Page 45 of 121 FirstFirst ... 354142434445464748495595 ... LastLast
Results 881 to 900 of 2415
    #881
    In the same line of thinking, reason why i bought a couple of pairs of Yokohama tyres last week.
    And having second thought about purchasing a pair of Petlas tyres for one of our rides.... 185 R14C 102/100Q....
    I have Petlas on one of my trucks bro. Not worth it imo. Madulas sya. Also had a couple breaks in the tread area even if we didn't get a single puncture. For 185r14 we use MRF. Good quality for the price. Bridgestones are still better but price is wow.
    Nexens are the oem for our GS. Ok naman, tread compound is on the hard side. Grip is just ok and we haven't had any problems naman. Hankooks look like they are much better. A relative has them on his Sta. Fe.
    #882
    mga bros, almost rear ended someone the other day. si kumag driver literal na biglang liko (motel), di nag signal pero tumigil bigla at tsaka nag signal na kakaliwa. * 60kph and no engine braking approximately 18 ft. bago ako nag fully stopped. umuulan pala noon and no abs yung auto ko (afaik vios e mt 2006). is this bad?
    #883
    btw road condition was similiar to black ice, asphalt na makinis most part so halos walang friction. salamat.
    #884
    Thanks bro.,- will then scout for other brands...
    Manipis na kasi ang tyres ng aming Old Faithful...
    Anyway,- dito lang sa tabi-tabi ang biyahe niya.... Pang-ragasa....
    Am currently using Hankook RA08.
    _/_/_/
    32.3K _/_/_/_/_/_/_/_/_/_/
    #885
    Sa emergency braking situations lumalabas ang difference ng magandang brand ng gulong sa mga budget meals.
    Apr 2014
    #886
    I do not like the stock Kumho Kh17's on my Kia rio. Handling issues at high speed highway driving.
    Sent from my MI 5 using Tapatalk
    Apr 2012
    #887
    Quote Originally Posted by fireice2 View Post
    I like KH17s naman with my Vios rather than the Yokohama Db na stock
    Sent from my LG-H818 using Tapatalk
    Jan 2017
    #888
    Good Day
    Tanong ko lang po kung ano po mas OK. NANKANG or FEDERAL?
    Hingi na rin po ako suggestions kung ano pa po mas OK na tires na mid price.
    Ito po size 195/55R15.
    Thanks po
    #889
    Quote Originally Posted by akris View Post
    Good Day
    Thanks po
    Between the two, Federal.
    You can also check out GT and Achilles if you're looking for budget brands.
    #890
    Yep, Federal over Nankang. Opt for 595EVO or Formosa FD2 with Federal.
    You can also check out Neuton or Accelera, good Indonesian brands like Achilles.
    Aug 2016
    #891
    Ano po recommended brands pang pick up o suv na ATs o HTs. My optiins are Federal GT Achilles Sailun Saffiro
    Sent from my SM-N920S using Tsikot Forums mobile app
    Jan 2017
    #892
    Thank you po jut703. Ichecheck q din po yan.
    Sent from my SM-N9005 using Tsikot Forums mobile app
    Jan 2017
    #893
    Tnx po egan101. Nacheck ko na din po yang mga yan. Tnx sa idea
    Apr 2017
    #894
    Mga sir, ask ko lang po. Ok lng po ba magpalit ako ng size ng gulong from 225/45r18 to 225/40r18? May car is a sonata, mabigat yung kaha
    Sent from my SM-G925F using Tsikot Forums mobile app
    Apr 2017
    #895
    7 yrs na kc gulong, pero nsa 70% tread life pa sana. My prospect is achilles2233
    Quote Originally Posted by markskept View Post
    try using this tire size caluculator para may idea a bro
    Tire Size Calculator
    #897
    The 225/45/r18 will be taller but it is within less than 5% of the stock size so you'll be good. I would suggest you go 235/40/r18 instead as it will be nearer to stock height but you get a wider tire.
    Apr 2017
    #898
    Thanks mga sir sa advice. Will be looking for 235/40r18 na. Haha! Any suggestions? Yung kaya lang ng budget
    #899
    Kumho Ecsta LE Sport KU39. Around 6k per tire. Grippy yet quiet. It seems that tread wear is good too as I've already done 10,000 km with my set and it still looks very thick.
    You can also go for Yokohama BluEarth AE50, around 5.5k. Not as grippy as the Kumho, but at least you get the Yokohama brand.
    If you want cheaper tires, Achilles 2233, around 4k per tire. Though I have to wonder why you're going for budget tires kung may pambili ka ng Sonata.
    Apr 2017
    #900
    Sa dad ko po yung sonata, and medyo tight na budget ngayon. Nasa province nmn kotse, 25km/day lang nmn tinatakbo. Safe po ba and authentic bumili sa mga independent online distributor? May nakausap ako sa 235/40r18, 3300 lang price eh
Low budget yet good quality tires
