Page 144 of 197 FirstFirst ... 4494134140141142143144145146147148154194 ... LastLast
Results 2,861 to 2,880 of 3938
    Feb 2007
    #2861
    I am using 32psi on all tires - nitro filled.
    Sent from my Nokia5110 using Tapatalk Pro
    Feb 2011
    #2862
    ours is 30psi front & 32psi rear. sakto lang for me.
    Apr 2013
    #2863
    32/35 ako before kaso matagtag na. Okay siya pag full load si monty. Ngyon 32 in all 4 tires.
    Sent from my iPad
    Aug 2003
    #2864
    Quote Originally Posted by kiros0110 View Post
    Mura lang dito sa Thailand... 220Baht / pc
    Mura nga sir. I have that emblem too. Removal of the old monterosport logo is easy. Di naman masisira yung paint. Just use dental floss as prince said. Although the plastic is a little soft kaya nasira ko yung monterosport logo ko. Ok lang no need naman. If euro setup ka sir nasa right side itong pajerosport nakalagay. Just a tip.
    Aug 2003
    #2865
    Bombie86, jc garage has an aftermarket sway bar. For egr blanking and other practical mods, there is our resident guru zix888.
    Feb 2007
    #2866
    Quote Originally Posted by keal01 View Post
    Meron kayo nito sir prince? May 16mm fittings kaya nyan? Baka rin pala mahirap humanap ng element nito.
    Sent from my iPad using Tapatalk - now Free
    Did not pursue to buy one sir, masyado mahal para sa akin. ;) although i have friend that can bring me from AUS.. Baka nga diy na lang ako ng tank mismo.. ;)
    Feb 2007
    #2867
    *kiros:
    You can use this guide sir to install your emblem:
    Go for Euro theme set up sir ;)...
    Feb 2013
    #2868
    Sa mga naka 4m41 engine, saang point ba ang iblank sa egr, yung malapit sa cylinder head or sa exhaust. TIA
    #2869
    Quote Originally Posted by ricciboy View Post
    yung ginawa ko sa recent 4m41 eh dito
    Jun 2008
    #2870
    Today OCC and EGR blanking installed courtesy of *sir Zix888...GLS V '13
    Thank you sir Zix888 and nice doing business with you...till our next installation...
    Feb 2013
    #2871
    Sir zixx meron ka pa ibang picture dko ma identify kung saan banda ito
    Mar 2005
    #2872
    Quote Originally Posted by zix888 View Post
    Sir zix, from the looks of it, mukhang sa cooler outlet yan ah instead of the inlet. Any particular reason why you put it there for 4m41 while sa 4d56 e sa cooler inlet ang blanking? Thanks.
    Apr 2010
    #2873
    if i may butt in, inlet po yan ng cooler. with that setup, where inlet pipe was removed, meron pa isang blank nyan sa exhaust manifold side. kung di tatanggalin ang pipe, i recommend sa exhaust manifold side ang blank. but aluminum blank *might* not withstand the hight temp. in regards, cooler inlet or outlet is a better choice. hth.
    #2874
    Quote Originally Posted by ezrydre View Post
    didnt remove the exhaust pipe bro, just showing ricciboy the point where i blanked.
    May 2007
    #2875
    Bro zix, ano ba pwede gawin para iwas rust build-up?
    Mar 2004
    #2876
    I believe the recommendation is at the exhaust. Can someone show picture of location where to blank at EGR exhaust pipe? Will cause the Check Engine Light to turn on?
    Apr 2010
    #2877
    Hi Walter. I PM you some pictures. If not enough just let me know. Actually it's the engine exhaust manifold. Not EGR exhaust. EGR cooler of 4m41 is on the passenger side. just above the turbo. Any problem or question with your install, just let me know and I'll try to give my best help.
    edit: passenger
    #2878
    Quote Originally Posted by SRGuy View Post
    rust build-up? what specific part ng oto?
    Feb 2013
    #2879
    Quote Originally Posted by ek2jayvee View Post
    Kung sa Right sir edi tatanggalin ko yung GLS-V emblem?
    Feb 2013
    #2880
    *kiros:
    Salamat sa guide sir. Patingin naman ng sa inyo
2013 Mitsubishi Montero Sport owners
