Page 45 of 47 FirstFirst ... 3541424344454647 LastLast
Results 881 to 900 of 921
    Yung nabili ko sa casa na oem fan belt dati nagkaproblema din ako na humahaba. Hanggang sa umabot sa Sagad na adjustment yung ac belt ko. Kaya di na ko bumili ng oem mitsuboshi. Gates nalang pinalit ko. Di na kailangan ng Re adjust. Tama lang 40k Kms palit. For me every 50k ako nagpapalit.
    Sent from my SM-G9287C using Tapatalk
    Hehe gates din gamit ko. Si BG gumagamit din niyan afaik. Maganda nga yan basta orig. May fakes din afaik.
    #882
    Gates talaga hanap ko last time ... lasa sabi ng autosupply china na daw .. kya Mitsuboshi V-belt na lang binili ko ..
    1st gamet ko ng mitsuboshi for a week lumuwag so adjust after nun ok na till now
    Nov 2015
    #883
    tanong lang sa pajero experts, since ididiscontinue na ang pajero, pag bumili ako nito, hindi ba ako mahihirapan sa parts nyan next time? baka maski sa mitsu casa subject for importation na mga parts, o baka sa japan pa mismo d narin mag manufacure ng spare parts.
    #884
    Quote Originally Posted by supersam View Post
    There's plenty of parts out there. China has also started making parts for the Pajero so I don't think supply would be a problem for the next 10 years.
    Nov 2015
    #885
    mahal ba pms ng pajero compared sa montero?
    #886
    Not really. Mine does guzzle fuel but then mine has the 6G75 which is a 3.8 V6 engine. The engine oil I use is Petron Ultron Rallye which isn't expensive since it's only a semi-synthetic. Oil filter is only 450 each. I change every 5k. ATF was changed for the first time after 80k. Replacement brakes are only 2K for front and back discs. Air filter only needs to be changed every 10K or if you live in the province, 15K since the air is cleaner there. Common problems I've heard from other users are:
    A. Brake issues
    B. Transmission issues
    I know a number of owners who have blanked their 4M41s. (I feel lucky that my 4M40 doesn't have an EGR) 4M41 owners just change their oil more often.
    FM users have it even better in my opinion.
    #887
    I parked over at the MOA area last week and had my fender light stolen. Apparently, thieves now like to use something with a sharp edge like a screwdriver to pry this off the CK's / BK's body. I had to get a replacement pronto since it left a hole on my fender.
    For those who get theirs stolen, part number is:
    #888
    Quote Originally Posted by K.I.L.L. View Post
    that looks like my old lancer's side light..
    if i were the warehouse head, i'd say it was a good move on mitsu's part.. multiple uses for the same item.
    Mar 2012
    #889
    Kill,both fender lights were stolen? sa loob ka mismo ng MOA naka park nung nanakaw?
    #890
    just imagine this, old paj like the fieldmasters were long way discontinued,,,but still parts are available even at your suking tindahan.
    #891
    Just want to hear some inputs, guys.
    Since generally the same naman ang body & platform ng BK at CK na Pajero (except for the front and rear fascia), is it possible kaya to do a swap of their front fascias, say a BK pajero convert to a CK look? TIA.
    Btw, I have a follow-up question regarding the PMS of the pajero. Is the 1st PMS of this rig around 1k kms or is it 5k kms instead? Nearing na kasi ang 1st month ng 4m41 ng dad ko.
    Feb 2012
    #892
    Hi mga sir need help with my brandnew pajero i have annoying rattles sa dashboard right side been with casa but they couldnt figure it out where it was coming from i need help from u guys who knows the ins and outs of pajero its very fraustrating tnx
    Mar 2003
    #893
    glove compartment yan. ipitan mo muna ng basahan bago mo isara. then drive konti. Kung mawawala.
    Feb 2012
    #894
    I did it already still has avibrating sound seems like coming from the inside of the dash between the windshield and the dash but when pressing the dash and the windshield it still has the annoying sound casa told me to wait for their call they already forwarded it to the mitsubishi plant but still whenever i use the carbit fraustrates me knowing the car is brandnew hope anyone from the forum can help me with it tnx
    Apr 2010
    #895
    Quote Originally Posted by sherwinsaquing View Post
    Noticed the rattling sound too on my 2016 BK. I thought it was coming from the glove compartment at first. I tried removing all the coins and other stuff in the middle console and the sound was gone. hope this helps.
    Feb 2006
    #896
    Calling all BK experts here.
    Does anyone know the specs of the HID for the factory installed locally sold Mit Pajero 2012 Diesel Variant? Model of the HID and the voltage?
    Im planning to upgrade the HID bulb only without changing the ballast anymore.
    Thanks for chiming in.
    #897
    Quote Originally Posted by flickserve View Post
    55W D2S is the default spec for almost all HID bulbs across all brands. You can verify with your owner's manual as well since it's listed there.
    Feb 2006
    #898
    Thanks for replying.
    Jan 2010
    #899
    Hi guys. Planning on buying a 2nd hand Pajero BK (2012) over a brand new Montero. Am I making the right decision? [emoji5][emoji45]
    If I go for the 2nd hand Pajero, may I ask for tips that I should look at to assess condition? The usual pa lang is what I did: checked for oil leaks, electronic components like power seats, power mirrors, locks, airconditioning, rusting under the seats (in case na baha), no fogging sa lights. One unit I'm looking at is around 60k mileage already. Thanks!
    Mar 2003
    #900
    so far ang nasira ko palang sa bk ko sa 10 years ownership are map sensor and scv.
2007 Mitsubishi Pajero (GEN III.5) [continued]
