Page 1 of 8 12345 ... LastLast
Results 1 to 20 of 158
    Aug 2003
    Hi everyone, i'm planning to plant some creepers to cover up the exposed walls/spaces at home. At least in my mind, the cover should help things cooler, since the areas aren't getting baked in the sun. Plus, i like the "green" look of it.
    Any recommendations for creepers/climbers? Preferrably the ones that don't destroy walls with their roots. A local plant shop suggested Ficus pumila, but i hear its roots can get into crevices and slowly destroy concrete walls.
    Some sources suggest that our native sampaguita(Jasminum sambac) can grow as a vine; pwede nga ba?
    tia
    tia
    what about bamboo? yung manipis, hindi yung pang-bangka.
    they won't creep, but they shoot straight up and can effectively cover your wall, without effectively touching it.
    but i am not sure of what the roots will do...
    Aug 2003
    Most of the floor is concrete po. I've thought about cutting a strip to plant bamboo, but i hear a lot of comments na ma-lagas daw sya, and it's virtually impossible to get rid of once nagka ugat
    what about putting up a vertical balag of sorts. that way, the creeper will use the balag and won't touch your wall.
    my concern with creepers, is that some of them aren't perennials. they die naturally after a year or two...
    tanim kayo ng patola o bitter gourd.. may pakinabang pa. wag upo. baka mabagsak ang balag.
    Aug 2003
    Yeah,putting up a bamboo grid/trellis could work. Iniisip ko naman e talian ng nylon from top to bottom of the wall for them to creep on
    yesss.. i've seen that, too.
    what about nylon chicken wire? or maybe something stronger, like industrial grade trellis? yung ginagamit na netting sa construction..?
    Aug 2003
    Does anyone know what these plants are:
    Jul 2006
    medyo ot :
    di ko maintindihan kung bakit pero lately tuwang-tuwa ako sa mga solar powered garden lights. halos lahat ng malalaking paso na nakapatong sa fence namin pinag-lalagyan ko
    medyo ot :
    Where did you buy, how much and how does it look like?
    Aug 2003
    Are these the low power/light types that you stick into the ground like tent pegs? Andami niyan sa ace, handyman, etc.
    ^ iyon nga iyon
    iyong mga pinag-bibili ko iyong mga P88 na binibenta sa japanese thrift stores. kelangan mo lang piliin para alam mong gumagana.
    although nakabili ako ng aluminum pole-like solar powered garden light for P250 din from ace naman
    ^ iyon nga iyon
    Bro.,- iyong mga P250 ay around P80 lang if you buy them from amazon....
    Doon ako bumibili ng solar-charging garden lamps....
    29.5K _/_/_/_/_/_/_/_/_/_/
    Ano yung halaman na humahaba nang pababa nakasabit?
    Aug 2003
    On the first pic i posted, i observed that the gardener initally planted it on the ground, then gradually twined it on the steel railings until it reached the top. Once there, hinayaan na lang tumubo pababa, almost covering the steel rails.
    I think yung spider plant can do that. You plant it on a basket, and let the "plantlings" shoot down via runners.
    Hindi ba available sa ACE hard ware I got mine sa ACE Hardware in Dubai.. and its not that expensive, depende sa size yung 6 pcs mga 1500 pesos lang
    Oct 2009
    Quote Originally Posted by CLAVEL3699 View Post
    hanging plants tawag namin nung elementary kami.diko ma pin point kung un nga ang tawag dun.para siya kangkong.na medyo dilaw ang dahon at tangkay.
    Quote Originally Posted by jaypee10 View Post
    Tama... hanging nga sya tapos hahaba nang pababa... lalagay ko sana sa bakod namin para matakpan.
    Oct 2009
    minsan nilalagay namin sa table ng teacher namin na nakalagay sa garapon.na may tubig hanggang sa humaba siya ng humaba at magkaroon ng kiti kiti sa loob ng garapon ha ha..
    pwede rin naman ung bogang bilya ung namumulaklak ng red na may tinik..ganyan ang bakod dati namin sa probinsya..
    heto yun diba?
Gardening
