Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    One was the Hand Brake Light, the other the Batterry Light, both were ON, though faint nga lang.
    I ignored them, when we went this am to matabungkay, and on our way home, near shell sta rosa, the engine died.
    Mabuti naitabi ko pa, mga 50m from shell. I called my friendly mechanic, but I could remember was to disengage something before towing.
    I opened the hood, and noticed that the neg terminal of the battery was loose. I bought a new battery, di na nga reverse polarity, abot din pala yong terminal, and after a hail mary, umandar.
    Tanong: Why the engine died kung loose ang isang terminal ng battery?
  2. #2
    bro na discharged yung battery mo. Oo nga reversed ang position ng polarity ng trooper. Motolite meron kaya lang yung higher models lang meron (excel ata).
    Kamusta na ang Trooper mo now? Baka hindi nag-deliver ng juice sa fuel pump mo kaya namatay. It's just a guess.
    ganyan din ang patrol. nag loose yun mga terminal/sockets na nakakabit sa positive not the battery terminal itself. ayaw din umandar. pagginalaw mo yun mga socket mag start.
    But the alternator is supposed to take care of the electrical requirements once the engine is running already, di ba? You could even disconnect your battery once your engine is up and running na assuming that your alternator is functioning properly.
    ewan ko, instinct lang yata, binomba ko yong fuel, napansin ko malambot, repeatedly hanggang sa tumigas, then kinabit ko yong bagong battery -- nag start naman, diretsong megamall he he, ayaw kasing mag-absent doon ng mga kids ko, so I told them na mag-taxi na lang papunta at doon na lang kami magkita-kita.
    new diesels have electrically controlled shut off sa injection pump. unlike diesels before if you push start it witout battery it will run.
    OT: ano po yung Arabs? akala ko nung una meron kang dinaanan na arabo na inisnub mo
    Signature
    oo nga dapat di mamatay kasi may alternator naman e. baka dead n alternator mo?
    Jul 2003
    Alternator supposed to power the system pero minsan di kaya ng alternator lahat ng accesories. especially the airconditioning. Kapag nagkokontact yung terminal sa battery, malaking amperahe kinakain ng battery so biglang nagkadip sa supply ng kuryente kaya siguro namatay engine.
    when there is no battery the engine will shut off. Alternators does not provide electricity they supply the battery current and the battery supplies it to the car. unlike old land rover which they have generators it supplies electricity to the car.
    sorry but i disagree sir. kasi ako i just ran my car 2 months ago WITHOUT a battery. start ko yung car using battery from another car, then removed that battery and then drove it for several km to get buy a new battery. during that time the old, discharged battery was in the trunk. di ko din pwede gamitin yung battery na pinag-start ko kasi 3sm yun di kasya sa car ko. so wala battery yung car habang gamit ko.
    did not know that could be done, EFI na ba? the tech school said that it was how the system works, sometimes nga when you use someone else battery to start your car and you dont rev it high enough it will shut down. and it will sometimes fry the computer.
    oh well thanks for the info.
    Jul 2003
    ARB,
    SOme alternators can't provide ample electricity at idle especially in cars where the main radiator fan is electric. add to that a/c load. an alternator reaches full power at around 1,500 rpm. Alternator get a negative ground on the engine. the positive out wire is then connected to the battery. but to connect the wire to the battery, it connects to the main terminal. thus also connecting to the rest of the car.
    generators were discontinued because of size an inefficiency. alternators are capable of producing more power in a smaller package. the difference is that generators put out DC current while alternators put out AC current which is rectified in the alternator itself. final output is DC.
    Hey redHorse, is your trooper a gold one? i saw a busted trooper on my way to Royale this morning.
    pk,
    Its white. It was also the first time to use an EWD.
    Jul 2003
    New vehicles with high-tech ECU's do not run when the battery is loose or disconnected......... i forgot the name of the circuit which senses if there is enough electronic supply for the whole system upon starting up the vehicle. Old vehicles (specifically diesel powered vehicles) will/can run even if the battery is loose or disconnected but if your alternator is of low ampere rating eventually your vehicle will shut down. I have experienced traveling Manila - Batangas with a discharged battery at kinaya naman po. The only problem was pag namatayan ako wala akong pang-startup sa makina ko pero buti na lang nag-recharge yung battery ko, thanks to my 80 AMP Hitachi Alternator :-))
    Depende sa electrical consumption ng engine yan IMO kung kaya nung alternator yung mga electrical requirements then there is no problem with regards keeping the engine alive this is true with sedan/gas fed engine. But for diesel fed medyo malakas kasi ito sa kuryente so baka di kayanin ng alternator. I think this is also why diesel fed engine requires higher capacity battery for more stored power.
    he he
    twice na ako nadali nito..
    yung first time umandar naman yugn patrol pero hindi gumagana
    yugn mga accesories, lights,signal lights,radio..pero yung engine ok..
    yung second time, ayaw naman umandar..
    yan nga ang dahilan.
Two Arabs I Ignored On My Trooper
