i can do without the seatbelt indicator lights and warning sounds
i just find it irritating to see this light/alarm on drives when i don't even use/need a seatbelt
Already checked feedbacks online, and for those vehicles equipped with the feature are asking how to turn the buzzer Off . So i based the function of this system on that. The system i am installing is timed, it doesnt go on the whole time you're driving w/o seatbelt fastened. Plus it has a on-off switchÂ*
I got the Part no. From the Service manual viewer(smv) for the seatbelt switch. Then as of now naka on-off switch pa lang siya, tinapos ko lang muna yung wiring para concentrated na sa driver seat para sa switch and buzzer next time na may extra oras. Ang naisip ko na switch integrated lang sa labas, kasi you are right sa tingin ko parang medyo sealed type ata siya, pero try ko din muna buksan, if ayaw, outside switch pwede din naman. Okay ba bro kung integrate ko na lang yung opened-door warning buzzer para hindi na bibili extra buzzer para dito? Totally oem parts. Kasi wala makuha buzzer sa banaue, naikot ko kanina.
Yes sir, yun yata yung diagram reference number. The only part numbers i found so far are those for the special tools. ;)Originally Posted by zix888
Parang there still some exe file that need to be installed para makuha yung part numbers.
I don't know if this can help..
Auto Parts mitsubishi- parts directory
This might be helpful if something can't be read. :-)
http://translate.google.com/#
Sirs goodafternoon po, off topic lang.
Bumili ako ng DRL, DIY ko po sana yung pagkabit. Gusto ko po sana, pag naka ON ang engine, on din siya. If OFF ang engine, off din siya. Saan ko po ba itatap yung device para ganon ang operation niya? hindi ko na lalagyan ng switch para less hassle.
Thank you po.
sus, mayroon pala ng lahat ng alarms bells and whistles ang monty
why mitsu opted not to activate these still puzzles me
i am not too fond though of the seatbelt alarm.
if this was enabled, i would have requested this to be disabled, hehehehe
Will have all my windows and side mirror etch by the end of march. Already ordered the armour etch cream and i have been reading about "in-place" etching since i dont want to remove the side mirrors..![]()
Thanks sir zix. Kung kaya ko lang yung LED indicators sa side mirror isabay ko na sana eh.. ;DOriginally Posted by zix888
Actually ang medyo mahirap lang is yung wiring. Sakin kasi isinama ko din sa oem wiring, dumaan din sa tubings, kaya medyo sumakit kamay ko after eh. Yung mounting ng arrow led turn lamp madali lang din, kelangan lang eh tools like heat gun(removing mirror from plastic backing), dremel(trim plastic backing to accommodate the arrow led), thinner(remove the primer from the back of the mirror itself), double tape.
