In my experience, not really delays the RCP activation but prolongs its effect. Yung nga lang, pag tinaas mo yung setting, mas gradual ng konti yung effect. Hard to explain but maybe because of the mapping curves being stretched, kaya mas gradual ang slope.
Sa youtube sir may video. Best to watch that para sa reference mo on tuning and locating the dials.
Good day po. I'm sorry if this is OT but ask ko lang sana kung active pa ba and MSCP website? di ko na po ma open kahit hanapin ko sa google. TIA
jaejae - ara pa ang website. Use this link: Login Required |
You will need to log in anew since new look, new interface na ang forum
sir eugene long time no see ah! i hope you are doing well :D salamat sir! try ko
ganda po sir zix888 po nang pagkakalagay ng springbooster parang oem...pagkakagawa
the cover of my step boards already having build up of rust. had to repaint to prevent rust from progressing. 3 of my officemates( 2 -'10 models, '11 model)are also rusted.
Anong rpm niyo pag 100kph? parang tumaas yung sakin naging 2100 o nanibago lang ako?'11 gls-v. 2.5vgt 4 speed at.
Dati nasa 1800 lang din.. 105k kms na natakbo ngayon. di ko pa napapalinis yung egr. Yun kaya ang problema? Ang hina na kasi ng hatak e.
Magkano po ba yun pagawa sa casa? and may check engine light pala, pabalik balik lang. hindi pa napapacheck kasi di na ako gumagamit nito e..
clairenceh, since high mileage ka na, yung hina ng hatak may be due to a number of factors. Check your air filter and fuel filter if they have been replaced recently. The EGR may be dirty and so is the intake manifold. Your intercooler may already be full of oil especially if you dont have an OCC, time to cleanse it. Check if you had the valve tappets adjusted already. Clean the MAF sensor if needed. Do an SIQL sa casa.
Since out of warranty na, after doing the following procedures, probably you may want to blank your EGR.
Sir zix, done cleaning may intake manifold yesterday.. 3days work din since its mY first time magbaklas ng manifold.. my egr blanked and tested na din, ayos na ayos.. lakas na ulit ung hatak.. napangiti talaga ako sa performance nya.. sana lng d umilaw cel for blanking may egr.. test ko ulit knina driving for only 40kph (kasi nagoopen daw yta ung egr valve ng less than 2500rpm), 30kms and idle for more than an hour so far d pa umilaw.. i also adjusted my waste gate actuator kya ang aga magspool ng turbo.. now, napapaisip tuloy ako, bkit pag sa casa laging advise na linisan ang egr kung d rin lang pati intake manifold.. what for kung ung egr pipe lang? D mabuti pa ngang barado na un para parang nablank na din lang egr,,
Sorry kung d masyado maintindihan post ko.. not really good in car forums.. now, pano po lilinisan ung intercooler? Since langis po yta dumadaan dun? Any advice please,, TIA..
