Page 95 of 121 FirstFirst ... 4585919293949596979899105 ... LastLast
Results 1,881 to 1,900 of 2415
    #1881
    I actually prefer the Yokohama Advan Fleva V701 over the Achilles 2233.
    It's the Kumho Ecsta LE Sport KU39 that I like better than the Yokohama.
    The Kumho has better grip and a quieter ride than the Yokohama, though the Yokohama definitely lasts longer (I'm at 35,000 km and tread is still thick, while my Kumho only lasted 32,000 km).
    The Achilles 2233 is a decent budget option but if you can afford the better tires (Kumho or Yokohama), go for it.
    thanks for the correction bro
    btw how much better was the brandnew achilles vs the brandnew yokos?
    kasi IIRC you were OK with the 2233's up until near end of life?
    Jul 2019
    #1882
    hi all.
    when is it advisable to change tires? thanks
    #1883
    Quote Originally Posted by atty.cadmus View Post
    hi all.
    Between 30k to 50k kilometers depending on the type of tires you have. Sport tires (Potenza, Pilot Sport, etc) tend to degrade faster while touring tires last a bit longer. You can do a visual check on the tires if the grooves are still deep enough.
    Also, tires need to be replaced if they are more than 5 years old from their date of manufacture.
    Aug 2019
    #1884
    hi all.
    Suggest also to rotate the tires between PMS.
    Jul 2019
    #1885
    my wigo is running at 35k odo. 2 years and 2 months. the tires are bridgestone ecopia.
    Quote Originally Posted by geronimof View Post
    parang hindi ni rorotate ni Toyota ah.
    sa next pms, i will have it rotated. thanks
    Apr 2014
    #1886
    Ecopia have a thread wear of 300 or 400 ata.
    Basta maganda threadwear rating nya. It could be a while bago maupod. But check the indicator to see just to be sure.
    Jul 2019
    #1887
    Quote Originally Posted by chronicle View Post
    thank sir.
    my wigo is averaging atleast 600 to 700kms per week. or 100kms per day. i might change tires if 3 years na. what you think sir?
    Apr 2014
    #1888
    thank sir.
    May indicators ang mga tire kung upod na or di pa.
    How do I know when my tyres are worn | The NRMA
    Sep 2005
    #1889
    kung 700kms per week.. baka less than 2 years lang kailangan mo na magpalit..
    thank sir.
    Jul 2019
    #1890
    ai mali. sorry. for the past 3 months, nagiging 700 kms per week na. since i travel a lot papunta office. out of town kasi.
    but the wigo is 2 years and 2 months. running at 35k mileage.
    Sep 2005
    #1891
    have it checked pag nag 50K na.. maganda din ni ro rotate every PMS para pantay..
    Jul 2019
    #1892
    alright. thank you.
    #1893
    Assuming you drive such distances at this rate, you will reach 48k kilometers with those tires in 10 months time. I guess you need new tires by then.
    No point to be skimp on tires when they are the most important part of your car. I just replaced the stock tires of my FXT after having traveled 39k kilometers (in 3 years) on it.
    Sep 2005
    #1894
    sa experience ko time to change tires if 50K or 5 years whichever comes first..
    Jul 2019
    #1895
    noted sir. thanks for the input.
    any suggestion for a good quality tires? yung presyong kaya. hehehe
    Jul 2019
    #1896
    or i will do this. sagad ko na lang nang 50k hehehe
    #1897
    Check out the Indonesian brands - GT Champiro, Achilles, Accelera, or Neuton. They are affordable and still perform well.
    Jul 2019
    #1898
    thanks. noted sir.
    Oct 2003
    #1899
    Ung champiro gtx pro maingay.
    Any users ng comforser tires here?
    Oct 2019
    #1900
    Quote Originally Posted by timming_gear View Post
    Ok ba yung arivo Tires? 265 65 17 . 5k lang per piece..
    Sent from my SM-G965U using Tapatalk
    Planning also to buy arivo brand 215/55/17 size.
Low budget yet good quality tires
