Thank you sir crosswind.
Ano po marerecommend niyo na rear parking camera? May parking sensor naman ang LS-A na m/t pero nakukulangan ako saka masikip talaga ang parking sa opisina namin.
So my first day vacay, installed aftermarket stainless steel intercooler pipes paired with Mishimoto silicone couplers/tbolt clamps. Then right after, HPD Australia Baffled Catch Can was assembled, then installed the K&N 33-3002 filter.
Sent from my iPhone6s using Tapatalk
Nice! Drooling over that dream HPD occ [emoji23]
Paps don't forget to tighten tbolt after a test run, or pag uminit ulet engine. Best to press the mid side of T while you're tightening it para di magbreak. Btw, may padating ako extra tbolts in case you need it.
The downside of LED for me is medyo scattered or sabog un spread ng ilaw, and you need to look for something with a good heatsync. You'll adjust a bit bec we're used to a more focused type na halogen bulb. If you backread a bit, Aaronix recommended some good bulbs to replace ur H11, i think it was PIAA ArrowStar white, simple plug and play and can be bought in most auto shops.
I wouldn't go HID retrofit since ours has that look in our low beam and those that are good really set the price very high 30-45k including fog lamps assembly.
Feeling car guy chronicles, on my second day vacay starts 'em early, the fuel trophy wheels that we installed half a year back isnt available on the offset that i need, currently et+20 and i want somethin like et-15.
And also have taken into consideration, the wheel manufacturers that make its center bore bigger so that the same type of wheel can be sold/installed on any other car brands.
That's where this fella kicks in, a customize hubcentric spacer with ID100mm centerbore to suit Isuzu's Hub and an OD108mm wheelbore to suit the aftermarket wheel and its a perfect fit. No more gap between the wheel hub and the rims. Majority of the vehicles weight will be carried by the hub and not entirely solely on the bolts. Just like an oem rim would do.
Wow HPD occ! Pangarap ko din yan. 😍
That is the correct way to avoid wiggling, vibration and stressing the bolts. 👍👍👍
In my case, I bought hub centric rings instead for my 0 offset wheels. I don't want them sticking out too much. ;)
Feeling car guy chronicles, 2nd day past noon, and its electrical upgrades.
Replaced stock/oem bulbs, with IPF halos, so feeling JDM fanatic? Added PIAA leds for signals, Philips leds for cabin lighting and positioning, HKS circle earthing system, Pivot megaraizens volt stabilizer, PIAA led regulators that serves as resistors to signal lighting. Hard wired also the Cellink B6 Batt from Lighter source for the Black Box. Replaced the stock batt terminals with heavy duty Projecta premium batt terminals.
IPF halos that were installed H11 Low Beams, HB3 High Beams & H16 Fog Lights.
[QUOTE=aar0nix;2741795]Could you post your receipt/invoice? Just blur out the personal details. Thanks[/
Good pm. Yes no probs, i will try to post it here, actually i found 2 previous receipts, still trying to figure out how can i post it here![]()
Anyways, the last time i had my car serviced, they were particular in reminding me that they must be informed beforehand that i will be availing of the arc discount, dati kasi nasa cashier na ako nung nilabas ko ang Arc card, i think the acctg people needs to know first![]()
I can only find 2 of my previous pms receipts where i was able to get an Arc discountwell, I think very minimal lang talaga pero kahit papaano me discount. You will appreciate the arc i think when you use it in booking ayala owned hotels, pag sa seda, you'll get a free room upgrade
