Results 121 to 130 of 795
January 27th, 2019 01:00 PM #121
- Mar 2013
- 6,160
January 28th, 2019 08:30 PM #122
February 1st, 2019 01:40 PM #123
Masters, please help me translate concrete mix (M20) or 1-1.5-3 using bags of cement. This is what the foreman is familiar with. According to him, sobrang tibay na raw ng 1-2-3 using cement bag volume, not sure if the concrete ratio guide pertains to volume or weight kasi. Thanks.
Sent from my Mi A1 using Tapatalk
February 1st, 2019 03:25 PM #124
February 1st, 2019 03:59 PM #125
What's the concrete strength required? 3000psi? Stick w/ 1:2:3 by volume & keep water content at a minimum. The amount of water used to mix is a vital factor in determining the final strength of concrete. Use the least to get a workable mix.
BANNED BANNED BANNED
- Sep 2015
- 13,919
February 1st, 2019 04:05 PM #126iba talaga pag engineer. Ang dami kailangan pag-aralan na sukat at bigat. Calculado talaga. Bakit pag licensure exam eh ang foucs puro sa mga attorney. Di ba dapat sa mga engineer kasi sila kumakalkula ng buidlings.
February 1st, 2019 06:36 PM #127
February 1st, 2019 07:26 PM #128
20Mpa is a tad under 3000psi. The 1:2:3 mix will yield above that if controlled well. Note that plant-batched concrete will be more precisely portioned by weight. For DIY mixes, it might be a challenge to do mass portioning, hence, volume is tolerated. To check mix & moisture content consistency, do the slump test.
Concrete Slump Test - Tutorial - YouTube
You may devise your own version of the 12" test cone. The lesser the slump, the stronger the yield.
- Nov 2017
- 1,748
February 1st, 2019 07:30 PM #129For 1:2:3 workable mix you can get 4000-5000 psi. You can try 1:3:4 for 3000-3500psi. Sometimes on sacks method not all are filled equally. Like what trav said water is a major factor for concrete strength.
February 1st, 2019 07:31 PM #130
Won't that consistency be difficult to manage if I don't have a concrete vibrator?
I don't feel any diffeence ng DCT Sent from my iPhone using Tapatalk
(2023) Ford Territory
