Results 21 to 30 of 908
October 17th, 2006 10:55 PM #21
kung gusto nyo LAHAT kayahin, Caterpillar 500KVA industrial generator ang sagot. yan gamit ng depot namin at kayang kaya 2 units ng mall-type chiller + tens of thousands watts of metal hallide lamps and FLs + a whole bunch of PCs
pero di lang nga automatic ang generator..manual key start pa. the automatic start add-on costs a couple of hundred thousand kaya di worth it unless may elevator like condos.
Tsikot Member Rank 5
- 3,144
October 17th, 2006 11:10 PM #22coleman din ang sa amin, 9600kva, ang ingay talaga, 15hp na briggs & stratton ang prime mover, kaya para kang nakasakay sa pump boat
October 18th, 2006 08:31 AM #23
pang malakasan na ito
.pero di lang nga automatic ang generator..manual key start pa. the automatic start add-on costs a couple of hundred thousand kaya di worth it unless may elevator like condos.
just in case nawalan ng supply sa Meralco
October 18th, 2006 12:24 PM #26
October 18th, 2006 12:29 PM #27
October 18th, 2006 12:29 PM #28
we have a honda genset and a robin....mas maingay yung robin, mas okay gamitin yung honda tsaka mas malaki yung tank nya kaya mas matagal mag-refill.....
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 18th, 2006 02:31 PM #29Ok yan lakas lang sa diesel at mahal ng parts. Siguro close to 100 liters per hour at 80% load. If you don't mind, where do you buy the filters and spare parts? Mahal kasi pag sa Monark. Cat Gensets din ang gamit namin.
Mali yata yung 9600kva dahil almost equivalent na yan sa 9.6MW pang power plant na yan bro.
October 18th, 2006 02:39 PM #30
Don sa DIY generator.. it says 4 Lit... does that mean 4 liter lang per hour?? or 4 liters lang kasya.. ilang liters per hour kaya yan?
What does it really mean when they say that the rack and pinion steering wheel assembly has been ...
rack and pinion repair
