Results 1 to 10 of 13
- Aug 2009
- 28
November 14th, 2009 10:37 PM #1hanggang anung size po kaya ng honda civic SiR?
balak ko po 17" naka lowering spring ako na 1.5 drop ok po kaya?
- Aug 2009
- 28
November 15th, 2009 07:51 AM #3pero hanggang anung size po kaya sa SiR? 18"? 19"?yung tama po sa fender di naman po sayad na pag 17"? baka pag todo liko sayad na sayad na ang 17'' di po kaya?
November 16th, 2009 10:04 AM #4
18", no... unless you want rubber bands for tires.... You'll have four bengkongs within the first week.
17" fits, but it depends on the width and offset of the rims. With a lowered car, you may have to adjust the camber and roll the fenders to make them fit properly.
- Aug 2009
- 28
November 16th, 2009 12:10 PM #517" po balak ko tapos po naka lowered na sya ng 1.5" drop na sya tapos po 205/45/17 balak ko sa tire sakto na po kaya sya or may need pa galawin pati camber?
November 16th, 2009 02:18 PM #6
It will really depend on the offset of the rim you're buying. If the offset is too small, the wheel will stick out and you will require camber adjustment.
November 16th, 2009 03:37 PM #7
I agree with Niky. Make sure the rims you get have the same offset (or at least, very close) required for your car; doing so you'll most likely be able to get the 17s with 1.5 drop and 205/45 tires to avoid any inconvience like tire rubbing and all.
- Aug 2009
- 28
November 16th, 2009 04:13 PM #8mga ilan offSet po ba ang kakasya sa SiR medyo ala din kasi ako alam sa mga ganun para di na ko papagalaw ng mga camber?
November 16th, 2009 05:14 PM #9
Not familiar with the SIR, but 38-42 is a safe bet. Try to get rims that aren't more than 7" wide. Maybe the Honda boys on the board will know.
December 22nd, 2009 08:59 AM #10
civic sir 99 ng friend ko po naka 20s iginugulong nya..concept one po ang gamit nya na rims..
hehe
wow thank you for your very informative reply, should i stick with the old 80's Mercedes to have...
Alternative Fuel Source: Waste Vegetable Oil...
