Page 50 of 135 FirstFirst ... 4046474849505152535460100 ... LastLast
Results 981 to 1,000 of 2693
    Apr 2013
    #981
    Quote Originally Posted by eyepon View Post
    after 1 week of relentless back reading, I'm getting my GLS V hopefully by weds next week! keep it this topic alive please!
    also, saan po didirecho sa first mods!!
    kilig much!
    I deretso mo kay boss zix888 yan. Pa egr blanking, occ, cabin filter, knn air filter mo agad para masarap yung breakin period mo kay monty.
    #982
    Quote Originally Posted by bicol_ini View Post
    Since I got my unit (last Nov 2013), I used Shell Fuel Save Diesel but once in a month I fill-in Vpower as recommended by expert from Shell since Vpower has content that cleans fuel nozzles daw.... my ODO reading is now at 4.3K, so far so good....
    Thank you for the input. I read some myth that regular diesel will clog the fuel filter. Buti naman Shell Fuel Save hindi. I think I will follow your fill-up routine.
    #983
    Quote Originally Posted by Bengbeng View Post
    Now, I'm confused. According to Mitsubishi di na daw kailangan break-in kasi ginagawa na raw sa factory. They said, don't carry heavy loads and don't push it too hard. May nakalagay naman sa manual about running-in (Break-in), not recommended daw yung short distances and heavy loads. I travel from Malabon to Mandaluyong which is around 22km-24km depending on which route I take so I was thinking malayo layo na rin yung byahe ko.
    If indeed I need to break-in my monty what is the top speed and distance I should travel?
    Jun 2014
    #984
    Hi! First time buyer here! still looking for the best offer for MS. I'm not sure if it's more practical or we cud save more if we'll buy the unit in manila. we're from bacolod. any suggestion? have actually inquired here in bacolod . their DP is 165k, monthly is around 25k for 5years. that's under psbank. is this offer reasonable? Thanks!
    Jun 2014
    #985
    Hi Sir! i got almost the same quotation as that of obssessed. i'm hoping i cud get a better offer. can I ask for your SA's contact number sir? thank you.
    Nov 2013
    #986
    uy! bossing same route tayo hehe, no need to break-in na talaga kasi ginawa na sa planta yan,
    ina agahan ko alis sa umaga para maka hataw man lang sa roxas, so far less than 4k pa lang tinakbo ng monty,
    yung break-in kasi kunwari bago overhaul makina palit ng piston rings, valve springs, etc. recommended ng mga mechanics wag muna lalagpas sa 80kph ang takbo for first 1000km, para dahan dahan lumapat lahat nung rings at valve seats, tapos nun, pag walang nag usok, pde na hataw.
    Quote Originally Posted by matchbox10 View Post
    Nov 2013
    #987
    actually this is my first diesel, lahat nang sasakyan namin gasoline, nung unang labas civic FD sabi ng SA 1800 makina pero 1600 lang daw consumption, so kuha ko, na salestalk kasi meron ako civic dimension na AT , potek ang lakas sa gas, after 2 and half years binenta ko din at palit jazz AT na 1500 ayun matipid, 9km/liter na, pero eto monty AT, nakaka 8.5km/liter lang (nilagyan ko kasi TC at crdi chips) pero malayo difference sa laki at sa liksi nya, so matipid talaga diesel, bukod sa mas mura per liter..
    Quote Originally Posted by cycarino View Post
    Thanks s input, Whitemonty2014! I appreciate it very much! Cge yung gls-v AT n lng kunin ko ill start n magback read about issues n din, actually yung mods ska n lng cguro after n mag expire warranty. Thnks again sir!
    Posted via Tsikot Mobile App
    #988
    Pero yung oil nyan from factory sa thailand is for break-in talaga need to change oil talaga sa 1000 PMS. Haist sa kabila remapping ng ECU uso no need na ng chip. Galing!
    #989
    Quote Originally Posted by frostmourn View Post
    If you don't do 1k PMS, Mitsubishi will void the 3-year warranty.
    I think no one will dare argue not to do the 1k PMS.
    #990
    Quote Originally Posted by whitemonty2014 View Post
    Just to be safe itatakbo ko sa NLEX over the weekend hehe..
    sa C3/sgt. rivera/araneta ave naman ako humahataw.
    #991
    Quote Originally Posted by mar_jenn81 View Post
    I recommend you purchase your unit in Bacolod, if you're going to use it there. Unless the branch is Bacolod has a very poor reputation. Last week, I got my unit in Quezon Ave, there was a problem with the AVT back-up sensor. So I went back today to replace the senor. Imagine if this happened to you, you'll need to ship back your unit to Manila just to replace the sensor. You might be able to save some cash because of the competitive rates here in Manila, sakit ulo naman kung may factory defects na covered naman ng warranty.
    Furthermore, you'll be doing your PMS in Bacolod, it's nice to have a strong relationship with their sales team. Kahit papaano di ka pababayaan. Like what happened earlier, accessories is under winterpine (third party authorized by Mitsubishi) yet my sales agent kept on following up the installation of the backup sensor.
    Jul 2010
    #992
    Hi mga monty peeps! Just got my MS GLX A/T today. Next week na ang malayong byahe dami pa kasi work.
    Sir zix888, ok lang ba if magpablock ako ng egr after ng 1000 kms pms ko?
