Page 7 of 41 FirstFirst ... 3456789101117 ... LastLast
Results 121 to 140 of 809
    #121
    Pics wont do it justice.I need a drone video to show it LOL.
    Sige will take pics..... i know theres karaoke event there soon...
    The hardwood interior was amazing. He used 12 different kinds of hardwood for the floors, doors, ceilings etc.
    I did ask how much it cost.... 82 million for the house construction alone without furniture and excluding the land price.
    Crazy hehehe. But damn!!!!
    $82M?
    Probably just a drop in the bucket for your friend, bro. ... 😉😊😊
    Wow! Awesome!
    Mar 2013
    #122
    $82M?
    Probably just a drop in the bucket for your friend, bro. ... [emoji6][emoji4][emoji4]
    Wow! Awesome!
    Pesos naman hehe.
    Jan 2016
    #123
    Masters, please help me translate concrete mix (M20) or 1-1.5-3 using bags of cement. This is what the foreman is familiar with. According to him, sobrang tibay na raw ng 1-2-3 using cement bag volume, not sure if the concrete ratio guide pertains to volume or weight kasi. Thanks.
    Sent from my Mi A1 using Tapatalk
    #124
    Pesos naman hehe.
    Oooppsss,- Sorry bro,- I was probably doing some company financial computation in $ that time...
    Even in PhP,- that's awesome!
    #125
    What's the concrete strength required? 3000psi? Stick w/ 1:2:3 by volume & keep water content at a minimum. The amount of water used to mix is a vital factor in determining the final strength of concrete. Use the least to get a workable mix.
    iba talaga pag engineer. Ang dami kailangan pag-aralan na sukat at bigat. Calculado talaga. Bakit pag licensure exam eh ang foucs puro sa mga attorney. Di ba dapat sa mga engineer kasi sila kumakalkula ng buidlings.
    Jan 2016
    #127
    I actually want 3500 psi, if that sack style volume is applicable, then I'll do the M20 mix. Thanks Sir Travs! [emoji4]
    #128
    20Mpa is a tad under 3000psi. The 1:2:3 mix will yield above that if controlled well. Note that plant-batched concrete will be more precisely portioned by weight. For DIY mixes, it might be a challenge to do mass portioning, hence, volume is tolerated. To check mix & moisture content consistency, do the slump test.
    Concrete Slump Test - Tutorial - YouTube
    You may devise your own version of the 12" test cone. The lesser the slump, the stronger the yield.
    Nov 2017
    #129
    For 1:2:3 workable mix you can get 4000-5000 psi. You can try 1:3:4 for 3000-3500psi. Sometimes on sacks method not all are filled equally. Like what trav said water is a major factor for concrete strength.
    Jan 2016
    #130
    Won't that consistency be difficult to manage if I don't have a concrete vibrator?
    Nov 2017
    #131
    As long as you dont see too much water separated on your concrete mix thats ok.
    #132
    It's not just recommended but required, sir. Drier, stronger mixes won't flow well. The proper way to prevent air bubbles, voids & honeycomb is thru proper vibration. It's even wise to keep a spare ready upon pouring as vibrator failures can be quite common.
    Jan 2016
    #133
    Quote Originally Posted by maxpedition View Post
    At a nearby house under construction, the engr told me she was using 1:4:6 for structural citing the sacks don't really get filled, but I think that would be more like 1:3:5. Just thinking that maybe if I do 1:2:4, then that would be more like 1:1.5:3?
    Actually gusto no foreman equal parts sand and gravel para daw iwas voids sa column, ano kaya effect nito sa strength?
    Jan 2016
    #134
    Thanks sir Travs, will see if I can rent one.
    #135
    If in doubt & you've the time to do some R&D, you can have your sample mixes lab-tested for compressive strength.
    Jan 2016
    #136
    Haha this is getting too meticulous. Maybe what I'll do is to keep a sample for testing later, I read that concrete achieves 99% strength in 28 days and continues to go beyond it's "rated" strength as years go by.
    #137
    Pardon begged, OCD & habits kicked in.[emoji120]
    Jan 2016
    #138
    No apologies needed Sir, I am very grateful for receiving valuable advise from the Masters [emoji4]
    #139
    Thanks, sir. Not qualified a master though. That honor should go to max.[emoji106]
    #140
    Guys what's the best way to anchor wooden baluster railing to tiled stairs? The stair tiles are outdoor finish porcelain types.
    Original plan was to have stainless steel railing but I'm trying to save a bundle by using wood.
House Construction
