Results 1,421 to 1,430 of 1770
- May 2009
- 119
May 21st, 2010 01:14 PM #1421sir its a 05 XT bale sir newly overhauled ang radiator and with 1 blocked hole on the radiator due to leak(is this causing high temp). Coolant was only used last Feb and before magcoolant nag radiator flush using prestone radiator flush...one thing i am noticing with my ride kahit i-rev ng high rpm walang black smoke na lumalabas...
- Apr 2010
- 2
May 21st, 2010 02:42 PM #1422need help sir? napansin ko lang sa ride ko ( xuvi 02 matic) biglang nagbabago ang takbo, sa coastal hirap syang tumakbo sa 60 kph at 3000rpm di na sya maka angat sa 80kph pero minsan naman ok sya sa takbo na 60-80 * 2000 rpm.sabi nang barkada ko baka raw nag slide ung clutch..un ba ang depekto nito??thanks
- May 2010
- 6
May 21st, 2010 05:32 PM #1423Sir sorry for the late reply, nasira server ng internet namin. Ang mga na experience ko lang na mga dahilan ng pagtaas ng temp gauge sa sasakyan are:
1. Sira nang thermostat;
2. Baradong radiator;
3. Sirang radiator fan motor; at
4. Sirang water pump.
In your case, mukhang ayos naman lahat ng mga parts na sinabi ko. Yung mga nabanggit kong parts, nasira within the range of 5 years.
Reviewing the facts, hindi nagabawas water coolant niyo, at kakalagay niyo lang ng oil sa fan.. hindi kaya faulty yun water pump na newly installed, which was put to the test nung matinding traffic sa init at babad makina? These are just my opinion from experience sir, hindi ako expert dito..
- May 2010
- 6
May 21st, 2010 05:41 PM #1424
May 22nd, 2010 02:26 PM #1425
ano naman reason pag bumababa rpm pag naka idle? yung xto ko minsan 600rpm lang with ac on. madalas tuloy ako mamatayan sa daan. comments please! thanks!
May 22nd, 2010 02:56 PM #1426
Madali naman ma-determine kung clutch slide ka. You would notice it when you shift gears, matagal bago kumagat yung gears. Also, when was the last time you had your car PMS? Sa casa ba o sa mosquito shop lang?
It could be a faulty idle up switch. The said switch is to regulate the idle when load (particularly gear shift/aircon compressor) engages.
- Apr 2010
- 2
May 22nd, 2010 06:22 PM #1427sir! ngaun lang kasi ko naka pag drive ng matic kaya di ko pa pansin ang pag shift ng gears..pero nararamdaman ko lang na parang me natulak sa likod ko pag nag change ng gears 1st and 2nd lang kaso ung third and fourth parang wala na..sa barkada ko kasi itong crosswind kaya di ko alam kung san sya nag papagawa ako lang ang gumagamit. san ba malapit na casa dito sa makati area ako.
- Apr 2010
- 23
May 22nd, 2010 06:58 PM #1428
May 22nd, 2010 09:37 PM #1429
May 23rd, 2010 02:28 AM #1430
Daming issue ng SU7:grin:
Xiaomi E-Car
