Page 65 of 89 FirstFirst ... 155561626364656667686975 ... LastLast
Results 1,281 to 1,300 of 1770
    Feb 2005
    #1281
    Quote Originally Posted by chitobarba1972 View Post
    mga gurus of tsikot , newbie inquiry lang...
    question for an A/T 4JA1 Turbo engine, what would be the normal procedure in turning off the engine after running for an hour at around 50 - 60 kph speed? How many minutes do I need to run it in idle before turning it off?
    Kasi sa akin ang practice ko ay to put it on idle for around 5 minutes bago turn off to make sure the normalized na yung turbo... is this ok or I'm just wasting fuel???
    paki klaro naman po... thanks in advance...
    No need to put your vehicle on idle. Since the 4JA1 is just low charged turbo, the oil cooler would be able to regulate oil temp.
    Feb 2010
    #1282
    Quote Originally Posted by Benzmizer View Post
    thanks for the info papsy!!!
    Oct 2009
    #1283
    *sir benzmizer so u mean there's no need to put turbo timer on the crosswind?
    Feb 2005
    #1284
    Quote Originally Posted by B3GINN3R View Post
    Nope. Waste of money.
    Apr 2010
    #1285
    Hi mga sirs and gurus. Need your help, bago lang ako d2. Hilander SLX, 1999 ung sa akin. I often visit my mechanic, dahil sa problem ko sa car. Mausok pag inistart, at kapag mabilis na ang takbo. Ang sabi ng mechanic, injection pump daw ang sira, at i-check daw ang nozzle. Tsaka may kabig din sa bandang kaliwa (drivers side).
    Please helppp.. many thanks in advance.
    Feb 2005
    #1286
    [QUOTE=DaddyLan;1451960][quote]Hi mga sirs and gurus. Need your help, bago lang ako d2. Hilander SLX, 1999 ung sa akin. I often visit my mechanic, dahil sa problem ko sa car. Mausok pag inistart, at kapag mabilis na ang takbo. Ang sabi ng mechanic, injection pump daw ang sira, at i-check daw ang nozzle. - Can be but I suggest that you have a 2nd opinion with another trusted and reputable technician to validate this. I fyou do so, justtell the 2nd technician the symptoms as you narrated here but don't say the said findings of the 1st technician who looked at it. If the conclusion is the same, it is likely the case.
    Tsaka may kabig din sa bandang kaliwa (drivers side). - Have you had your vehicle checked for its CAMBER and ALIGNMENT? If not, do so. Your camber/alignment may be off.
    Oct 2009
    #1287
    kailangan ng mgpalit ng rear shock absorber sa crosswind ko. ano po magandang shock ang ayos ilagay gas o fluid type?
    Feb 2005
    #1288
    In my own opinion, I'd go for gas type. Lasts longer.
    #1289
    Gusto ko sana magkabit ng chrome na rear combi para tail light. any idea kung magkano ang ganito?
    Feb 2005
    #1290
    Quote Originally Posted by TholitzReloaded View Post
    You referring to the standard tailamps on a 2008~ model Sportivo? If so, they go with the tailamps (not sold separately). Then again, I believe there are aftermarket stuff like those sold in accessory shops.
    #1291
    I was checking this with jasons autosupply pero according to them wala daw talaga kasamang chrome trim yung tail lamp. Si Marvs meron yata pero no news pa ako kung available na sa kanya.
    I'm also looking for sportivo decals not sure kung may nabibili nito.
    Feb 2005
    #1292
    Meron yan pero sa Parts Dept ng mga dealers tiyak. Those are not sold outside the dealer.
    #1293
    According to Jasons dinidikit lang daw ng double adhesive yung chrome trim, sana may magfabricate nito locally I'm sure magiging mabili to.
    Sep 2009
    #1294
    *bro tholitz- regarding sa chrome trim. try mo madison's sa banawe. sabi nung ebabs na nag-assist sakin meron daw sila nyan pero by-order. pang sportivo 10. price nag re-range 800+up. pag nahanap ko calling card nila post ko or pm kita.
    mga boss- pag pinalitan ba ang centerlink mas maganda bang idamay na rin ang mga tierod ends? salamat ulit sa mga tutugon!
    #1295
    Quote Originally Posted by holdencaulfield View Post
    *Holdenfield, thanks p're tagal ko ng naghahanap nito.
    Oct 2009
    #1296
    sir ok lng ba pag ung automatic tranny ko naka engaged sa 2 or L uphill climb then padating sa flat surface ililipat ko sa D accelerating without stopping the car? My nabasa kasi ako sa transmission forum na ok lng daw, hindi ba masisira ang gears ngauto tranny nun.
    Feb 2005
    #1297
    Ok lang yan. No worries.
    Basta don't shift to lower gear at high speed or else......
    Oct 2009
    #1298
    ok lng talaga sir benzmizer na iengage ung auto tranny from 2 or L to D kahit tumatakbo ang sasakyan?
    Feb 2005
    #1299
    Yes. You need have to stop when shifting from one gear to the other BUT you must be cautious of the vehicle's speed when shifting.
    #1300
    *Holdenfield, eto kaya yun? Madison Auto. Maizone. 41 Agon nr Banawe St. Quezon City • 7438223 to 32 loc 128. 50 Kaliraya St. Banawe Quezon City • 4118737 ...
Isuzu Crosswind Owners Thread [ARCHIVED]
