[QUOTE=yapoy86;1973643]lalakas din yan pag naka 5k kms ka na.. also block mo na yung egr para mas lumakas ang hatak.../QUOTE]
Sir baka pwede ishare kung pano ginagawa ito? Thanks.
Hello mga sir.
May quick question lang ako.
I just bought the Adventure Super Sport SE 2012, 2 weeks ago.
Just this morning may napansin lang ako sa ilalim.
Sa ilalim, left side sa may driver's door, may parang host(rubber) na nakausli. Normal po ba ito?
Hindi ko kasi sure kung hindi ko lang napapansin ito dati.
Thanks in advance.
drain hose yan ng aircon...
re egr blocking all you need is a metal plate.. remove the intake where you can see the EGR valve... then make a cut out from the plate to cover the valve...
madali lang tanggalin ang intake yung nakakabit sa black tube
Nailabas na po namin yung adventure kanina. Napansin ko lang po na mahina ang signal ng tv, paano po kaya mapapalakas? Tsaka eto late ko na kasi napansin, medyo may sabit yung drivers' glass window kapag sinasara before sya lumapat, pero konti lang naman, hindi lang kasing swabe ng iba. :D
Sir subukan nyo po yung X8_C2 yun ang gumana sakin tapos lumabas po kayo ng garahe nyo para makasagap ng satellite signal.
Sir yung set-up ng voice navigation dapat piliiin mo po yung english kasi pag female or male voice ang naselect mo, walang sound na lalabas dapat po yung english lang. FYI.
Ah kaya pala wala nagsasalita.. hehe! E yung voice command sir napagana mo ba?
Saan po kaya ok magpaservice na casa? Nasa magkano kaya 1k PMS? May mga ipapa-align din kasi ako like steering wheel(wala sa gitna), drivers' glass window at rear driver side door.
PROS:
1- less smoke-belching (higher combustion chambers temperature lead to a more accurate combustion process);
2- lower fuel consumption;
3- increased performance;
4- increased reliability, since EGR is too sensible to higher sulphur amounts on the fuel, and also due to the recirculation some sulphur compounds generated due to the combustion come back and start to rot the engine inside...
We might remember the EGR was originally developed for spark-ignited engines, and their only advantage into a Diesel is the decreasement on NOx emissions, altough it has some bad side-effects.
tagal n din ako ngbbsa sa thread na to at mdmi ako ntutunan salmat sa mga nag share ng info at fyi about sa advie ngayon lng ako nkregister para mkpg post:
queries lang:
san po yungg EGR mkikita at pano ggwin yung EGR blocking?
ok lng b mag pa change oil mski nsa 2.5 k p lng yung km nya at malayo p sa 5k na ibblik sa casa medyo maingay na kasi yung tunog ng makina at sabi dun sa mitsu site mdumig oil filter daw couldcause yung engine noise so im just asking sa nkk alam nung first 1k change oil kasi naging thimik yung mkina after ilabas ng casa.
share ko lng po n FYI in return sa mga ntutunan ko n info dito:
sa mga gusto manood ng you tube videos sa head unit ng adventure gls sport se:
pwede nyo idownload yung video sa you tube ng mski anong downloader tapos i convert sa mpeg(*.mpg) format tapos ilagay nyo na sa usb or mski ano storage n pwede sa port gmitin (usb ipod at sd slot) at you can enjoy watching your favorite you tube videos hbng nagd drive kayo.
sa hindi mkpg download sa you tube post lng sa thread at i'll post a site na easy ang pg download.
p.s
may nkk alam b ng easy way pano maalis ang dried rugby sa carpet matting ng adventure na nbuhusan o kelangan b sya na palitan.
salamat![]()
to download a video from youtube you can use http://tube2mp3.de/ and select if you want to download the video in mpeg, xvid or mp4, or can also download only the audio in mp3...
Question: advisable ba na ipacheck up sa casa yung mga adventure na nailusong sa baha na almost nasa running board na?
1 month nalang 5kPMS na. antayin ko nalang ba? baka kase sabihin sa casa ang arte ko heheh
yes, have your brakes cleaned.. especially drum brakes.. and your lower ball joints greased...
