Page 28 of 58 FirstFirst ... 1824252627282930313238 ... LastLast
Results 541 to 560 of 3019
    With the air filter, it will only add a few HP (around 5 or 6 I think) so you will not feel the difference. But if done with headers & piggyback ECU, the total HP increase is much bigger.
    Thank you GH!
    Sep 2014
    sir, kapag nag-install ako ng car intake at headers tapos pina-engine remapping ko na pero mag-papaservice ako s CASA, i-rereset ba nila yun?
    Aug 2012
    Larry, why did you sell your ASX? What did you replace it with? Thanks.
    Sent from my GT-N7000 using Tapatalk 2
    May 2011
    Quote Originally Posted by Pipefish View Post
    Naka cx5 na yan.
    Aug 2012
    Quote Originally Posted by skybison View Post
    Naka cx5 na yan.
    Maganda 'yung antenna ng CX5. Hehehe.:D
    Hmm, halatang fabricated at mukhang ok lang, as in ok lang din kung stock lang din sya! Or black color na lang din yung staintes plate na cover/guide ng pipe.
    Type ko pa kung rear fog lamp ang pinakabit sa likod.
    May 2011
    me motor ang headlights natin that controls the adjustment.
    Not sure lan with SE (4x4) variant kun me mala "gyroscope" sila for auto adjustment.
    I think may motor, once na nag on ako ng HL nakikita ko na nagma-calibrate pa yung level.
    May 2011
    Quote Originally Posted by Noel Salisipan View Post
    Yes the motor is out of the question meron talaga yan (one of the reasons why headlights with electronic adjustments are expensive).
    Yun "mala-gyroscope" (cp/tablets - eto nagca-cause ng auto-rotation ng screen) yun sinasabi ko kung meron nga ba yun headlights ng SE - which causes to auto adjust. Sa amin kasing mga GLS, 1-4 lan yun setting, though me motor pa rin - manual adjustments nga lang.
    Sep 2005
    sir yun 4 para saan kaya?
    sa manual kasi sir 0-3 lang meron description
    0- driver or with 1 front passenger
    1- with 5 persons seated
    2- with 5 persons and with fullload at the trunk
    3 - driver only with full load at the trunk
    correct me if im wrong.
    May 2011
    Quote Originally Posted by BRIAN View Post
    nah, i don't rely much sa manual. Sa kalye ako mismo nagti-timpla. Yun base ko is a regular stock height sedan - basta ang tama sa HLs din nya. Tsaka 2 lan kme usually ni mrs hindi gaano loaded.
    I have a real vacuum cleaner, not the lame 12-volt one. Hehe. >>:->
    my black&decker car vac performs like my compact 'cheapipay' household vac. Hehe. As long as it serves its purpose, bato/buhangin lan naman.
    me ilaw naman yun inverter mo that indicates na me power sya?
    Aug 2012
    Mga boss, do any of you use a power inverter? I got this 3,000-watt TBE inverter but I can't seem to make it work. I connect the + and - terminals to the battery but it doesn't light up. Is there something I need to do that I'm unaware of? I'm planning to use this 800-watt vacuum cleaner in the car. Thanks a lot.
    May 2011
    why the need for inverter?
    1. there are car vacuum cleaners that's plug & play with cig lighter. (12v/DC)
    2. common household vacuum cleaner (autovolt 100-240v/AC)
    unless you're trying to use no.2 and you have no power outlet near your parking or whatsoever?
    (me baon din ako 150w inverter/CDRKing incase of emergency lan)
    Aug 2012
    Sep 2012
    Quote Originally Posted by bonclem View Post
    Mga sirs bgo lng po ako dto, bale sakto kac yun thread nto skin kya might as well join in pra me input ako from other people.. Bale gnto po yun kwento.. Una I wasn't aware na me push start/stop n pla yun gls model ng asx so when I discovered it it made my decision final to get ASX..An hirap kac mkakuha ng accurate info khit sa website ng mitsu(not updated), ngdealer hopping pko at nginquire sa mga Sales Rep including sa trinoma n me display ng asx pro mukhang di ata cla cgurado sa mga features ng product nila.. Finally I was able to confirm yun features sa citimotors.. then next step is yun color which I preferred which is Q.brown.. Again i did a barrage of inquiries for the color and found a dealer who has one, after confirmation I went on to process my application for bank financing. And the sales agent asked for reservation of 50K because their manager will not procure the unit from the plant with my PO still in process for a 5k reservation only..
    So what the heck, I did my part and paid the 50K reservation expecting the unit at the end of this month.. But guess what, the sales Agent called me and told me that at the time of their inquiry of Q.brown ASX gls 2012 availabilty it was there but days after I paid they say its gone. And I don't know if this is blessing in disguise but they said the 2013 model is coming out by the end of october to november, so they said Its better to wait for it..
    Anyway after 3 days ago another agent from diamond motors that I earlier encountered but has no Q.Brown ASX GLS before confirmed to me that a 2012 ASX gls Brown arrived just this morning.. I was waiting for him to tell me if there would be a 2013 ASX model coming out, but I got a reply about 45mins later.. He then confirmed that yes a 2013 model was coming this late october( imagine they won't divulge this to dispose earlier models first and I also got this info that some agents/dealers would even give a 2011 model and change the year model thru some miracle work thru LTO).
    Now I am confuse whether to wait for the 2013 or get this 2012, by the way Im trapped with the other dealer because of the 50k reservation which I know is refundable but I doubt I can get in 2 weeks time(I know someone who got his refund 5 weeks later for a 5k reservation only).. My budget includes that 50k. Theres no updated price for this 2013 unit yet but the sales agent said it won't be much and he could arrange for the discount to just balanced out from the price of the 2012 model..
    Im getting impatient but seems to be I just have to wait..
    My Agent and dealer was able to pull it off.. i got my 2013 ASX GLS this afternoon.. After telling them I would go with the 2012 model from other dealers and refund my 50k, they were able to confirm that there are units already in customs and that they would definitely do everthing so I could get a 2013 unit.. And with exaggerated patience on my part they were able to secure it in advance even if there system has no pricing available for asx 2013 yet.. I don't know if this is true but they said I was the "FIRST" one to get a 2013 ASX model...
    obvious changes were the front fascad is sleeker, new fog lamps with chrome siding, Power doorside mirror with signal lamps(previously with SE only), additional chrome on side..inside they said the steering wheel control is upgraded and so with the stereo..
    Congrats! pics! pics!
    - - - Updated - - -
    Aug 2005
    Congrats.. :-)
    Aug 2012
    I like the face as it is and I want it to look tough, not sleek. About the fog lamp, heck I don't even use it. I think the 2012 GLS has power mirrors on both sides. Rationalize, rationalize. Hehehe. :D
    About their claim on the steering wheel, it seems like they still don't know what they're selling. They should have told you that you have an upgraded suspension and CVT.
    Congrats and enjoy the ride!
    Sep 2012
    thanks guys!! here's some pics...
    [IMG] ASX 002 by bonclem, on Flickr[/IMG]
    [IMG] ASX 001 by bonclem, on Flickr[/IMG]
    [IMG] ASX 0035 by bonclem, on Flickr[/IMG]
    [IMG] ASX 004 by bonclem, on Flickr[/IMG]
    [IMG] ASX 005 by bonclem, on Flickr[/IMG]
    Just asking, the headunit (stereo) is Mitsubishi OEM or is it still a AVT headunit? I cannot see clearly from the posted pictures.
    The front grill effect looks nice.
2010 Mitsubishi ASX Crossover
