Page 42 of 71 FirstFirst ... 3238394041424344454652 ... LastLast
Results 821 to 840 of 1411
    #821
    Do you mean, to use 4 lengths for bottom chord?
    Basic angle bar truss section.
    Jan 2016
    #822
    Quote Originally Posted by maxpedition View Post
    Back to back. I think for 9 meters you can use 3 lengths x 6.0m
    Yes Sir Max, the design was back to back for all chords and webs, am I correct to say that you were thinking back to back for bottom chord only and single bars for top chord and webbings. Sorry, I'm just clarifying sir. I thought the interpretation of 2 lengths is back to back.
    Jan 2016
    #823
    Wow, may steel plate pala ito, I thought it was simply full weld directly on all contact points. This type of connection was conveyed to me by another contractor, as he said, nasusunog daw Ang bars pag direct.
    #824
    For small spans like yours, you may do this..
    Some use cut I-beams or wide flanges for the T section of the top & bottom chords. You may wanna check availability & costs, sir. Also, scissors, designed well, remove the horizontal stress vectors & will have lesser tendency to deflect/sag..thus, may do w/ reduced sections.
    Jan 2016
    #825
    That looks like a T bar Sir, could be a faster alternative for the chords if they have the equivalent size of two angle bars joined
    #826
    Or an I-beam/wide flange section cut along the middle to get 2 Ts.[emoji4]
    Jan 2016
    #827
    Here's my truss details, that RT-5 is supposed to join the trusses together, is that necessary given the trusses are secured by purlins? Or maybe not that whole detail but just a long angle bar running end to end to hold them together?
    https://i.postimg.cc/brKmdWRQ/Roof-Truss-Diagram.png
    #828
    Test upload
    I can't upload my truss plan pic
    There are many ways to skin a cat, sir.[emoji4] Here's another...
    Nov 2017
    #829
    Test upload
    Your design indicate 2L x 2.5x2.5x 6mm same as travs detail. You just follow your design and since you downgrade your angle bar size better look for standard thickness.
    Jan 2016
    #830
    Thank you very much Sir Travs and Sir Max!
    ito yung sinasabi ko inuuna yung aesthetic kaysa functionality.
    sa mga senior bihira yung mababalita na namatay dahil nadulas sa comfort room. Usually heart attack. Nahihiya sabihin yung tunay pangyayari.
    Ito yung dati ko pa reklamo sa mga architect/interior designer. Bakit magkakabit ng tiles sa C.R na pwede ka na magsalamin sa kinis/kintab. Ano ba purpose pag gumawa ng bahay eh inagas yung tiles sa bisita? Paano kung nadulas?
    Be functional. Dapat may purpose yung gagawin wag puro mata.
    #833
    Isa kasi sa symptom yan parang sumasakit ang tyan, kaya madami sa banyo inaabutan. But I agree, ayoko din ng bathroom na parang salamin sa kinis at kintab ang tiles
    Jan 2016
    #834
    What's the best kind of tile na pwede ilagay sa T&B? We have the kind na medyo rough, pero pag tamad ka maglinis, nagkakaron ng dirt stains, I also tried the makinis ones para di madali kapitan ng stains, madulas nga talaga ang problema.
    yung puti na madami maliliit na bukol-bukol na bato-bato yung parang sa mga beach house na ginagamit na steps sa hindi cementado lupa. Usually alam ko puro dark yun pero parang may white din.
    meron pa other purpose yan kasi pag naliligo you can scrub your foot ang linis pink na pink ilalim paa.
    Sep 2010
    #836
    Well there are different kinds of tiles. The polished glossy finish (which are usually used for walls), the matt finish & the textured finish.
    You could just use the matt finish for the floor. The textured ones would ofcourse have more grip than the matt one, but would need more effort to be cleaned.
    Sep 2010
    #837
    You mean wash out?
    #838
    wash out.
    old style na yan, libag magnet yan sa CR. ginagamit yan ng contractor na nag-aapura at nagtitipid. hinahalo lang sa semento latag na.
    ginagamit din sa mga nitso
    dami modelong vinyl tiles na pang TB - di madulas.
    Jan 2016
    #839
    Pang garage yan Boss XTO [emoji3]
    Sa vinyl kasi hinid makalinis ng paa. Maganda pa din bato tapos may gaspang na nakaumbok,. May nakita ako sa wilcon na makabago na din.
    washout ba tawag sa sinabi ko. Yun lang talaga effort linisin yan.
    Hindi pa ako pinapanganak ganito na. Nung bata ako pag naliligo kaskas ko talaga paa ko jan and super bilis malinis agad. Kung sa kamay ang tagaaal napagod na ako kaka-kaskas hindi pa malinis.
House Constuction [Merged]
