Page 60 of 89 FirstFirst ... 105056575859606162636470 ... LastLast
Results 1,181 to 1,200 of 1770
    Feb 2005
    #1181
    Quote Originally Posted by Niwr3_j View Post
    mga sir/s bago lang po ako d2 & wala din masyadong alam sa sasakyan! i brought a brand new isuzu sportivo 2009, i used almost 15 days lang po then after nun out of the country na ako.. worried lang po ako kasi walang gumagamit sa bahay pinapa-andar lang ni erpat every other day.. ask me lang po kung oks lang po yun n hindi sya tumatakbo? please give some advice naman po sa mga expert isuzu owners?
    TIA..
    Well, that's better than not start it at all BUT ideally, a vehicle (regardless of brand) should be run even just for 1 or 2 kilometers (at least) mainly for the benefit of those moving parts --- lubrication purposes.
    One part that is commonly affected when a vehicle is left idle for a long time are the brake calipers/system. They get stuck up (even newly replaced) if not used for a long time.
    Sep 2009
    #1182
    Quote Originally Posted by samurai_jack View Post
    mga bro... question lang.. i have a Crosswind XTI 2010. gusto ko sanang maglagay ng chrome accessories. Pero sabi ng casa wala pa daw sa banawe area but sa planta meron. i asked kung iniba nila design ng tail lights. ang sabi iniba daw. baka pag bumili ako sa labas eh ipilit lang. may alam ba kayong mabibilhan ng chrome accessories, especially for the rear lights?
    tanung tanung ka lang sa banawe meron na sila. nasa 800-2,8k. yun yung horizontal ang hati sa gitna.
    Jan 2010
    #1183
    Quote Originally Posted by alfredj View Post
    mga sir help naman po bago lang ako dito.kakukuha lang namin ng new sportivo last january. tanong ko lang po kung saan po mas maganda ipagawa ung lock ng pinto.ayaw kasi maopen ung door pag nasa loob.nabali po yata. kailangan po ba na sa isuzu ko ipagawa..? normal lang po ba sa aircon na parang may tumutunog ng ''tik'' after 3-7 seconds parang nag auto on/off po ung aircon?ilan po ba ang dapat na tire pressure? kailangan ko po ba sundin ung 26psi front at 35psi sa rear parang matagtag po yata ung 35psi..? maraming salamat po.
    Sir baka child lock lang. Di pa ako sure nito ha kasi hindi ko pa nacheck kung may child lock ba yung pinto. Aling door ba ang tinutukoy mo? Yung sa aircon na may 'tik' sound, ganun din sa sportivo namin. Napansin ko kanina while idling, pagmag-on or off yung thermostat ata ng aircon, may 'tik' sound. Maybe the other experts can shed light on this.
    Feb 2010
    #1184
    Quote Originally Posted by KramretxeD View Post
    yung isang door po sa gitna left side.ayaw po maopen pag nasa loob. parang nabali po yata..
    Feb 2010
    #1185
    sir ano po ang tire pressure ng sportivo nyo?front and rear?
    Feb 2010
    #1186
    sir tama ka naka child lock po yung door kaya pala ayaw maopen pag nasa loob. thank you po.ano po tire pressure ng sportivo nyo?front and rear?
    Jan 2010
    #1187
    Mabuti naman sir at child lock lang pala. Di pa namin napapalitan yung air pressure sa wheels, straight from the casa pa yung sasakyan. Last saturday lang namin kinuha so i guess nasa default pressure yung wheels. Pansin ko mas mataas pressure sa rear kaysa front. Napansin mo ba sir yung 'ssshhh' sound ng aircon? Kasabay nung 'tik' sound. Kanina ko lang napansin eh.
    Sep 2009
    #1188
    Sirs,
    Meron din ako concern with regard sa Tire Presure,
    I currently have 30psi front and 33psi rear
    I have an XTO. Ok lang ba ung pressure na un.
    Usually Magisa lang ako sa car and gamit ko to daily from Novaliches to Makati. Minsan lang my sumakay sa front lets say my side trip ako.
    I loaded kasi before 35psi on all tires pero napansin ko somehow matagtag cya sa edsa.
