Page 43 of 47 FirstFirst ... 33394041424344454647 LastLast
Results 841 to 860 of 921
    Nov 2014
    #841
    Quote Originally Posted by babynos01 View Post
    I think the creaking sound at D to R and vice versa is dahil sa rotation ng prop shaft. May play kasi yun before mag contact sa differential. I think its normal. Try mo sir D to N tapos balik uli sa D if mag creak pa siya.
    HTH
    tnx sir, i'll try to do this later when i drive.. i didnt notice this kc mashado ako nakatutok dun sa D to R and vice versa e.. will update you guys later.. pag D to N and vice versa walang ginawang creaking sound, ibig ba sabihin ung D to R and vice versa ko is just normal at wala akong dapat problemahin na regarding sa transmission ko?
    ung sa clanking sound sir, may suggestion ka ba dun? d ko makita kung anu ung cause e..
    thanks sir..
    Sep 2011
    #842
    Yung sa MS kasi namin, i noticed that the creak sound is produced kapag umikot yung prop shaft before magcontact sa differential. Happens when R to D and VV. Faint lang yung creak sound sa amin.
    I think its normal naman. Pero mas maganda if may opinion pa ng iba.
    But if malakas yung thug sound and creak sound nung sa inyo sir, pacheck nalang.
    Does it only happen kapag naka stop yung car?
    Nov 2014
    #843
    tried what you said sir, it only happens when doing D to R and vice versa, pero pag nasa N to D or R naman wala, unless pag naglalaro ung rpm during idle.. sa other A/T cars kc namin parang walang ganun.. and before parang d naman ganun ung BK, kaya parang nagulat ako na may ganun bgla, mejo parang malakas dn kc sha for me e..
    Last edited by orbital; February 26th, 2015 at 09:10 PM. Reason: additional information
    Nov 2014
    #844
    guys, i have new problems.. normal b na nagrereset mag isa ang FC ko sa display? ngaun kc bgla sha nag reset out of nowhere tuwing umaga.. then pag nangyayari un, i have a hard time starting.. could this just be a battery issue or something else? kc when i have a hard time starting, i hear clicking sounds..
    Mar 2003
    #845
    How about your clock nagrereset din?
    Nov 2014
    #846
    sir PB, ung clock parang d naman nagrereset, check ko ulit later pag byahe ko.. pero IIRC, FC lang sir.. starter issue? mejo matanda na dn tong BK e, 07 model 140k mileage..
    Nov 2014
    #847
    sir PB, FC lang ang nagrereset, ung clock, date and radio, ndi naman nagrereset.. u might know the cause?
    Mar 2003
    #848
    Orbital, same lang tayo matanda na pajero . 07 din akin. ang naiisip ko lang Baka naka manual yung settings ng FC meter. With hard staring petrol ata engine mo. Di ako familiar.
    Nov 2014
    #849
    papacheck ko nlng dn ung sa hard starting pag pinasok ko sa casa together dun sa iba kong problems like clanking sound underneath, tug sound sa pag shift and ung sa transmission na parang nabababad sa 1st gear.. naka manual? manual and reset lang naman ung sa FC sir PB d b? meron b ako dapat ayucn dun para d na sha nagrereset everytime i start the car? ang hirap kc icompare nung FT to FT method na manual at through the computer.. lam m naman pag petrol, mejo malakas sa gas, hehehe..
    #850
    boss, san makakabili ng mags na toh? 22"
    Sep 2011
    #851
    Sir orbital, pa update kami regarding sa observation ng casa dun sa clunking underneath ah.
    Nov 2014
    #852
    had my car done, both suspension arms front, stabilizer links sa back plus bushings and shocks.. and the clanking sound is gone.. mejo mahal inabot, nag-source out lang kami ng kabarkada kong mechanic ng parts, nagbayad nlng kmi ng labor.. naka 40k din ako.. though ung sa shocks remejo palang, but will replace it once nakahanap kami hayaba for rear, front palang nakuha namin e..
    Nov 2014
    #853
    *extremeride69
    triton rims? wala ako alam dito sa pinas na meron.. if you're willing, pwede ka paship from other country.. alam ko alibaba may mga nagbebenta nyan..
    Mar 2003
    #854
    Orbital, pa post naman ng prices sa suspension mo kung pwede
    Nov 2014
    #855
    cge sir PB, post ko maya maya ha.. nasa kotse ung resibo e.. pero lahat orig parts.. sa shocks lang ako mag hayaba..
    Sep 2011
    #856
    Ano daw cause ng clunking sound sir?
    #857
    Quote Originally Posted by extremeride69 View Post
    Le Mans III wheels ata yan sir, not sure if this can be bought brand new locally.
    I'm also interested to get one if may makukunan locally, but 20" lang.
    Nov 2014
    #858
    bushings sa shocks caused the clanking sounds.. but kaya nasira bushing ko is because d na naglalaro ng maayos stabilizers ko which also cause the other parts to weaken so had to replace..
    replaced the ff:
    suspension arms front x2 - 14000
    tie rod bar x2 - 1600
    tie rod end x2 - 1500
    stabilizer link+clamp+bushing x4 - 12000
    steering boots x2 - 500
    then labor pa..
    to be replaced but parts already bought:
    shocks for front kayaba x2 - 3800
    still looking for rear hayaba shocks, meron oem replacement *4500 each pero sabi ng tropa kayaba nlng daw kabit namin, mas mura at mas ok kesa replacement part..
    Mar 2003
    #859
    Orbital, thanks sa prices. Ang mahal pala. Pina check ko din suspension ko. Free sa casa 15 point check up. Upper balljoint naman daw saakin. 800 each daw. I'm guessing yung suspension arms mo kasama narin balljoint?
    Nov 2014
    #860
    yes sir PB, kasama na.. buo na sha.. d rin kc adviceable na ndi buo palitan kc papalyahin dn nya un katagalan thats why binuo namin.. shocks nalang kailangan ko palitan.. then tska ko nlng palitan mga springs ko since ok na ok pa naman.. d naman palitin parts natin since our car was made for rough terrains.. mataas lang na tlga nabyahe ko at mejo bara bara kc ako magdrive thats why nagkaganun.. sa 350z ko lang ata ako naging maingat sa pagddrive dhl sa mababa mashado e, hahaha!
2007 Mitsubishi Pajero (GEN III.5) [continued]
