Results 11 to 13 of 13
December 22nd, 2009 04:53 PM #11
+40 and higher offset is usually a good fit for any EK-body Civic such as the SiR. If you want a truly idiot-proof offset go for +45.
Do not neglect to look at your wheel width as well as your offset. If the offset is correct but the wheel is too wide you can still rub. (Conversely narrow-width wheels have a little more leeway with offset - you can run a little less offset without rubbing, e.g. 15x6.5 +38.) You should stay away from wheels wider than 7.5"
For daily driving 15" wheels are actually best for an EK Civic. 16" wheels are okay too. 17" wheels are pushing it already - tires are expensive, wheels are heavy and harshness is an issue at that size.Last edited by Type 100; December 22nd, 2009 at 04:59 PM.
December 22nd, 2009 05:05 PM #12
i agree with type 100. 15s-16s are already good for SiR. but 17s is way off.
putting 17s on SiR is like putting 19s on an FD.
December 23rd, 2009 09:32 AM #13
I don't feel any diffeence ng DCT Sent from my iPhone using Tapatalk
(2023) Ford Territory
