Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 164
    Sep 2006
    #41
    matrabaho pag scraped completely ang paint. tama si gongrhey, yung may bubbles lang. baka di rin sila umabot sa deadline mo pag ganun.
    Jul 2013
    #42
    anyone who can recommend a shop that customizes kitchen sinks?
    ayoko na sana palitna yung counter top namin... pero wala akong makitang sink na same size sa lumang sink
    #43
    Don't just replace the sink, redo the install, if you can. Go undermount like the 1st pic. Seals won't last. Or go integral w/ SS top...the ultimate vs. abuse... for those who lease out their units.
    Look for custom SS fabricators(local to you) who cater to the food industry.
    Jul 2013
    #44
    Bayad na si contractor... having the granite replaced will add 100K to my bill (Quartz counter top + new sink)
    So I'm trying to push the cost down by not having to replace the counter top.
    *Quartz is around 20K/slab
    Jan 2016
    #45
    Marami ako nababasa dati sa FB na gumagawa ng stainless things, or maybe you can buy a slightly bigger sink para cut ka na lang sa counter mo, much better nga if undermount.
    Jul 2013
    #46
    honestly, di ako masaya sa undermount, hirap kasi palitan ynug silicon kapag nag molds na (nasa ilalim kasi)
    nag message na ako sa mga stainless shops sa FB and Lazada/Shopee... kaso wala pang sumasagot, halos 1 week na.
    may drain tray kasi yung sink namin... so medyo malaki compared sa mga nasa market.
    Jan 2016
    #47
    Silicon? Wala ung sa amin, sinilip ko tuloy, malinis naman, 6 months na naming gamit.img_20210429_162739.jpgimg_20210429_163035.jpg
    Sent from my Mi A1 using Tsikot Forums mobile app
    Jul 2013
    #48
    yup... yung gap ng sink and countertop... palagi kong issue yan noon. pero every 2 years ko linilinis (tanggal silicon tapos palit), di naman every year.
    Anyway, as I said, looking for a solution to save the current countertop... sana may mag reply sa mga pinadalhan ko ng message.
    #49
    Have you tried the usual Wilcon/CW Home Depot/MC Home Depot?
    Sent from my SM-G960F using Tsikot Forums mobile app
    Jul 2013
    #50
    yes... will go to another place this weekend sa Pasig naman
    Mar 2021
    #51
    Lakihan mo na lang yung sink para malayo sa edge ng countertop. Hindi mo na makikita yung silicon sa edge hehe
    #52
    Use polyurethane, not silicone...& don't apply superficially after the sink & the top are joined. Undermount PU seals are applied generously between mating surfaces prior to top installs. Like sir Papi's below, you're best having nothing visible there, no gaps...or could be a case of poor seating or not quite level top alignment...common execution or material flaws.
    Anyway, over-under conversions are still very doable. Just gotta find the right sink.
    Good luck, sir. Apologies to have been of no help.
    Jan 2016
    #53
    Sir Travs, actually there is a gap of about 1 mm, I didn't know it was supposed to be sealed, I guess the contractor skipped that to save some money, but then, maybe it's the gap that prevents mold formation since it somehow gets some aeration. Guess I'll check after a year.
    #54
    There likely is a seal sitting between to keep water from straying into the gap & seeping thru the top's substrate.
    Jul 2013
    #55
    Found 2 options na...
    1. A Chinese Manufacturer gave me a link to a custom designed sink (with the dimensions I need) in Alibaba. They'll create the sink once I hit "buy" - sa dami kong email at text sa "local manufacturers" I find it disappointing na ni isang local manufacturer di sumagot.
    2. Thanks to Facebook's targeted ads - I saw a sink na 10cm lang diff sa butas. will visit the shop this weekend.
    #56
    speaking about sinks,
    does anyone know where i can get the old-style porcelain-ed sinks of olde?
    yung malapad dahil may landing strip on both left and right of the sink bowl...
    #57
    Even those farmhouse sinks are re-imagined undermount now, doc. Just less of a headache in upkeep. Kohler has em.
    #58
    nice, but...
    'yokoh.
    'too many sharp angles', and no proper drainage for the left and right landing strips.
    it reminds me of the workplace sink. palaging basa yung kanan at kaliwa ng sink...
    our northern hill porcelain sink is starting to rust at the edges, kasi...
    highs.
    #59
    Make sure to specify SS 304 grade, sir.
    And if you want mould resistant sealants, go for neutral cure CO-POLYMER, not regular silicone. They're locally available.
    Way before undermounts were available, been underlaying over-mount sinks like this very old 1 that has never yet to see any repair.🤞
    There really leaves no reason to go over. Under is just better.
    May 2007
    #60
    Sir, try JCSI Stainless - meron sila shop at sumasagot naman sila sa FB msgr.
House Renovation
