Page 72 of 89 FirstFirst ... 226268697071727374757682 ... LastLast
Results 1,421 to 1,440 of 1770
    May 2009
    #1421
    Quote Originally Posted by ovitrops View Post
    jaz014, ano year model ng ride nyo? puwedeng reason kasi ng pagtaas ng temp gauge is may bara na sa radiator niyo. Every 20,000 km dapat pinapalitan ang coolant, baka hindi napalitan ng ganung frequency yung sa inyo..
    sir its a 05 XT bale sir newly overhauled ang radiator and with 1 blocked hole on the radiator due to leak(is this causing high temp). Coolant was only used last Feb and before magcoolant nag radiator flush using prestone radiator flush...one thing i am noticing with my ride kahit i-rev ng high rpm walang black smoke na lumalabas...
    Apr 2010
    #1422
    need help sir? napansin ko lang sa ride ko ( xuvi 02 matic) biglang nagbabago ang takbo, sa coastal hirap syang tumakbo sa 60 kph at 3000rpm di na sya maka angat sa 80kph pero minsan naman ok sya sa takbo na 60-80 * 2000 rpm.sabi nang barkada ko baka raw nag slide ung clutch..un ba ang depekto nito??thanks
    May 2010
    #1423
    Quote Originally Posted by jaz014 View Post
    Sir sorry for the late reply, nasira server ng internet namin. Ang mga na experience ko lang na mga dahilan ng pagtaas ng temp gauge sa sasakyan are:
    1. Sira nang thermostat;
    2. Baradong radiator;
    3. Sirang radiator fan motor; at
    4. Sirang water pump.
    In your case, mukhang ayos naman lahat ng mga parts na sinabi ko. Yung mga nabanggit kong parts, nasira within the range of 5 years.
    Reviewing the facts, hindi nagabawas water coolant niyo, at kakalagay niyo lang ng oil sa fan.. hindi kaya faulty yun water pump na newly installed, which was put to the test nung matinding traffic sa init at babad makina? These are just my opinion from experience sir, hindi ako expert dito..
    May 2010
    #1424
    Sir, most probably yung baradong hole sa radiator ang nag-cause ng pagtaas ng temp gauge..
    Sep 2009
    #1425
    ano naman reason pag bumababa rpm pag naka idle? yung xto ko minsan 600rpm lang with ac on. madalas tuloy ako mamatayan sa daan. comments please! thanks!
    Feb 2005
    #1426
    Quote Originally Posted by watuzi View Post
    Madali naman ma-determine kung clutch slide ka. You would notice it when you shift gears, matagal bago kumagat yung gears. Also, when was the last time you had your car PMS? Sa casa ba o sa mosquito shop lang?
    Quote Originally Posted by holdencaulfield View Post
    It could be a faulty idle up switch. The said switch is to regulate the idle when load (particularly gear shift/aircon compressor) engages.
    Apr 2010
    #1427
    sir! ngaun lang kasi ko naka pag drive ng matic kaya di ko pa pansin ang pag shift ng gears..pero nararamdaman ko lang na parang me natulak sa likod ko pag nag change ng gears 1st and 2nd lang kaso ung third and fourth parang wala na..sa barkada ko kasi itong crosswind kaya di ko alam kung san sya nag papagawa ako lang ang gumagamit. san ba malapit na casa dito sa makati area ako.
    Apr 2010
    #1428
    Quote Originally Posted by TholitzReloaded View Post
    Sinabi mo pa, Day 22 na ngayun wala parin yung Parts na kailangan ko (Headlamp) puro sila next week di masabi kung kailan exactly darating yung parts. Ni hindi apologetic yung nakausap ko tumawag nalng daw ulit ako sa Monday para magfollowup.. Imagine, nakakapiss off talaga yung mga tao dito. I wouldn't recommend this casa to any owner of Isuzu Cars here in Tsikot.
