Page 8 of 71 FirstFirst ... 4567891011121858 ... LastLast
Results 141 to 160 of 1411
    #141
    Quote Originally Posted by van_wilder View Post
    we use bradnams... masmahal siya kasi imported pero kapag kinompare mo ang layo ng difference...
    hindi kaya sa buhos ng roofdeck ang problema?
    abc/mortabond/wallright pala yung grout combi para sa tiles, my bad. pwede na ba ito to eliminate the roof deck seepage problem ser Van_Wilder?
    Apr 2004
    #142
    grout? hindi...
    #143
    grout? hindi...
    ano ba ang the best para sa tiles, doubled para waterproofing? nakabili na kasi ako ng tiles.
    Apr 2004
    #144
    walang subsitute sa waterproofing... grout kailangan yun para sa tiles, separate pa ang water proofing...
    Jun 2006
    #145
    sir VW,
    questionstupid one)
    di ba architech talaga yung mga nagdedesign ng bahay/buildings? iba pa ung mga engineers? civil engineers ba ang tayag sa kanila o ano.
    #146
    hmmmm... thanks bro, plan to put up a shed if my tiles will not work. guess the seepage comes from the wall joints coz' no trace of cracks are sighted.
    Apr 2004
    #147
    Quote Originally Posted by cyrusblutrooper View Post
    sir VW,
    questionstupid one)
    yup... iba pa... civil/structural engineers... architects are the ones in charge of the aesthetic design, engineers are the ones who check the structural feasibility and design...
    #148
    hindi siya plastic... rubber yun... yun yung rubberized asphalt...
    Plastic talaga yung nailagay nila aside pa don sa rubberized asphalt..hindi ko lang alam kung alin ang nauna..layer
    Jun 2006
    #149
    thanks po sir VW, kaya pala yung architech kung ka kilala nag papapirma ng kanyang design sa engineer, ok maliwanag na thanks ulit.
    Mar 2005
    #150
    pero pag housing and buildings (up to 4th Storey) puede na ang architect from structural analysis to architectural design
    Sep 2004
    #151
    yan din ang worry ko sa roofdeck. kung monolithic, most likely sa joints lang galing seepage. siguro dapat lagyan ng waterstop sa construction joints bago buhusan.
    May 2005
    #152
    Quote Originally Posted by NightRock View Post
    sir VW ,tama si Sir Nightrock,plastic nga po ang gamit nakaroll pa nga nakakita din ako nito sa ME na mga ginagawa na bahay
    may nakikita din ako gumagamit sila ng styro foam para sa wall
    ano naman po ang function nito
    Jul 2003
    #153
    pag may gagawa ng bahay sa bandang cebu baka makatulong kami ha... we sell finishing products, kadalasan ung mga wood and other interior materials ng bahay... just contact us through our landline, pwede ipasite visit. ;)
    Aug 2004
    #154
    Quote Originally Posted by ozcity View Post
    yung sa akin inabot lang ng 10k
    post ko pic later..
    sobra mura nito ah...
    post mo naman pics.. sir..
    #155
    Quote Originally Posted by raikonen View Post
    this is 10k/sq 2flrs with roof deck 100sq lot area
    #156
    2 x sqm/floor lang ba, di ba kasali ang computation sa roof deck mo?
    #157
    Quote Originally Posted by BoEinG_747 View Post
    Not sure if you are referring to the styro foam as water proofing.
    But, we used styro foam in our place as moldings sa wall ng bahay vs. cement. Mas perfect ang cuts ng pre-fabricated styro foam (with cement reinforcement yata), so mas maganda....
    Apr 2004
    #158
    yup ganun nga... basta kapag moldings masmaganda ang pre-fabricated... with or without styrofoam... yun iba gumagamit ng styrofoam pero hindi gumagmit ng hollow-blocks... iba yun methodology nun construction... marami kasing methodology pero economical ang ibang methodology kung townhouse, condo, etc yun paulit-ulit...
    #159
    technically 3 flrs yan...basement,1st, then 2ndflr, then roof deck
    #160
    van wilder, okay ba ang gypsum board para sa ceiling instead of the usual plywood? asar kasi mga anay sa lugar namin, pag gypsum board hindi ka gagamit ng mga kahoy para sa ceiling joist. nagtatagal ba yun, say 10years or 15years? ano karaniwan nagiging problema sa gypsum board? hindi ba humihiwalay yung dugtungan pag nagtagal?
    tnx sa mga suggestions mo.
House Constuction [Merged]
