Prince777,
forgot to mention I am using android. Checked the playstore and they do have one for it.
Thanks
magtatanong lang po para sa oil catch can ilang mm po ba yung size ng fitting na swak para sa orig hose natin
question po masters .. nagpost ako sa non vgt thread pero parang ito yung active kaya ditto na lang po
for glx AT nonvgt,nagback read na po ako and lagi ko nababasa that nonvgt AT has inadequate power torque compared to vgt. Panung kulang ung power? Kunwari, edsa lang cruising 30-40kph e gusto po magovertake.full step sa gas pedal walang torque na mararamdaman? Walang jolt? Walang sudden 1acceleration? As in mabagal bumilis? from full stop, tapos full step on gas pedal wala din jolt sa glx AT? pero sa gls ramdam ung power?
Thanks po
Sir, pa pm naman po ng price ng k&n filter padamay na rin po ng occ at cabin filter. Thanks
Sent from my GT-I9205 using Tsikot Car Forums mobile app
you mean palaging nakasalpak yung OBD scanner? pwede namanmost obd2 apps now go beyond the common use of obd2 scanners of just identifying the cause of faults or check engines lights. but now, they provide real time information from you car ECU. so habang tumatakbo, you can see most of the vital readings like rpm, pressure, temps, fuel level etc.
Good pm mo mga Bros,
tatanong ko lang yung tamang pag sukat ng langis. ang alam ko kasi mga 5-7hrs naka off yung engine then saka ko susukatin, pero nung
sinabi ko sa service advisor ko yung pag check ko ng langis sabi nya mali daw yun. dapat daw mga 20mins umaandar muna yung engine. alin po ba ang tama?
thanks a lot.
Hi Thumbdrive. Sorry late response. I was out of the country for a month. To answer your questions, yes it is loud but no loss of power. Same speed around 100-140. For me and my wife, we noticed it. Parang sound na you are in front of the electric fan. Havent talk to my agent yet about this. Will give him a ring tom. Will update you on his feedback. Thanks
