Results 961 to 970 of 3710
- Feb 2011
- 47
February 28th, 2011 12:51 AM #961Sir's,
Good day! I'm new to this forum..
Tanong ko lang marumi ba talaga ang gas(diesel/gasoline) ng petron? Dati kasi sa shell ako nagpapa gas pero ng lumipat ako ng petron naka experience na ako ng palya when rpm reaches 2000 ayaw ng lumampas sa 2k ang rpm, pina check ko sa isuzu madumi ang fuel filter pagkapalit ok na. 2007 ung crosswind(XUV) ko that was the first time na nagyari un. ngaun sa petron pa din ako nag gagas may naramdaman na naman ako palya last week.
pls share your experience..
Maraming salamat!
- Sep 2010
- 181
February 28th, 2011 06:35 AM #962[quote=red16;1688519]madumi na sigurado condenser ng aircon mo bro....dapat palinisan mo na...regarding sa nababawasan ng liquid yung reservoir mo,try mo muna ibalik sa coolant/water yung laman ng radiator at reservoir mo,before ka mag suspect ng leak sa radiator...ganyan din kasi sa akin,nung una,may coolant naman sya,kaso mas lamang yung tubig,1 liter coolant and the rest ay water na...kaso nagbababawas din,kaya dinagdagan ko pa ng coolant,dapat pala talaga 50-50....
February 28th, 2011 10:03 AM #963
Too early to assume given the information you have stated.
I have been using Petron straight since 2005 and I have no such issues -- considering that a Trooper's engine is much more sensitive than of a Crosswind. You may want to check that particular Petron station where you fill your Crosswind. Baka yang particular station na yan bahain yung lugar or di regular maglinis ng mga tanks nila.
- Jan 2011
- 176
February 28th, 2011 10:33 AM #964Good day guys..
1. ask lang sana ako.. if I get good fuel consumption, does it mean that my engine is healthy and in good condition? Is it that simple, or it does not always equate? I recently acquired a 2005 sportivo kase and I'm averaging 11-13km/L in mixed city and highway driving and I have an Automatic..
2. What can I do with the excessive rattling and noise of my grill? ang ingay, especially when the idle rpm drops a bit.. wala namang loose nuts & bolts..
TIA!
- Jan 2011
- 58
February 28th, 2011 12:40 PM #965Mga boys, Tanung ko lng kung san OK magpalinis ng injector ng xwind ko i'm in qc and caloocan... 100k km na kc gs2 ko lng palinis at bka gmanda pa ang performance nya... thanks much sa mga mkaka2long...
- Jan 2011
- 31
February 28th, 2011 02:24 PM #966Hello po sa lahat! Patulong po.
Bago palang yong Sportivo 2010 xmax namin, nakapark sa loob ng property namin na nakafence. Kinaumagahan, napansin ko nakabukas ang fuel cover.
Tanong ko po:
1. Mabubuksan ba ang fuel cover sa labas lang?, or dapat ba doon sa loob driver side ang unlocking?
2. Duda namin, me pumasok na tao sa bakuran kagabi at gustong nakawin ang sasakyan, pero kung binuksan yung fuel cover, bakit hindi nag alarm? Kasama ba ito sa security alarm system ng sportivo pag piliting buksan ang fuel cover sa labas?
3. Madali lang ba nakawin ang sportivo kahit naka lock lahat na door o me alarm? O yung mga magnanakaw ngayon magaling na rin na kayang e bypass/disalarm ang security system ng sasakyan?
4. Ano po ang dapat kong gawin para madagdagan pa yong security ng sportivo ko para hindi bastabasta manakaw?
I need your advise mga tsikoteers, first time kong car ito, baka wala pang 2 buwan mawala na ito. Konti lang kasi bahay/tao sa lugar namin.
Salamat po.
February 28th, 2011 03:17 PM #967
Tanong ko po:
1. Mabubuksan ba ang fuel cover sa labas lang?, or dapat ba doon sa loob driver side ang unlocking? - No way to open from the outside (except for XL model I think)
2. Duda namin, me pumasok na tao sa bakuran kagabi at gustong nakawin ang sasakyan, pero kung binuksan yung fuel cover, bakit hindi nag alarm? Kasama ba ito sa security alarm system ng sportivo pag piliting buksan ang fuel cover sa labas? - No. Alarm system only covers all 5 doors and hood. (with shock sensor)
3. Madali lang ba nakawin ang sportivo kahit naka lock lahat na door o me alarm? O yung mga magnanakaw ngayon magaling na rin na kayang e bypass/disalarm ang security system ng sasakyan? - All cars are easy to steal if the car thief is really good (except for vehicles with immobilizer wherein one would need the original key to start the car)
4. Ano po ang dapat kong gawin para madagdagan pa yong security ng sportivo ko para hindi bastabasta manakaw? - Install a steering lock (that thick metal rod you install on the steering wheel) and park the car in a well-lit area -- possibly with a security guard situated near your car.
Salamat po.
- Aug 2009
- 349
February 28th, 2011 08:04 PM #968Gud eve... mga sir! Kapapa ayos kulang ng leak sa radiator ng a/t 02 xwind namin. After na fix yung radiator, pina start at binomba or pedal to the gas ginawa namin pra malaman kung may tumutolo pa. Ok na cya at wala ng leak kaso nung tumatakbo nko at nag miminor bigla nalang namatay yung makina.. 3 times nang yari sakin. Binalikan ko yung shop at pina check ko ulit yung pinag kabitan ng mga pipes sa radiator eh.. ok naman at walang tagas or maluwag. Pina check kurin ang Battery, ok din (9months old) Hindi ko alam kung ano ang problem ng "Engine" bakit namamatayan ako. 1 year & 8 months plang yung xwind nang mabili nmin.
One more thing... my bad effect ba kung e-mix mo ang "distilled" sa "tap" water??Yun kasi ang ginamit ko kanina ... ty!
- Aug 2009
- 349
February 28th, 2011 10:03 PM #969[quote=acergy09;1688608][quote=red16;1688519]
Sir acergy... kaya ba e DIY paglinis ng condenser?How much sa shop pa clean any idea? (para di ako "mataga" sa pera.
) TY..
- Jan 2011
- 31
February 28th, 2011 11:09 PM #970
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
