Page 1 of 9 12345 ... LastLast
Results 1 to 10 of 87
    Sep 2016
    Hi Sir/Madam, appreciate your suggestions about portable tire inflator/air compressor. Anong brand ang mga trusted at saang dealer pwedeng bumili? TIA
    Aug 2012
    Gamit ko Windek Automatic, Digital Tire Inflator. Very easy to use. You can set the pressure you want into memory. Backlit LCD display. With White and Red LED flash light for night use or emergencies. With 2 adaptors for inflating other things.
    Sent from my D5833 using Tapatalk
    im using coido digital compressor, meron pa syang setting na ilalagay mo yung desired pressure then mag cut off, kaya lang ngayon hindi na gumagana yung feature na yun but everything else is working, bumili na lang ako ng tire gauge
    May 2009
    ts, go for the metal pump....wag ka bumili ng plastic.
    search ka sa lazada meron just under P1.5k lang....yung "total" na brand seems good enough....been also planning to buy one for long trips or emergencies.
    may air compressor ako kaso malaki....hehe
    Meron palang plastic na pumps hehehe
    Jul 2013
    We have a thread about this just recently. I just can't find it through the search function.
    Elevo EVO688 less plastics, large compressor.
    Feb 2016
    Sa SUV pwede ba ang portable na compressor? Ung sinasaksak lang sa 12V
    Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
    Aug 2012
    Quote Originally Posted by markkevin View Post
    Pwede. No problem with mine.
    Lahat naman kaya 32psi(most vehicles) Kahit lagyan mo ng 40psi matagtag naman. Kaya padin. I think max is around 45-50psi. Di na kaya mga 90-115psi for trucks hehehe
Tire Inflator/Air Compressor