    Bagsak talaga Customer Service nila dito, they couldn't do anything para maprovide yung parts and to think na they knew the parts needed for replacement from the moment na dinala ko sa kanila yung auto ko as early as April 28 lumabas ung LOA and naorder na raw yung Parts pero anong petsa na ngaun May 12 na wala parin. Di man lang masabi ng taong kausap ko what's causing the delay.
    Nako sir ako ren marameng bad experience sa Isuzu Pasig
    Feb 2005
    #1429
    ISUZU Makati
    Dominga Building III, 2113 Pasong Tamo corner Dela Rosa Street, Makati City
    CONTACT NUMBERS
    Trunkline : 8191213 / 8191219 / 893-8064 / 893-8048 / 8938047
    Sep 2009
    #1430
    Quote Originally Posted by Benzmizer View Post
    *benzmizer-can i use this tiny li'l knob at the lower left to correct the rpm? btw, if my idle up switch is faulty, won't it move? coz i observe that the needle drops to 500rpm when load disengages and shoots up to 600rpm only when load engages. thanks again!
    Feb 2005
    #1431
    That little knob you are referring is the chock --- yes, it'll temporarily solve the issue on low idle but SHOULD not be permanent. That is used when cold starts to help achieve the normal operating temp of the engine faster.
    The recommended (normal) rpm should be:
    without aircon/load - 700-750rpm
    with aircon/load - 800rpm
    With this, your 550rpm (without load/aircon) and 600rpm (with load/aircon) is considered low.
    Oct 2009
    #1432
    normal lang ba na puti ang usok ngcrosswind? kac napapansin ko pagumaga parang mausok siya pagstart ngengine at nakaidle kac usually bago ako aalis ngbahay 3 to 5 mins idle para uminit ang makina, then napinsan ko kanina pagtraffic at nakaidle nakikita ko ung reflection ng usok sa sidemirror kac naiilawan ngkasunod ko na sasakyan. normal ba ito sa xwind?
    #1433
    Quote Originally Posted by B3GINN3R View Post
    Yung sa akin puti din usok pagstart sa umaga ganito na sya mula nung nabiling brand new. Yung medyo mausok nangyayari din ito sa sportivo ko kapag matagal tagal ko na hindi nilinisan yung exhaust kita din sa side mirror parang smoke screen hehehe. Binubugahan ko ng tubig mula sa hose pagkatapos non wala na masyadong usok sa idle or sa arangkada. Yung iba tinatapakan yung accellarator para matanggal lahat pati yung sa loob pero ako hindi na. Once a month ko lang ginagawa ito sir try nyo sir.
    #1434
    http://i938.photobucket.com/albums/a...5262010911.jpg
    Had a similar problem before. Ito yung ginawa namin sa idle up switch, naglagay lang ng rubber nakabalot dun sa "hook" kasi hindi na tumutukod sa idle control kapag humila yung idle up switch ng a/c. Crude but effective.
    Sep 2009
    #1435
    thanks for the info benz!
    Quote Originally Posted by redmicablue View Post
    try ko nga i-diy. salamat sa pic magaya ko mamaya. salamat ulit!
    #1436
    guys meron bang way para maka install ng 2din head unit sa crosswind?
    Apr 2008
    #1437
    replaced my foglamps to dlaa it only cost me P1,100 pareho lang sya nung binebenta sa casa.. but casa price is P5K plus
    May 2008
    #1438
    mga sir meron akong napansin na pag-full steer sa left may tumutunog na parang humahampas na bakal...neron na po bang nakaranas ng ganun...
    Feb 2005
    #1439
    Quote Originally Posted by kaioz View Post
    As i have owned 2 Crosswinds already, unfortunately wala. Kaya if you'd notice, ISUZU only develops 1-DIN headunits.... the most they did is a full 1-DIn screen (currently installed in the Sportivo)
    Oct 2007
    #1440
    ano yung dlaa sir. accessories shop ba yun at saan?
Isuzu Crosswind Owners Thread [ARCHIVED]
