Page 109 of 151 FirstFirst ... 95999105106107108109110111112113119 ... LastLast
Results 2,161 to 2,180 of 3019
    May 2011
    #2161
    Quote Originally Posted by zix888 View Post
    your bling now sticks out at least 23.05mm from the oem. mas lalabas pa siya if your tire is wider. what is the size of the oem, para macompute natin
    phDM oem tires: Dunlop sp sport 270
    215/60/17
    #2162
    Quote Originally Posted by skybison View Post
    215/60/17
    in that case, tires sidewall will be out by 19mm
    (hairline bigger than my mid-finger)
    while back of the tires sticks in by 11mm[if you can put any of your fingers between the tire/shocks spacing(oem)definitely no rubbing issue on the shocks]
    and is just taller 6.65mm(up and down), so sir noels rig is taller 6.65mm.
    (smaller compared to our key blade)
    and if speedo not adjusted by obd, actual speed 100kph, reading is 102kph
    #2163
    Very impormative Zix, thanks.
    Actual lang sukat ko, 10mm-15mm naman sa tantshahan.(smiley)
    If possible, may you share the computation?
    #2164
    Quote Originally Posted by Noel Salisipan View Post
    we will use the tires width , since they wider than the wheels.
    oem tire width is 215mm, while the 19" is 245mm, which is 30mmm wider than the oem( 15mm on each side). if you got an offset same as the oems, which is +46, 15mm lang sana ang ilalabas ng tires, but since mas mababa ang offset by 4mm, i-add mo siya sa 15mm na inilapad ng tires mo, that is 19mm. same is true with the back part of the tires, i-less mo yung 4mm sa 15mm, thats is 11mm.
    sa over all dia naman,
    constant na yung rim dia 19" plus yung thickness ng tires. now yung kapal nung goma is indicated already sa 245 45, this means na yung kapal niya is 45% nung lapad na 245mm. 245x.45=110.25mm . yan ang kapal ng tire, pero when you measure the dia of a wheel/tire, 2 portion ng goma, sa taas and yung nasa bottom, so multiply 110.25x25=220.50mm, i-convert mo sa ", 220.5/25.4= 8.681". add the wheel dia. and this, its 27.681"
    oem is only 27.157"
    their difference is 0.524" also equal to 13.3mm(overall) . di ba hatiin mo sa 2 kasi tire portion is top and bottom, kaya 6.65mm lang actual na itataas ng oto mo.
    #2165
    Ask ko lang sa mga GLS model may nag pa install na ba sa inyo na gawing HID ang headlight? Both low & high beam? OEM ba ang inilagay? Yung talsik ng ilaw katulad ba sa SE na superwide din? Magkano kaya? Kasi 14k ang charge skin ng casa.
    Sent from my GT-P7510 using Tapatalk 2
    May 2011
    #2166
    Quote Originally Posted by rensom View Post
    walang bearing yang upgrade mo if you're eyeing for a "wider" throw. Madaya ang SE kasi me extra bulb sila (below the projectors) specifically aimed sa tabi (for a wider throw). :D
    if you notice mas maliit yun "space" nun projectors to give way sa extra bulb below...
    not like with other variants:
    yun magaling kong SA even suggested basagin ko yun headlights ko - claim sa insurance and palitan daw nila ng pang SE. Hahaha. Lintek na suggestion yan.
    #2167
    Ha? ...... Ang sabi sa akin gagawin daw nila tulad sa Montero.... Dalawa-dalawa. Ewan ko kung yun ang ibig nilang sabihin. Phone inquiry lang naman kasi eh.
    #2168
    oem is only 27.157"
    Thank you very much bro!
    #2169
    welcome sir. meron typo sa 110.25x2=220.5. nway, passion ko kasi sa oto yan, "shoes". very important ang offset.
    May 2011
    #2170
    padagdag naman sa calculation ng speedo correction (+/-) :D tenks!
    #2171
    oem dia 27.157"
    19" overall dia 27.681"
    27.681-27.157= 0.524
    0.524/26.157x100= 1.93%
    meaning, ang correction factor is 1.93%
    if your speedo tells 100kph, it is actually
    100x1.0193=101.93kph
    May 2011
    #2172
    hmmm. I also have a monty but, basically they're just the same naman na projectors on low-beam, hi-beam on 'regular' reflective housing. Kung hid upgrade, probably mas-lalayo sya kesa lalapad ang buga UNLESS they'll have to tweak yun beam 'palabas/wider' throw. (Based on my knowledge on oldskul HL na pwede mo manual adjust on non-motorized-auto-leveling headlights).
    if you ask them to trade-in your stock GLS HLs and replace with SE HLs, magkano kaya?
    #2173
    Sge tol.... ask ko. Thanks
    #2174
    oem dia 27.157"
    Dati, reading ko sa speedo may 5-10kph difference vs gps but now nasa 5kph na lang. But still may difference pa rin sa gps! (wonder)
    Do this need need correction?
    #2175
    oh, okay. activate gps, cruise at exactly 100kph (gps reading). then check what it says there at your speedo. let me know what is that reading. malalaman natin what exact dia your rig needs to give you the exact speedo reading
    May 2011
    #2176
    Slight OT:
    Monty GPS (AVT HU) vs iPad2 GPS
    iPad shows slower by 10kph (stock monty), iv read somewhere sa post ni niky na me bearing din yun chipset na gamit ng GPS (refresh rate)?
    Although not so bigdeal for me, but who's more accurate?
    #2177
    Slight OT:
    sakin naman yung gps reading ng avt is the same with my 4s and 3gs
    Apr 2010
    #2178
    You can change the tire diameter in the ecu. I was able to get a cable to reprogram the ectas in the ecu. Just measure the tire diameter then input it in the ecu.
    May 2011
    #2179
    Quote Originally Posted by big_d_lou View Post
    Care to share further details? What software are you running, cable (obd-usb?), etc?
    I'll be checkin on a OBDII(bluetooth) tomorrow, pair it on my android phone/ipad or laptop. With this, can i check on what you've stated earlier?
    #2180
    Di daw pwde trade-in...bawal daw, ibenta nlang daw sa labas. Ska suggestion skin yung low beam nlang daw palitan pra yung high beam magamit ko raw Kpag umuulan o foggy.. mahihirapan daw ako kung lahat hid? Totoo ba? 7K + yung lowbeam ksama na labor.
2010 Mitsubishi ASX Crossover
