Page 10 of 71 FirstFirst ... 678910111213142060 ... LastLast
Results 181 to 200 of 1411
    #181
    van
    what is the pros and cons of the following roof
    shignles
    tegula
    long span
    in our village marami akong nakikitang naka shingles and it looks cool lalo na sa combination na color dark brown and pastel brown ng house but does it dissipates heat more compare to others and what about its maintenance?
    thanks
    Jul 2005
    #182
    Quote Originally Posted by van_wilder View Post
    Pagibig gives application form and before that they would brief on the procedures, then they will give you the requirements. But still you will be needing 30% equity on the cost of the house construction
    pasingit na rin po.
    so ibig po sabihin, if you're targetting a 2M house construction loan, you will need to have 600K on hand to avail of the said Pag-Ibig loan? tama po ba?
    Jul 2005
    #183
    per square meter... not a dumb question... actually a good one, kasi walang nag-indicate kung ano nga naman yun 15-20k... at least na-clarify...
    yup kasama na sa amin yun plans and permits... unless meron ka na, irevise namin ng onti para masmaayos implementation, kasama na labor and materials doon sa 15-20k...
    hindi naman ako siguro mawawala dito...
    info*webuildpacific.com or paolo.cristobal*webuildpacific.com
    15-20K is for the total floor area regardless kung 2 or 3 floors house mo? how about the roofdeck, paano computation nun to the overall cost?
    sa waterproofing may choices ka... critical ito since madalas ito nagiging problema ng roofdeck...
    first of all, pinakaimportante, dapat READYMIX CONCRETE ANG BUHOS, AT ISANG BUHUSAN LANG... hindi pwede putol putol, dapat monolithic yun roofdeck para walang tagas talaga sa concrete, then waterproofing:
    a. sahara
    b. mortar seal
    c. rubberized asphalt
    kami we have experience both with and A and B, but we suggest C - rubberized asphalt, kasi yun dalawa kung hindi magaling yun naglagay yari na... sa rubberized asphalt dapat maayos yun pagkagawa...
    yong mga projects nyo na with roofdecks, any problems so far? tatagal ba na walang tagas yong roofdeck in the years to come given na maayos pagkakagawa as you described? our plan kasi is to have a roofdeck instead of the usual conventional roofing lang. (housing loan na lang kailangan, lot is already ours)
    this is similar to those new houses malapit sa Filinvest 2 sa QC na may roofdecks, which makes me think kung may problema ba mga yon...those houses, btw, are constructed by Filinvest inhouse construction daw.
    Apr 2004
    #184
    i will answer your questions... medyo busy lang... anyway visit www.webuildpacific.com for some references and samples of our projects...
    Jul 2005
    #185
    Quote Originally Posted by ozcity View Post
    this is 10k/sq 2flrs with roof deck 100sq lot area
    ozcity, pa post naman ulit ng pic ng bahay niyo. parang ang galing kasi na ang daming levels on a 100 sqm lot area.
    Apr 2004
    #186
    although we do shingles, we recommend cpac monier (its lighter) roof tiles since mas less heat yun compared to shingles, shingles pa nilulumot...
    wala kaming tagas sa roofdeck, we are doing 2 buildings right now na nakaroofdeck, okay yun isa, yun isa hindi pa nabubuhusan...
    #187
    About flooring sa ground floor. Maglalagay sana ako ng granite pero medyo mahal talaga ang italy processed granites. Wag kayo magkakamali sa Bengco granites. Ang hirap nila kausap. Any other tips sa finishings?
    matagal ba magpapapalit ng window casing to aluminum sliding?
    #189
    shadow, depende yan sa pagbaklas ng window casing...usually titibagin yan di ba? so may retouch pa yan yung drying time ng semento ang matagal diyan...
    yung alu sliding madali lang ikabit yan...
    Aug 2004
    #190
    dito ko na lang i-post ito...
    mag-ingat po tayo sa pagbili ng semento. buy only from reputable shops..
    napanood ko sa imbestigador last saturday, yung mga semento hinahaluan ng apog para dumami.. yung 10 bags nagagawa nila 20-25pcs sabi ng isang trabahador.. pati yung mga shops na dinalahan nila, todo tanggi na di daw sila kumukuha ng ganun pero huli sa camera..
    Jul 2003
    #191
    naku, pano malalaman pag hinaluan yung semento?
    Aug 2006
    #192
    Quote Originally Posted by igorbaby View Post
    Hi To all Tsikot Members,
    Ayoko na magpaliguy-paligoy pa, but for all your House construction needs, I am highly recommending van_wilder as your contractor. He just finished my house last April, they finished everything on time while I am working here in abroad. I mean, they did everything sa gusto ko and all of my family are happy to the outcome of our house.
    raikonen,
    Try to contact van_wilder for your house construction, hindi ka magsisisi for every cents na gagastusin mo. They are very Professional, Honest & Humble contractor. Actually, pangatlo sila sa contractor na nakausap ko, at sila ang maayos kausap. If you have a design na gusto mo, have the budget, talk to van_wilder first, if you want you can visit my house na ginawa ni van_wilder.
    Hope I can help!!
    Thanks,
    igorbaby
    PICTURES PLS!!!
    Feb 2006
    #193
    Sir, Van, totoo bang mas malamig ang loob ng bahay pag ganitong technology ang gagamitin (walls w/ styrofoam in between concrete)? Kasi ganito ang "sales pitch" nung taga Megaworld sa mga housing projects nila.
    This is true and i can prove from my experience in Bahrain. Most of buildings ive seen and stayed for a year were constructed using blocks with styrofoam in between not hollow. Just imagine an outside temperature of 45 deg C at kung nasa loob ka ng bahay ay parang shade temp lang (di pa bukas ang aircon). Pero ang rooftop ay floor slab.
    Feb 2006
    #194
    Sir Van,
    May warranty ka ba sa defective works and bad quality? Babalik ba kayo kapag maraming diperensya nakita after less than a year completion?
    #195
    Quote Originally Posted by falalofasion View Post
    PICTURES PLS!!!
    pictures will say it all.
    ako ang una kong tinitingnan sa bahay ay ang mga kanto at lahat ng sulok ng walls, kelangan nasa "hulog" at derechong-derecho ang plastering.
    Jul 2003
    #196
    Quote Originally Posted by 109 View Post
    click nyo link below eto pic ng gawa nila van.
    http://www.webuildpacific.com/projects.htm
    http://www.webuildpacific.com/designs.htm
    Feb 2005
    #197
    109,
    Dati hindi ko alam ang mga ganyan about sa corners ng mga walls & post na dapat buhay daw ang mga kanto at hindi pabilog, ang nagturo pa sa akin nyan ay ang Foreman ni van_wilder, at sabi pa nya kapag hindi daw talaga nasa hulog or derecho, dinadaya ng ibang gumagawa at ginagawang pabilog.
    igorbaby
    #198
    Hello,
    What is a good brand for a water pump ?
    I'm building my house and my storage tank is cistern-type ( underground) so I want my water to reach to my attic ( 3rd floor ) bath room....
    In your experience... a good brand - quality and reliability-wise, what can you recommend ?
    Thanks!
    #199
    igorbaby,
    nice work on ur house. more pics
    gambit5,
    try pedrollo pumps, probably the best italian pumps in the market
    subok ko na.
    #200
    Mariwasa has a tiles that aparrently rejects or kills germs.
    12x12 size is around 36-37 pesoses
House Constuction [Merged]
