Results 1 to 13 of 13
    Aug 2009
    hanggang anung size po kaya ng honda civic SiR?
    balak ko po 17" naka lowering spring ako na 1.5 drop ok po kaya?
    Kung ako papipilin mo 17 " okay na sa akin.
    Aug 2009
    pero hanggang anung size po kaya sa SiR? 18"? 19"?yung tama po sa fender di naman po sayad na pag 17"? baka pag todo liko sayad na sayad na ang 17'' di po kaya?
    Aug 2004
    18", no... unless you want rubber bands for tires.... You'll have four bengkongs within the first week.
    17" fits, but it depends on the width and offset of the rims. With a lowered car, you may have to adjust the camber and roll the fenders to make them fit properly.
    Aug 2009
    17" po balak ko tapos po naka lowered na sya ng 1.5" drop na sya tapos po 205/45/17 balak ko sa tire sakto na po kaya sya or may need pa galawin pati camber?
    Aug 2004
    It will really depend on the offset of the rim you're buying. If the offset is too small, the wheel will stick out and you will require camber adjustment.
hanggang anung size na rim ang kaya sa civic SiR?
