Exterior or interior wall more than 3 meters width should have column stiffener and for 4.8m height of wall you should provide beam stiffener same width as you chb. Regarding your tie beams reinforcement if the span of your beams is less than 5 meters you can use 16mm but greater than that use 20mm.
