Results 1,281 to 1,290 of 1770
April 8th, 2010 09:19 AM #1281
- Oct 2009
- 59
April 9th, 2010 02:01 AM #1283*sir benzmizer so u mean there's no need to put turbo timer on the crosswind?
- Apr 2010
- 1
April 9th, 2010 01:21 PM #1285Hi mga sirs and gurus. Need your help, bago lang ako d2. Hilander SLX, 1999 ung sa akin. I often visit my mechanic, dahil sa problem ko sa car. Mausok pag inistart, at kapag mabilis na ang takbo. Ang sabi ng mechanic, injection pump daw ang sira, at i-check daw ang nozzle. Tsaka may kabig din sa bandang kaliwa (drivers side).
Please helppp.. many thanks in advance.
April 9th, 2010 03:20 PM #1286
[QUOTE=DaddyLan;1451960][quote]Hi mga sirs and gurus. Need your help, bago lang ako d2. Hilander SLX, 1999 ung sa akin. I often visit my mechanic, dahil sa problem ko sa car. Mausok pag inistart, at kapag mabilis na ang takbo. Ang sabi ng mechanic, injection pump daw ang sira, at i-check daw ang nozzle. - Can be but I suggest that you have a 2nd opinion with another trusted and reputable technician to validate this. I fyou do so, justtell the 2nd technician the symptoms as you narrated here but don't say the said findings of the 1st technician who looked at it. If the conclusion is the same, it is likely the case.
Tsaka may kabig din sa bandang kaliwa (drivers side). - Have you had your vehicle checked for its CAMBER and ALIGNMENT? If not, do so. Your camber/alignment may be off.
- Oct 2009
- 59
April 10th, 2010 01:39 PM #1287kailangan ng mgpalit ng rear shock absorber sa crosswind ko. ano po magandang shock ang ayos ilagay gas o fluid type?
April 10th, 2010 06:01 PM #1288
April 11th, 2010 02:01 PM #1289
April 11th, 2010 09:35 PM #1290
Xiaomi E-Car
