Page 11 of 14 FirstFirst ... 7891011121314 LastLast
Results 201 to 220 of 642
    Sep 2012
    Thanks sir zix888! 2010 and later model ng adventure ang may EGR. Tama si sir Zix same with monty kaya yung appointment ko sa kanya suntok sa buwan kahit may pictures akong sinubmit sa kanya. It seems that Mitsubishi adventure and Montero are almost the same, same oil filter,and same EGR balnking plate shape.
    Jan 2008
    Quote Originally Posted by b0y37 View Post
    ^ Is this after the intake? If so, wala palang ganyan sa mga lumang advie. 2010 onwards lang ang meron?
    check mo kung may tube coming from your exhaust manifold going to intake EGR yan.. add mo pa yung vacuum advance valve sa ibabaw tapos may mga tubes pa
    Sep 2012
    sir maiba lang ako. mayroon ba sa atin nagpainstall ng legit oil catch tank. and san po nagpa install? ano po yung hose/nipple size.
    Sent from my Galaxy Nexus using Tapatalk
    Feb 2007
    Sirs,
    My adventure was in Tacloban City and is one of the victim of super typhoon Yolanda. Submerged and the bad part was; it was sea water and not just rainwater. Even this will be restored, i would assume that there will come a time that in some parts, rust will still build up faster than it should be.
    1. Can I claim for a replacement unit? Bought December 2012 and less than 4K kms on the odometer.
    2. If 1 is not possible, restoration will be the option. For those who have their units restored, what was the process on the insurance claim?
    3. Aside from letting the car dry first, not starting or cranking, ECU check/removal, battery disconnect..what are the other things that i need to note?
    Would really appreciate your input sirs..
    Thanks a lot and more power..
    Sent from my Nokia5110 using Tapatalk Pro
    Jul 2013
    Sirs,
    Remove the ecu. Get rid of seawater by rinsing the vehicle with fresh water.
    Feb 2007
    Quote Originally Posted by silver V View Post
    Change oil and gear oil sir
    Definitely sir...
    Quote Originally Posted by Lew_Alcindor View Post
    Where would be the location of the ECU?
    For sure the sea water will already dried up before being washed with fresh water..
    Apr 2013
    Definitely sir...
    ECU on adventure?
    Nov 2011
    Feb 2007
    Red submarine..
    *I will be a Yolanda Survivor!*
    Jul 2013
    Red submarine..
    naku si prince. sayang naman po yung bago niyong kotse. total loss na po ata ito sa insurance niyo sir. hope walang nasaktaan sainyo sir. yung monty niyo po?
    Feb 2007
    Thank God at ok naman relatives amd my family is in Manila when it happened. Monty is also there and was ok..
    Maliban kay Advie..
    Jul 2013
    Maliban kay Advie..
    nakumusta niyo na po ba insurance niyo? for sure sir madaming mag claim sa insurance ngayon sir. mabuti naman po sir ok isa niyong kotse, pero bakit di po nakaligtas advie like monty did?
    Apr 2013
    Maliban kay Advie..
    My sympathy sir,wala pang plate si advie tila ma total loss na:shocked:
    Apr 2013
    Up ko lang sir prince 777, ano na update sa advie mo ?
    Aug 2009
    anong meron na bago sa GLX 2014? tia
    Jan 2013
    Good day sa inyo. ask ko lang po sana kung mag fifit ba sa super sport 03 yung 17x7.0jj et42 offset. tapos 215/55 17 hindi po ba ito matagtag? thanks in advance!
    Feb 2007
    Quote Originally Posted by cardict View Post
    Good and Bad..
    I was able to get the "constructive total loss" amount of 700K for a 2012 Dec unit.
    Bad thing is I was only break even with all the money spent, from DP and MA combined.
    Still waiting for the cheque to be issued...tsk tsk...
    Sent from my iPad using Tsikot Car Forums
    Apr 2013
    Good and Bad..
    Your insurer sir?
    Feb 2007
    Yes sir loy, advised already the insurance. Iniipon ko lang requirements para i-submit.
    Nasa Leyte si Advie kasi doon sya naka-pirmis at si monty ang ginagamit sa Manila kaya si advie lang ang nadamay..
    Hopefully total loss nga ang sabihin ng insurance..
    Jul 2013
    good move sir, nakaevacute po family niyo before the storm hits. pag di po total loss sasabihin nila, mahihirapan po kayo mag restore. mukhang bugbog inabot sir.. nakakapanghinayang talaga damages due to yolanda...
2012 Mitsubishi Adventure?
