Pools & watertanks are a different story. The concrete isn't subjected to dehydration & thermal contraction/expansion from exposure to the elements. Failure on these structures are more from improper execution & seismic disturbances than the factors that affect firewalls & suspended open decks.
Naalala ko si Shadow nung makita ko ito. I think he was asking for a filler in between tiles na maliit ang space
https://shp.ee/rtdwatj
For residential build, how much would be the difference in per square meter cost between:
Bungalow
2-storey
3-storey
This will help determine whether to get more land and build a bungalow or a 2-storey on a smaller lot ... say the difference is 10T per square meter ... so it would be better to get a 1000 square meter and build bungalow house rather than 2-storey on 500 square meter lot ...
Way more variables than just levels. Terrain, design, specs, roof type, wall & window volume are amongst those that significantly influence construction cost.
personally,
i would get the biggest plot that i am willing to afford.
the house plans come secondary.
i can always adjust my house plans, but there is a good chance, once i get neighbors, i can not make my land expand.
Same...but the smallest house.[emoji4]
Haha...none taken, sir.[emoji120][emoji4]
Here's my non professional take.. Average contractor quote in my location for a standard spec 2 storey build is 30k/sqm of which 30% is labor cost . I would guess that it's safe to assume a modest reduction of 10% on labor plus deduct the cost of materials to support a 2nd floor slab. These basic support materials do not cost much relative to total material costs. So labor of 10k less 10% is 1k plus saving on materials say 3% of 20k or 600 = 1,600 less per sqm. Going with higher cost finishing materials will probably even out this small cost as there is small difference between installing a 10k and 50k water closet for example. In short, negligible toni cost difference between single and 2 storey houses. What say you Sir Travs? [emoji16]
For the same area, sprawling roof cost, esp w/ clay option, can shoot up the expense significantly to offset the added structural requirements of suspended slabs. Then, there's the likelihood of greater wall+roof beam perimeter/volume....this could swing the comparison in favor of a boxy multi-storey.
That said, one can never take for granted the architectural side of things. The gap between a good, experienced 1 who focuses on function, cost over form vs 1 that 'just designs' can be wide.
Just too many factors to generalize the comparison. Apologies if this won't satisfy the inquiry. It's not as simple as one would like to think.
Read somewhere that a bungalow will save 10T per square meter over a 2-storey ...
How about a 2-storey vs 3-storey ...
If you get an interior designer to do all the vanity, cabinets, kitchens, lightings and others aesthetics of the house . . It will add up to additional 25% ++ of your cost per sqm.
