Results 21 to 30 of 43
September 29th, 2003 12:30 PM #21
...also there are some car alarm that can sense the if the car battery is low charge or not, if it is low charge and try to start the engine, the car alarm will siren...
September 29th, 2003 01:32 PM #22Originally posted by RedHorse
he he
HAHAHAHAH...
...AKO DIN yon ang akala ko.
September 29th, 2003 01:45 PM #23Originally posted by mdpo
Depende sa electrical consumption ng engine yan IMO kung kaya nung alternator yung mga electrical requirements then there is no problem with regards keeping the engine alive this is true with sedan/gas fed engine. But for diesel fed medyo malakas kasi ito sa kuryente so baka di kayanin ng alternator. I think this is also why diesel fed engine requires higher capacity battery for more stored power.
September 29th, 2003 02:47 PM #24
O.T. but I want to ask this q...
minsan, na-drain battery ko. nagpatulong ako mag-push start. sabi nung isa, di daw mag-iistart makina ko kasi patay daw baterya, electronic daw kasi ang ignition ko. e alam ko mechanical injection ..to make the story short, nag-start naman makina ko nung nag push start kami.
but for sophisticated engines like the trooper... mag-istart kaya mahina kung i-push start mo considering na electronic fuel injection sya?
*afrasay
yung diaphragm ba na sinasabi mo e electrically actuated yun? eto yung equivalent ng manual choke sa older engines di ba?
September 29th, 2003 03:52 PM #25Originally posted by ARB
did not know that could be done, EFI na ba? the tech school said that it was how the system works, sometimes nga when you use someone else battery to start your car and you dont rev it high enough it will shut down. and it will sometimes fry the computer.
oh well thanks for the info.
Tsikot Member Rank 5
- 3,144
September 29th, 2003 04:49 PM #26just came back from inteco, and accdg to TECH2 probe, nasa borderline case na ang alternator ko...
anyone knows what good brand of aftermarket alternator?
meanwhile, next assignment, is under the hood of E150, wala kasi akong alam sa layout noon, kung nasaan ang fuel pump and battery, just in case lang matulad sa nangyari sa trooper.
September 29th, 2003 07:06 PM #27
what do they mean by borderline na? in due time it needs replacing? you can have it fixed, may mga orig parts sa casa ang alternator. new one for the pickup cost 25k, mas mahal siguro for the trooper. better get that fixed, auto trans ba trooper mo? it cant be push start as with all auto trans cars.
- 3,144
September 29th, 2003 08:23 PM #28arb,
not the whole alternator, the exact description ay nasa truck, mas lower sa 25k, as usual inteco doesn't have it on stock, so I'll ask other isuzu dealers..
September 30th, 2003 08:19 AM #29Originally posted by rsnald
*afrasay
OT:
just this morning 5:15 am my safari won't start. it turns out my battery, which about 3 days ago was check by my suking store has having one dead cell, gave up on me. GRABBBEE, sobrang antok ko na (this is a different story)and can't think straight. hindi namin makaya push start ng guard namin. so i decided to wake my neighbor para kunin ang susi ng car to jump start. ayon, one click, panaandar ng isang toyota corolla ang isang nissan patrol. wala lang. ;)
Tsikot Member Rank 3
- Dec 2002
- 636
September 30th, 2003 08:34 AM #30RedHorse,
Same thing just happened to my alternator, 2 warning lights- brake and alternator- were lit up. Isuzu pasig said they can't repair, only replace but a new alternator for the trooper costs P40k!
The damaged part was the IC. The shop i brought it to didn't have the part but had a surplus alternator, same 90amp rating, same bracket and housing so had this installed- cost was P4.8k.
On an ECU controlled engine, you shouldn't disconnect the battery while running since a spike of AC from a faulty alternator may fry the ECU.
The only thing i notice with the surplus unit is that it has to hit 1krpm before the warning light switches off in the morning- is that because the unit was from a gasoline engine ?
Good point on that. But the hybrid one which will give you a ton of savings on fuel maybe worth it...
Mitsubishi Xforce
