Page 47 of 91 FirstFirst ... 3743444546474849505157 ... LastLast
Results 461 to 470 of 908
    ganun din po sir.. pati doorlocks pwede mo din palitan ng magandang klase po... yung insulation foam naman dalawang klase po yan yung isa 2" FOAM lang po.. yung isa maliban sa 2"foam nilalagyan din ng rock wool (selected areas only)
    nag pasok na kami dati ng genset na parang pinto ng kotse kung sumara... meron pang shock yung mga pinto to assist sa closing and opening ng doors...
    and if the doors dont close tightly... alignment lang po yan...
    well that says a lot about the manufacturer when the dealer/reseller still has replace parts and fix flaws to make the product market-ready
    Jun 2011
    #462
    Quote Originally Posted by joms View Post
    *Glenn = Elemax SH7600 and SH3200 are made in Japan. Elemax uses Honda engines. Complete line-up, pics and specs can be found here: ELEMAX GENERATOR JAPAN: EX Series - Products Line up
    Honda EP2500CX not sure but I think made/assembled in China already pero I think Japan pa din yung parts. Their specs/pictures/SRP price can be seen here: http://www.hondaph.com/view/power-pr...wer-generators
    Note: Honda Philippines recognizes the Honda generators such as the EP2500CX and they will honor the warranty. As far as I know, they will not, however, honor the warranty of the Honda engine placed in the Elemax generator.
    sir i check the specs and pics.. kung ganyan kalakas sa fuel yan... IMO mag china ka nalang... ilan araw lang para ka na din bumile ng china genset.. yung 6.2kva nasa 30k lang po yan...
    get a bigger rating genset nalang para sigurado ka tumatakbo lang ito ng less than 50% ng kanyang rating... para hindi hirap ang generator mo...
    Ang mga ganyan genset po kasi HINDI po matitibay yan... pag gagamitin mo na dun mo palang malalaman barado na pala noozles etc...
    Jul 2004
    #463
    Pre, alin sa mga sinabi ko ang malakas sa fuel? I am considering this 3 units now:
    1) Elemax SH3200 (2500watts nominal) = 1.42 liters/hour (P1,870/24hours)
    2) Honda EP2500CX (2300watts nominal) = 1.47 liters/hour (P1,941/24hours)
    3) Elemeax SH07D Diesel (50%load is 3250watts nominal) = 1.69 liters/hour (P1,833/24hours)
    I find their fuel consumption quite good already. Anong China brand will give me much better fuel consumption? Also, note that my nominal consumption will run at around 1600 watts only (I said mga 2000watts to give it some allowance baka may dagdag ako) so I think all three gensets above can easily handle my requirements.
    Would you still go for China? Which particular brand/model and why? May I know its liters/hour? Thanks
    Mar 2004
    #464
    You shouldn't rely too much on the specs. It's like buying a car based on specs. Admittedly, there are much fewer generator set users compared to cars so it's very hard to get actual reviews from users. So best bet would be to buy from reputable sellers and get a reputable brand.
    #465
    CLAVEL - what happened sa after sales service nila? Mabagal?
    CVT - pre what does "sinipat" mean and what do you mean na parang magkapatid sila?
    How about ELEMAX (powered by Honda), any feedback? Right now I'm looking into getting their Elemax SH7600EXS which runs around P70k (6.5kvA nominal / 7.6kvA max). This any good?
    Bro.,- tinignan kong mabuti.... Pareho ang layout, pareho halos ang mga piyesa..... Honda kasi ang genset namin....
    Looks to me like a re-branding only.
    “Familiarity breeds awe”
    23.7K:debate:
    #466
    Yung Cummins genset namin na 45kva consumed on around 140-160li of diesel during the almost 4 days of power outage caused by typhoon Santi last year. Walang patayan yung genset. During the day kasi we need the electricity for the business, and during the night naman for the house. So less than 2li/hr lang pala ang consumption kahit 45kva na?
    Signature
    Jun 2006
    #467
    Uls, glen, can you pls pm me price for 10 kva diesel generator, silent type with wheels for easy transport. Can be loaded or pulled by my truck if needed. 1800 rpm, 230 volts, 60 hz, single phase.
    My load will be 120 units of 15 watts led tube, 18 units electric fan about 90 watts each, printer, 3 computers and credit card terminal. No aircon load. I figure it's about 5 kW x 2 so about 10 kva. Tama ba?
    Jun 2006
    #468
    Sorry double post.
    Btw, can you pls include fuel consumption figures, how many litres of oil it needs, weight and other important info.
    Thanks.
    Jun 2011
    #469
    ask ko lang ilan po temperature?
    hula ko 45 lang he.he.. halos on idle lang yan.. he.he...
    yung unit nyo sir malamang running only at less than 25% of its standby rating...
    yung isang unit namin... 83kva Cummins din.. running between 60 up to 90percent of its standby rating... consumed 200 liters of fuel in 25 hours non stop operation....
    Quote Originally Posted by userfriendly View Post
    sir our smallest silent genset is 13 kva. doesnt have wheels
Generator sets
