Mga sir ask ko lng, ano kaya ang problema nung pajero ck pag kambyo nya (matic) kahit i shift ay matagal bago kumagat para umatras? Kahit sa "D" ganun din.. mga 5 mins tska pa lng kakagat ung reverse or drive. Tia
Good day to everyone...im planning to buy pajero 3.8 gas..need to ask info regarding fc in city and highway?TIA
The centre LCD on my CK got damaged from the summer heat I think. It is now hard to read as the LCD got "wrinkles." I am wondering where I can get a replacement part for this or if there is anything I can purchase to just replace it totally.
What is basically the difference between a local BK and the one from Dubai aside from the moon roof and some aesthetic additions? Are the parts the same, so maintenance can be done in our local dealerships? Thanks
I've reached 79k so along with a lot of other maintenance things, I had my transmission checked. Apparently my transmission support is almost worn out. I also had my ATF changed.
ATF fluid for the Pajero requires SP3 which is very different from Dexron 3.
Old and new transmission supports.
Old dirty ATF tray with the magnets covered in sludge. The magnets double in size through the years as it collected the fine metal particles.
ATF tray after cleaning.
Interestingly enough, the ATF filter on the newer Pajero is very different from the filter on the FM. When I had my FM's filter changed, it looked like a sieve. On this one, the filter looked like rough-cut foam like scotch-brite.
How much inabot parts ? 62k Kms palang saakin but every 20k nag flushing ako ng tranny. Is this bk or ck?
Sent from my SM-G9287C using Tapatalk
Roughly 12k. My CK is a petrol one with the 6G75 so the used oil was still not black when I had the transmission opened up.
My problem is still the LCD display. I got shown a coloured one which was perfect for me but it was malfunctioning due to moisture from being exposed. Here's my current fried LCD display:
Any leads to where I can get a replacement would be highly appreciated.
Boybi, hehe bihira lang talaga Sunday car ko nalang siya. Last pajero model na to. Kailangan ko na mag move on sa iba. Wala nang aabangan na new pajero model.#pajfanboi
Kill, thanks sa info.medyo malambot narin tranny support ko. Paghahandaan ko na yan. Yung lcd parang may nakita ako sa eBay pero sa US ang location. Will let you know pag makita ko pa. Have you tried sa casa kung how much yung assembly?
Check out this item I found on eBay:
http://pages.ebay.com/motors/link/?n...801910&alt=web
http://pages.ebay.com/motors/link/?n...650713&alt=web
Mga bro. Yung Pam belt ko nag squeak at low rpm sign na Kaya na pa sira na? 20k palang o 2 yrs na. Thanks
Yung nabili ko sa casa na oem fan belt dati nagkaproblema din ako na humahaba. Hanggang sa umabot sa Sagad na adjustment yung ac belt ko. Kaya di na ko bumili ng oem mitsuboshi. Gates nalang pinalit ko. Di na kailangan ng Re adjust. Tama lang 40k Kms palit. For me every 50k ako nagpapalit.
