personally, i would have preferred to have the switches of the front and rear foglamps separate and independent from the stalk
also, right now, i can't switch on the rear fogs without switching on the front fogs. sometimes gusto ko lang rear fogs ang naka-on and off ang front fogs. maganda kung one is independent of the other
I'm sure it can be done atty. There are a lot of options where you can put the separate switch for the rear fog light. It's just a matter of having the correct type of switch and a good installer;-)..
Mods are endless ba atty?
As long as there are still features that are available in other countries for the montero which is stripped down in the phil variant, "upgrades" will still be possible.
Stock bulb
With HID
Â*
Finally nagawan ko na ng solution yung medyo mahinang reverse light nung gtv ko, since iisa lang kasi siya dahil rear foglamps na yung isa. Retrofitted an hid. Ang laking improvement lalo sa places na talagang walang enough lighting, kitang kita na siya.Â*
ok sir zix ah heheHindi naman po sha nakakasilaw sa mga nasa likod?
Sino po meron jan extra sd ext pabuy naman po hehe![]()
Hehe, sigurado nakakasilaw sa likod, pero during reverse lang naman, hindi naman siya parang rear fogs na laging bukas eh.
Wala ako extra sd cable, si sir skyranger nagpamasko ng 5 pcs, pero alam ko ubos na din. Update na lang ulit kung mayroon papunta na china para makapagpasabay tayo ng sd cable
happy new year sa lahat ng monty owners
ingat lang sa pagmamaneho at baka pagkamalan tayong gago daw
nyahahahahaha
:hysterical:
yes, happy new year Monty owners! ang new years resolution niyo ay huwag na maging street bully at feeling superior sa lahat. Amen?![]()
Medyo matagal ko na nabili yung hid set na yun, actually pinaglumaan na nga, bale napundi na yung ka-pair nun, so spare ko na siya. Decided to use it na lang kaysa nasa bodega lang. Just bought it locally. But you can get a single beam hid for as low as p1900 nowadays, got my front foglamps p1900 /pair , same price
Sir zix ok to ha, Pag traffic tapos naka bright yung nasa likod. I'll put it on reverse. :pOriginally Posted by zix888
Finally Â*my last diy for this year 2011 is finished. Â* mounted an arrow led on the side mirror for turn signal
Montero sport arrow led turn signal - YouTube
