Hi Sir/Madam, appreciate your suggestions about portable tire inflator/air compressor. Anong brand ang mga trusted at saang dealer pwedeng bumili? TIA![]()
Gamit ko Windek Automatic, Digital Tire Inflator. Very easy to use. You can set the pressure you want into memory. Backlit LCD display. With White and Red LED flash light for night use or emergencies. With 2 adaptors for inflating other things.
Sent from my D5833 using Tapatalk
im using coido digital compressor, meron pa syang setting na ilalagay mo yung desired pressure then mag cut off, kaya lang ngayon hindi na gumagana yung feature na yun but everything else is working, bumili na lang ako ng tire gauge
ts, go for the metal pump....wag ka bumili ng plastic.
search ka sa lazada meron just under P1.5k lang....yung "total" na brand seems good enough....been also planning to buy one for long trips or emergencies.
may air compressor ako kaso malaki....hehe
Meron palang plastic na pumps hehehe
We have a thread about this just recently. I just can't find it through the search function.
Kung gusto mo mag-exercise, pwede rin yung bike pump na dual barrel. Mga 40 pumps lang per tire per day, maintain mo tire pressure and muscles mo.
Magkano po ang ganyan?
Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
After 4yrs of use sa 4 vehicles(and sometimes used to prime fuel filters) camshaft lock broke loose causing the cam to misalign. Na stuck up yung piston pero hindi nasunog ang motor.ang galing.
Cleaned and rebuilt, applied lock-tite on those screws holding the cam to the motor shaft and the cylinder.
Solid ang construction neto- zinc body, piston ring made of teflon material, and the sleeve/liner of the bore is well machined.
oil-less ba yung ganyan? have the same model for more than a year now, ok pa rin
After countless 0-35 PSIs on our vehicles and helping other motorists eh bigla na lang tumigil yung compressor. Ginagamit para makatakbo lang sa vulcanizing or totally walang laman ang reserve tire.
Wala namang sira physically on the outside or amoy sunog
Where can I have this repaired (anong shop ba dapat puntahan ko, electronics ba or machine shop or what)
edit: tried PM-ing you pero puno na inbox mo
Sa SUV pwede ba ang portable na compressor? Ung sinasaksak lang sa 12V
Lahat naman kaya 32psi(most vehicles) Kahit lagyan mo ng 40psi matagtag naman. Kaya padin. I think max is around 45-50psi. Di na kaya mga 90-115psi for trucks hehehe
I would suggest getting a metal tire compressors. Mas heavy-duty ang parts kaysa sa flimsy plastic box type of compressors. Basically plastic tube lang ang compressor nya sa loob. Tingnan nyo mechanism nyan sa video:
You don't need to get the exact brand endorsed sa video. As long as you get a metal compressor, ok na yan.
