Page 125 of 251 FirstFirst ... 2575115121122123124125126127128129135175225 ... LastLast
Results 2,481 to 2,500 of 5006
    Jul 2004
    #2481
    Quote Originally Posted by zix888 View Post
    Simplest connection is just tapping it(rear foglamp) to the front foglamps, in that way we can leave the stalk switch as it is , but have a control on the rear fogs. In my case i always turn on both front and rear fogs together so that set up would be fine with me.
    personally, i would have preferred to have the switches of the front and rear foglamps separate and independent from the stalk
    also, right now, i can't switch on the rear fogs without switching on the front fogs. sometimes gusto ko lang rear fogs ang naka-on and off ang front fogs. maganda kung one is independent of the other
    Feb 2007
    #2482
    I'm sure it can be done atty. There are a lot of options where you can put the separate switch for the rear fog light. It's just a matter of having the correct type of switch and a good installer;-)..
    #2483
    Hehe same here, hindi nga maturn on yung rear unless on din yung front, kaya i did a simple manipulation, inverted the connection, first to go on is the rear then front, in turning off, last on first off, kaya unang mag off yung front before the rear. Mas gusto ko din kasi rear muna bukas lalo na kung medyo kagat pa lang ang dilim, park lights plus rear combi lang
    Jul 2004
    #2484
    hindi nagbaliktad ang indicator lights sa instrument panel?
    *prince -- yep, puede i-DIY pero saka nalang
    #2485
    Hindi naman nabaligtad ang orientation sa panel since the the supply naman nagbabase galing ng stalk switch yung indicator
    Jul 2004
    #2486
    ah okay
    kasi magkaiba ang symbol ng indicator for the front and rear fogs on the instrument panel
    so if you turn on the rear fogs, it is the symbol for the rear fogs that turn on first?
    #2487
    ah okay
    Yup the symbols stay just the same, if its rear indicator is on, rear foglamps is on, same is true with the front foglamps.
    Jul 2004
    #2488
    ayus ah
    dami palang puede i-modify sa monty
    Feb 2007
    #2489
    Mods are endless ba atty?
    As long as there are still features that are available in other countries for the montero which is stripped down in the phil variant, "upgrades" will still be possible.
    Jul 2004
    #2490
    yep mukha nga endless
    either mods to add to the monty or mods to change/enhance what you already have in the monty
    Nov 2011
    #2491
    Sir zix888 tanong lang po.do guys from mscp or pajero club also consult you?or are you also a member of both?hehe tanong lng sir ang tindi ng mga mods sa mga babies mo sir.parang when you post an article eh talagang read and learn from it eh hehe thanks sir!
    Aug 2011
    #2492
    Quote Originally Posted by mhacko View Post
    Thanks Sir Six.. BTW any suggestions for HID Kit, Color Temp (5000k to 6000K is ok?), brand, where to buy.. I also checked with my dealer na pwede daw magdala ako ng HID Kit then sila mag install since walang available na HID kit sa kanila. Sir Six naka HID ba Monty mo, what is the Color Temp? Thanks
    Try xenonworx at calamba st banawe or xenonbulbs araneta. 4300k is the brightest. Dont go beyond 5k. Hirap ka na sa gabi at ulan
    #2493
    Quote Originally Posted by silver V View Post
    Hehe, mahilig lang talaga tayo sir sa pagkakalikot and butingting. Dami ko din natutunan dito kaya in return naman eh i share what my mods are
    #2494
    Stock bulb
    With HID
    Â*
    Finally nagawan ko na ng solution yung medyo mahinang reverse light nung gtv ko, since iisa lang kasi siya dahil rear foglamps na yung isa. Retrofitted an hid. Ang laking improvement lalo sa places na talagang walang enough lighting, kitang kita na siya.Â*
    Sep 2011
    #2495
    ok sir zix ah hehe Hindi naman po sha nakakasilaw sa mga nasa likod?
    Sino po meron jan extra sd ext pabuy naman po hehe
    #2496
    Quote Originally Posted by ciscruz View Post
    Hehe, sigurado nakakasilaw sa likod, pero during reverse lang naman, hindi naman siya parang rear fogs na laging bukas eh.
    Wala ako extra sd cable, si sir skyranger nagpamasko ng 5 pcs, pero alam ko ubos na din. Update na lang ulit kung mayroon papunta na china para makapagpasabay tayo ng sd cable
    Jul 2004
    #2497
    maganda yung illumination ng reverse lights
    good job
    #2498
    Finally Â*my last diy for this year 2011 is finished. Â* mounted an arrow led on the side mirror for turn signal
    Montero sport arrow led turn signal - YouTube
    Jul 2004
    #2499
    i prefer the led arrow lights to the ones on the outside
    one time may nakita akong vehicle whose side mirror outside lights were colored blue, i just found it too garish and out of place
    #2500
    Yup same here parang off yung blue imo. What i have is just a turn signal amber color same with the 2012 gtv. Just added the arrow led on the lenses
2011 Mitsubishi Montero Sport [continued]
