Page 74 of 251 FirstFirst ... 246470717273747576777884124174 ... LastLast
Results 1,461 to 1,480 of 5006
    Quote Originally Posted by renn114 View Post
    Thanks for the feedback sirs.
    Di po ba 350Nm from 1800-3200 rpm range?
    Di ko sure but it seems 2,000 rpm usually type ng Mitsu as the starting point ng turbo working. I might be wrong though and baka nga as early as 1,800 full monty na!
    Feb 2010
    #1462
    tentative date for the availability of 2012 montero will be on september. there are minor changes for both variants. magkakaroon na ng Cruise control ang GTV, ang GLS-V naman magkakaroon na ng paddle shifter. yung rear aircon ng both variants nasa ceiling na. so far yun palang ang update sa amin.
    Jul 2004
    #1463
    Quote Originally Posted by lyonell1989 View Post
    IMHO, they could have done away with cruise control. it is as useful here as heated seats. in my previous ride, i rarely used the cruise control
    paddle shifters on the gls-v is okay and will make manual shifting more convenient. this should have been made standard in the first place
    as for the ceiling mounted aircon, this is a nice addition. hopefully this will free up more space for the third row seats
    May 2009
    #1464
    hi to all. not so sure if this has been taken up before but would appreciate if someone can reply to my question. my navigation system's voice is not working. i checked the settings of the navi and the volume is on high- level 5 but still it doesnt talk. Is there a control which i failed to switch? thanks in advance.
    May 2009
    #1465
    Quote Originally Posted by gardy_incon View Post
    Mga sir, help naman po, nawala ung voice sa GPS ko d naman siya naka mute. Ang huling tanda ko lang na nagawa ko is na i unplug ko ung cable then plug ko ulit, May connection ba kaya un?
    is your voice working na? what did you do?
    Apr 2008
    #1466
    Is this true, the total add on rate for the whole 3 years(36 mos) is 14.37%? May I ask sir if you know somebody from metrobank that I can directly talk to? thanks
    #1467
    Quote Originally Posted by lea128 View Post
    Try factory reset, push button # 10
    May 2011
    #1468
    If there really is a 2012 GTV coming out this September. Limited edition ba ang 2011 GTV/GLS-V? hehe Or Guinea pig
    #1469
    Need help on setting up my reverse camera. Anyone who knows if there is a setting needed to be done to activate the camera? Tried to connect the reverse cam directly to the video jack just to test if its working, before laying out the wiring, and the camera sign didnt illuminate and rear cam didnt work. Tested my rear camera on my home tv and its working. I know it has something to do with the setting, style para maobligate ako magpagawa sa casa/winterpine, so if anybody there na may idea, it would really be appreciated. Wanna do the wiring myself para malinis sana. TIA.*
    Jan 2011
    #1470
    Quote Originally Posted by zix888 View Post
    You need to connect the HU reverse cable, pink color ata yun (pero meron yun label) sa reverse light supply to make it work. Suggest also to have the camera supply cable connected sa reverse light supply para hindi maginit. Pwede kang mag tap sa reverse light sa ilalim ng dash sa driver side, yun panel cover sa tabi ng footrest. Need to have a tester to know which cable to tap to habang naka reverse yun shift knob.
    Will connect the SD card extension sa Monday. Will let you know the wire color kung san ka mag tap, in case hindi mo pa nakita by then. The camera will work work during reversing, it will not work via the HU control, Hindi daw yun ready sabi ng AVT.
    #1471
    Quote Originally Posted by tuazon7 View Post
    Okay thanks, will wait for your update, ayaw ko na magtrial and error, at least sigurado na ko kasi maginstall ka din pala ng extension cable, hintayin ko na lang info mo sir. Pasuyo na lang sir how they're connected. Thanks a lot sir
    Jan 2011
    #1472
    mga sirs! saan nakakabili ng sd card extension cable?
    regarding the reverse cam you can ask tsikot shop how they did mine.
    Mar 2011
    #1473
    Sir, Will the new GLS-v also be having 5 speed tranny?
    Mar 2011
    #1474
    Noted sir Zix... thanks a lot.
    I hope with the new GTV, I would not be doing so much "tinkering".
    All the clips are mounted horizontally, so horizontal motion of pull is a must, never upward. Start from the small opening on the lower portion between the cover and lcd screen, literally your fingernails touching the lcd screen for a start
    #1475
    Quote Originally Posted by md_alcapone View Post
    I got mine from china, taobao.com ( thats like ebay in china )
    Jan 2011
    #1476
    panu pag translate sa english sir? chinese character kasi...
    #1477
    Naku sir, bro ko kasi nag order niyan, he works there in china kaya medyo nakakaintindi na siya salita nila. Last april pa nga niya nabili yan for me, last thu lang nakarating sakin, he is on vacation here.
    My navi sd card
    #1478
    *md
    Sir you use google translation din daw, medyo matrabaho nga lang
    #1479
    Sir zix888 how about eibachs? Have you tried it? Gusto medjo ilower na hindi gano magbago ride comfort kasi nahihirapan talaga sumakay. Ty
    Feb 2010
    #1480
    I'm not yet sure, pero during our meeting with regards to 2012 monty, baka daw maging 5 speed A/T na rin.
    as for M/T VGT, malabo pa daw magkaroon nun.
2011 Mitsubishi Montero Sport [continued]