    Pagsabaysabayin ko na po ang egr blanking, knn filter at cabin filter. Yung occ baka after 5000kms pms na lang po. PM po kita if ready na po ako magpasked. Salamat po.
    Jul 2012
    #993
    To, dira ka nalang kuha. Bawi ka nalang sa rebate sg psbank, may rebate sa advance bayad sa due date, may rebate kong sobra ang amount ginbayad mo sa sked amortization nila. Abot na P40k ang accumulate ko sa rebate for 20 mos.
    Sent from my GT-I9100 using Tapatalk
    #994
    Pasensya na po mga Sirs, ngayon lang po ulit ako nakapag-reply, nagbakasyon po kasi ako sa leyte-cebu at di masyado nakagamit ng net...
    Sir PP, indicated naman sa 2010 manual kung para saan bansa yung model, same as sa online manual. Kaya lang, dahil sa upgrades, other parts from specific models in other countries are being used as upgrades pa sa models natin.
    If you are referring to SW remote battery, i guess nag start in some 2012 models na wired na yung controls.
    Base sa pagkakaintindi ko sir MID is yung display sa taas at ang HU is yung nasa baba kung saan may lagayan ng CD o magplay-play ng CD.
    :D
    Sent from my Nokia5110i-VgT using Tsikot Forums
    Thanks po Sir prince777, for the reply, really appreciated...
    glad to hear yung reference material na gamit natin as source of good info, and the same time, for safety na rin sa monty users for everyday use...malaking tulong na po ito sa lahat, to avoid any accidents/incident, para na rin po sa safety ng lahat...
    kung ano man po yung mga issues/concern, to resolve it in early time....
    [QUOTE=Reybeck;2349328]
    Quote Originally Posted by playplugg View Post
    Sir Reybeck, ask ko po kung i-hold ko po yung volume switch, will fully turn off the HU?! and same procedure po rin ba to turn it on again?!
    para before starting the engine, need to turn off the HU(MMID), para less load sa battery during start up and prolonged the life of the HU,
    The HU....
    Yes sir, same procedure lang po.
    Thanks Sir Reybeck...although na hindi nag-turn-off yung MMID (HU)
    instead, meron po ako nakita not sure kung yung small circle, (parang reset button na gagamitan ng paperclip) for HU/MMID reset...
    kung ito po talaga yung reset button...
    Quote Originally Posted by Saki View Post
    Based on my experience usually the oil leak is the most common symptom (visual), it bounces much at early stage, and thud sound while running when it worsened. With my monty I didn't feel the bounce first, nakita ko muna yun leak, then I realized di nga normal yun bounce nya.
    Thanks po Sir Saki for the info...
    almost a month ago, nag test po ako ng handling performance ng monty ang pushing my limits in driving and the monty handling/stability...sa daang-hari, before po ako mag-vacation, maganda po ang naging result (handling/stability, braking performance ng ABS/EBD)...uphill/downhill, yun lang po meron po akong hissing sound na naririning (parang na-deform na mags na kaya pa-ihandle ng rubber tire[s]) after the run, nasa molino part na ako... but no incident(accident) happened during the run...pag nakauwi po ako sa bahay namin..will check the suspension, and takbo ulit ang monty if this kind of sound will reappear again...
    Quote Originally Posted by DAMaster View Post
    sir playplugg salamat sa reply and info! sa mga kasama natin na naka gas variant, please share your experience sa maintenance and FC please. thx!
    Anytime po Sir DAMaster....sa sobrang dami ng back thread...di ko pa po nababasa lahat ang mga current info and reply
    #995
    No problem for that Sir matchbox10..
    As long as yung time-frame na kabisado at gamay nyo po yung kalsada na walang tao/property
    w/o risk...
    Safe driving po Sir (Y)
    Nov 2013
    #996
    oo nga sir, nakita ko din sa FB remapping ecutek with dyno test sa QC lang tapos yung talyer specializing BRZ/T86, GT-R, and Montys, bumili pa ng bagong monty pang demo nila sa ecutek retuning, tapos me suggested pa na mas malaking turbocharger hehe ipon mode, di pa ko nag inquire kasi wala pa ko budget pero retuning pa lang yata around 30k na wala pa dynotest
    Nov 2013
    #997
    ok bro, enjoy! haha ini imagine ko nangingiti ka din habang nag d drive, nakaka alis stress hehe..
    #998
    Good eve Monty peeps ;)
    sir Louie pa PM naman ng price ng SD card, trying to send you a PM kaso puno na daw inbox mo. I will soon get a GLX AT and may get a free SD card though i am thinking if it is worth to negotiate replacement with other possible item/s like back up cam. -tia
    #999
    sorry OT lang..
    at 3k km, finally had our GLX/MT installed with K&N and OCC: and had optitron activated kanina courtesy of sir zix. watching him worked built up his credibility/reputation even more, very accomodating sa mga queries ko in all matters monty.. for now, happing happy na ko sa mods having done with EGR blanking and ac cabin filter noong una pa, also c/o sir zix. mas sumarap hatawin si monty sa nlex back to la union, hindi mararamdamang 120-130kph na pala. pero, ika nga ni sir zix, safety first..
    thanks master zix lalo na sa guaranteed lifetime free consults, hehehe..
    Sep 2013
    #1000
    Quote Originally Posted by vickoy1228 View Post
    Hi sir sorry po hehe nadelete na po, also sent you a message.
2014 mitsubishi montero