    And about sa comment ni Sir CrosswindXT na kapag 40psi maganda or Tama lang ang kain sa gulong. is this true. sa dating lancer ko kasi same same din tulad ngaun ang pressure 30psi front and 33psi rear.
    So ano kaya ang advisable sa ganitong mga scenarios?
    Thanks!
    Feb 2010
    #1189
    yes sir napansin ko din yung sound ng aircon. ok lang kaya yung tire pressure na 30psi front and 35psi rear? yung nakalagay kasi sa gilid ng door ang tire pressure ay 26 psi front and 35 psi rear?kung gawin ko kayang 30psi front 32psi rear?
    May 2009
    #1190
    TIA..
    usually sir kapag nastock ang sasakyan on a long time basis is naooblong ang mga tires niya...dapat at least madrive yan once in a while...ipadrive mo sa erpats mo instead na stationary idling lang...
    Jan 2010
    #1191
    Quote Originally Posted by jaz014 View Post
    mga sirs thanks po sa advice.. mag 1 yr npo kasi sya 2k palang ang tinatakbo, baka pag uwi ko palang uli sya masu2lit! may tanong po uli ako mga sir/s
    1)plan ko kc i-upgrade ang audio system nya like changing the stock speakers and addt'l amplifier pag pinalitan ko po ba lhat ng stock audio system ko is mavoid na ang warranty nya?
    2)parang naliliitan po ako sa gulong at rim nya comparing sa body parang alangan eh..gusto ko rin sanang palitan at ano nmn po ang recommended size at brand ng gulong & rim ang magandang ipalit? mavoid din b warranty nya pag nagpalit ako?
    TIA po ulit.. pasensya npo kya newbie lang sa forum at sasakyan eh
    Apr 2008
    #1192
    *niwr3 bro 18" is enough bagay satin ung rota journey.. tapos low profile tires
    Jan 2010
    #1193
    thanks bro.. u have any idea po how much it will cost ska saan shop magandang bumuli at mura? thanks
    Jan 2010
    #1194
    mga sirs anong size b ung rim at gulong ng stock ng sportivo? d b sya mag ka2 problem pag pinalitan ko ng mas malaki at ano po magiging advantage at dis-advantage pag pinalitan ko sya? thanks..
    Jan 2010
    #1195
    mga sirs check nyo tong pic nung ride ko diba parang alangan ung rim & tire nya sa bulk body nya!
    ano po ba ang advantage & dis-advantage pag nagpalit ako ng mas malaking rim & tire? please give some comments po and advice bago ko mag decide! saka ma void po ba insurance nya pag nagpalit ako ng kahit na anong accessories fr. the stock?
    thanks po uli
    Jan 2010
    #1196
    thanks po uli
    Feb 2005
    #1197
    [SIZE="4"]Geez![/SIZE] Talk about "LOW MILEAGE"!
    Any alteration on the vehicle WOULD void its warranty.
    Here is a photo of my former 2003 XUVi on 18" rims:
    ... on 255/55 Bridgestone Dueler H/P tires.
    Disadvantage? Tatagtag ang ride mo.
    Apr 2008
    #1198
    pero sa porma ok na ok..
    *niwr3 try mo to www.rotawheels.com call mo nalang sila.. afiak 30k ung mags na journey
    Jan 2010
    #1199
    sir for me kung city driving ka lang, ok na siguro yung 30 front and 35 rear. di naman masyado iinit gulong mo unlike highway driving na iinit talaga gulong mo. yung recommended air pressure kasi may allowance yan tuwing iinit gulong mo, tataas din air pressure sa tire. kung combination ka, city plus highway driving, i suggest stick to the recommended air pressure. kasi pinag-aralan din yan ng manufacturer through several and rigid tests. pero like all things, personal preference mo pa rin yan sir. kung comfortable ka sa current air pressure mo (handling and ride comfort) then stick to it. ikaw din naman sasakay sa sportivo mo.
    Feb 2010
    #1200
    sir thank you po sa reply.sir what po ba ung recommended air pressure?un po ba ung 26psi front and 35 psi rear?
Isuzu Crosswind Owners Thread [ARCHIVED]
