Page 26 of 58 FirstFirst ... 1622232425262728293036 ... LastLast
Results 501 to 520 of 3019
    May 2011
    Quote Originally Posted by zix888 View Post
    oh, okay. activate gps, cruise at exactly 100kph (gps reading). then check what it says there at your speedo. let me know what is that reading. malalaman natin what exact dia your rig needs to give you the exact speedo reading
    Slight OT:
    Monty GPS (AVT HU) vs iPad2 GPS
    iPad shows slower by 10kph (stock monty), iv read somewhere sa post ni niky na me bearing din yun chipset na gamit ng GPS (refresh rate)?
    Although not so bigdeal for me, but who's more accurate?
    Quote Originally Posted by skybison View Post
    Slight OT:
    sakin naman yung gps reading ng avt is the same with my 4s and 3gs
    Apr 2010
    You can change the tire diameter in the ecu. I was able to get a cable to reprogram the ectas in the ecu. Just measure the tire diameter then input it in the ecu.
    May 2011
    Quote Originally Posted by big_d_lou View Post
    Care to share further details? What software are you running, cable (obd-usb?), etc?
    I'll be checkin on a OBDII(bluetooth) tomorrow, pair it on my android phone/ipad or laptop. With this, can i check on what you've stated earlier?
    Apr 2010
    This is the cable that i used to change the settings of the ecu.
    This is the software that came with it. You can see the settings for the tire diameter. Changing that will automatically calibrate your speedo with the new settings
    May 2011
    thank you *big_d_lou
    hmmm. I also have a monty but, basically they're just the same naman na projectors on low-beam, hi-beam on 'regular' reflective housing. Kung hid upgrade, probably mas-lalayo sya kesa lalapad ang buga UNLESS they'll have to tweak yun beam 'palabas/wider' throw. (Based on my knowledge on oldskul HL na pwede mo manual adjust on non-motorized-auto-leveling headlights).
    if you ask them to trade-in your stock GLS HLs and replace with SE HLs, magkano kaya?
    Di daw pwde trade-in...bawal daw, ibenta nlang daw sa labas. Ska suggestion skin yung low beam nlang daw palitan pra yung high beam magamit ko raw Kpag umuulan o foggy.. mahihirapan daw ako kung lahat hid? Totoo ba? 7K + yung lowbeam ksama na labor.
    May 2011
    Quote Originally Posted by rensom View Post
    6000k (white) or
    8000k (bluish white)
    + rain + asphalt = BULAG ka na sa daan
    What i did before was pair my h4 projectors (hi&lo 6k hid/white) headlights to h1 (3k hid/yellow) fog lights. Para at least me panlaban sa ulan.
    7k? Check the brand/specs and do a comparo - baka 2-3k lan sa labas. UNLESS warranty-ed nila yan and "acceptable" na sa iyo ang 7k for that. Madali naman kasi for me magDIY kaya hindi makatarungan sa akin ang 7k. And yes, i'll go for their suggestion na yun low beam lang HID mo.
    PS. Cheap china HIDs usually lasts 13-14mos past the 12mos warranty. Hehe
    6000k (white) or
    single beam china is P2k.,got mine last year march, upto (19mos)now okay pa din.
    May 2011
    Uy, good buy na yan.
    at a glance akala ko sabi mo goodbye na yan, hehe. no signs pa din naman of about to get busted, sulit na
    Apr 2012
    guys.. ano difference ng ASX 2011 2012 2013?
    Bumaba na yung price ng ASX 2011.. planning to buy a GTA pero almost same price na lang sila?
    Go for ASX na lang ba? ASX 2013 irerelease daw later this year? Ano meron dun?
    May 2011
    Quote Originally Posted by Det7 View Post
    2013 Mitsubishi ASX specifications & pricing revealed |*CarAdvice
    From the outside the updated Mitsubishi ASX remains largely unchanged but has been softened at the front with more flowing lines and an updated grille while the rear gets an revised bumper. Mitsubishi says the balanced approach creates a more hatch-like appearance.
    6000k (white) or
    Thank you parekoy..... sabi skin xenon daw ang ilalagay... ilan ba ang klase ng xenon? I mean pano mo mlalaman kung orig na xenon? Meron din bang orig na made in china?....yun nga sguro gawin ko...and I go to bluish white.
    May 2011
    not sure but try mo: Xenon HID Store - HID Kits - HID Lights - HID Conversion Kits if eto din yun benta sa iyo. Only tried VTX and Bi-Xenon HID kits e.
    with china naman, me "hi" & "lo" ends naman sila that goes with the price. hehe. So like zix's hid na 19mos and goin - sulit na yun for 2k.
    May 2011
    Noel, here are the pix of my wheel gaps to the shocks, trailing arm (forgot to take on the wheel well side naman, hehe)
    tires: 235/50/18
    mags: 18x8 ET +40
    mags to trailing arm (rear-left side)
    mags to front-left-shock absorber
    malayo pa ang gap! haha.
    angas lan nito o.
    tires: 235/50/18
    mags: 18x8 ET +40
    angas lan nito o.
    Angas talaga nyan, at brusko na masyado!
    Talaga bro ha, sinungkit mo pa talaga ang pag shot. Hirap nyan, pwera na lang kung nasa lifter.hehehe
    tires: 235/50/18
    mags: 18x8 ET +40
    angas lan nito o.
    Sinungkit mo pa talaga ang mga shots bro, hehehe..
    Parehas yata na 5spoke rim natin?
    Angas nga nyang Concept car ng ASX. Mas naging sharper ang HL at mga curves!
    (like)
    Mar 2012
    angas lan nito o.
    [/QUOTE]
    wow ang dating sir ng mags ah (sketch).. if im not mistaken parang may nakita akong ganyan sa mga naka BMW.
    Hope ganyan yun mags ko with my pizza pie. Sorry sir OT na. hehehe
    Thanks for the info parekoy
2010 Mitsubishi ASX Crossover
