Results 1,961 to 1,970 of 3710
- Mar 2010
- 143
February 26th, 2012 12:47 PM #1961ALIGNMENT questions po:
i've been troubleshooting cause of uneven wear of front tires. naka ilang balik na sa servitek pero ok naman lahat alignment analysis. finally, servitek mechanic recommended replacement of idler arm and then check for possible camber, caster at alignment (for the nth time).
kelangan kong matunton cause noong wear bago bili bago gulong. yung napu-pudpod ay yung inner portion nung tires.
naka discourage pa kasi sabi mechanic common problem nang mga kapwa crosswind ito at considering na wala pa 2 years yung xuv namin. hay grrrr talaga.
suggestions or tips from those who had the same and solved the problem? salamat!!!
- Feb 2012
- 7
February 26th, 2012 04:40 PM #1962Good day po sa lahat ng Crosswind owners, kakabili ko lang ng Crosswind XTO 2002 Model AT, ayus naman medyo nanibago lang dahil yung isang sasakyan ko ay Nissan Terrano mt.
Question lang po ano po ba pinagkaiba ng XT, XTO, Xuv, Xuvi? nagsearch ako sa net di ko makita
February 27th, 2012 03:38 PM #1963
XT, XTO are the non-sporty models, XUV and XUVi are sporty ones, They no longer release XUVi's, I think the last was 2005.
February 27th, 2012 10:04 PM #1964
Accessories ang differences nila.
The XTO is part of the standard ride height group. XUV, XUVi, XTRM, and Sportivo models have a higher riding body with fender flares and body cladding and a spare tire on the tailgate to emulate a sport utility vehicle..
Alignment, sakit na ata talaga ng Crosswind. Hindi ko alam bakit. Dahil ba sa parts na sinusupply sa kanila?
February 27th, 2012 10:50 PM #1965
Just wondering what an XTO would look like if it were equipped with an XUV's fender flares but retaining the XTO's alloy wheels and ride height. No photoshop installed to try it out.
February 27th, 2012 11:41 PM #1966
The offset is a bit of a mismatch. I've seen an XTO being kitted out with XUV flares back when body cladding and flares where the 'in' thing. The wheel's offset makes it look too small tired for the body kit.
On the other hand, the flares and cladding help avoid body damage from other cars parked beside you. The XT I drove had a huge dent in the door after some moron hit it with a car door. We had it repaired at a PDR facility. But still the time and expense could have been avoided if the vehicle had adequate protection.
February 28th, 2012 06:33 AM #1967
- Jan 2008
- 39
March 2nd, 2012 07:19 PM #1968Hi,
I've just bought 2005 ISUZU CROSSWIND SPORTIVO M/T. Still have not yet checked the car completely but may knocking sound sa harap, ano po kaya ang sira nito?
TIA
- Nov 2011
- 171
March 3rd, 2012 01:46 AM #1969^^
goodluck chuck,
you should have check it thoroughly before you bought the car.
p.check up mo na lng yan sa casa or sa mga ibang shop para mas makatipid ka,for sure mas madaling malaman ang problema pag nasa actual na.
- Feb 2012
- 7
March 3rd, 2012 10:35 PM #1970Paunti unti naayos kuna yung crosswind ko ano pa ba kulang?
Change oil, fuel filter & oil filter
overhaul ng mga brakes
tune up & valve clearance adjustment
Change of tires from 205 65 to 205 70 tapos na balance na rin
binili ku na rin nito bagong floor mat, rain visor, rear spoiler, pati na beverage & cellphone holder
Sa tues papa hilamos ko tapos palagyan ko ng carbon fiber sticker yung hood imbes na pa repaint ko yun na muna.
Planning to put 1 din dvd tv monitor next month
Decals na lang kulang, mga magkano kaya decals sa CASA? or may mabibili sa mga suking auto shops?
Thread was made nung 2018 pa po sir.
