Page 71 of 73 FirstFirst ... 216167686970717273 LastLast
Results 1,401 to 1,420 of 1445
    #1401
    Sir up lang po ng thread:
    question po sa mga guru ng trooper.
    Ung officemate ko may trooper (i believe 4jx1 engine kasi 3.0),
    Ok naman tumakbo, pero nahihinaan na daw siya sa makina, pero he already clocked around 140k kms and i think 2000 or 2001 model ung kanya.
    Paakyat daw ng bridge sa ortigas, hirap ba hirap at sobrang bagal niya.
    Question mga sir, eto na ba ung relative sa fuel injection or sa turbo niya? Sorry hindi ko na po mabasa lahat.
    Ung abs niya umiilaw paminsanminsan din po, pero nabasa ko na nakukuha sa linis.
    #1402
    Help po mga idol.
    Aug 2009
    #1403
    good pm guys, need your help
    2003 isuzu trooper skyroof local 4jx1 engine edition
    1) umiilaw ang oil pressure indicator light when i started kanina ( hindi ko na pinatakbo)
    2) palaging dead bat ( kahit ok ung alternator) battery bough 2014 april
    3) no power when going uphill
    pls help thank you
    pls help thank you
    Sep 2008
    #1404
    anyone here with a 4JG2 local trooper na first owner until now?
    Jan 2010
    #1405
    Good morning mga trooper owners!i'm a proud owner of an isuzu bighorn 1994 4jg2 engine.
    #1406
    Quote Originally Posted by jidroiv View Post
    same here. 1994 4jg2.
    Aug 2015
    #1407
    yung Trooper ko ayaw mawala nung ABS warning light. :shocked2: ano kaya problem?
    Check all the abs sensor sa apat na wheels im sure isa doon ay may problema, may kamahalan ito lalo na't kapag buo na kasama ang hub...minsan kapag ginamitan mo ng scanner at delete ang DTC Code naaalis and warning light sa dashboard (ABS)...
    gdrtechnics.com
    Aug 2014
    #1408
    Hi Troopers,
    Gusto ko lang magtanong kung mga binebentang troopers ba are locals or converted surplus? pano malalaman kung local or surplus?
    Hi Troopers,
    Apr 2008
    #1409
    Most surefire way is through chassis number. Local 3.04x2 Skyroof Troopers have a chassis code of PABUBR73xxxxxxxxx. 3.14x4 Jap Bighorns have JACUBS69xxxxxxxxx. But traces of conversion are almost always very evident, like the 8 way adjustable seat at the right side, A/T shifter with button at the right side, reversed indicator stalks, etc.
    Sep 2008
    #1410
    My local 4x4 4JG2's chassis number also starts with JACUBS69 . . . , so it is not a sure identification for a surplus. The location of the wipers, car radio antenna (surplus is located on the left front fender), the angle of the side mirrors (surplus left side mirror is positioned more to the inside of the door), surplus 4JG2 engines have EGR, to name a few. HTH
    #1411
    look at the antenna. imported, the antenna is on the left side.
    May 2016
    #1412
    hello trooper owners! ask ko lang kung meron bang lumabas na local trooper with 4jg2 engine 4x4? what years did it came out and ok pa ba to bilhin na 2nd hand car?
    Apr 2008
    #1413
    Meron bro. I think 1999 and below. They're pretty rare though. Napakatibay kaya konti ang nagbebenta.
    Sent from my SM-G900I using Tapatalk
    May 2016
    #1414
    Quote Originally Posted by GTi View Post
    thank you. may nagbebenta kasi sa akin. akala ko kung 4jg2 na trooper surplus o converted. sabi kasi nya local talaga yung kanya kaya I had to make sure and ask dito sa forum. ok pa ba ang 97,000 mileage * P300k?
    Apr 2008
    #1415
    As long as the mileage is authentic, condition is good, and it really is a local unit. 300k is actually a good deal.
    May 2016
    #1416
    Thank you again for your insights sir.
    May 2016
    #1417
    * Sir GTi:
    ask ko na lang din kung alam mo ba na may lumabas na local trooper with 4jg2 engine 4x4 Automatic?
    kasi ang sabi nila mero daw lumabas na local 4jg2 4x4 BUt with Manual transmission and not matic.
    itsura nabinebenta sa akin is like the LS or skyroof without the fender flares and hoodscoop.
    TIA
    May 2016
    #1418
    kung may hoodscoop ba diesel at kung wala gas?
    Apr 2008
    #1419
    AFAIK all local 4JG2 Troopers were manual. I could be wrong though. There are however, many automatic Japan surplus 4JG2's.
    If without a hood scoop, that Trooper is definitely a gas V6.
    Perhaps the unit was originally a gas unit that was converted to diesel?
    May 2016
    #1420
    I'll have it check sa LTO this Monday. makikita naman sa history ng sasakyan kung may change engine ba. Philippines 2000 kasi plate nya at W ang starting. yun din naisip ko baka gas to diesel engine.
Isuzu Trooper discussion
