Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
    Jun 2004
    #31
    hi sir,
    FYI, the 1kzte uses a computer box. you might get the engine cheap but the electrician will charge you an arm and a leg for the installation. friend of mine spent 15k on the electrician labor and materials. and the 1kzte may be fast but its not as fuel efficient as a 4jg2. cuz the 4jg2 is direct injected. but the 1kzte runs smoother because it still has a pre combustion chamber unlike the 4jg2 (direct injected).
    Another consideration you should consider is the vibration of the engine. Malakas ang vibration compared to a gas engine.
    May 2004
    #32
    mints, 4jb1t is direct injected. but afaik 4jg2 is not. i maybe wrong though
    #33
    Quote Originally Posted by niwde11 View Post
    You are correct on both sir niwde.
    Feb 2011
    #34
    4JX1T ang direct hehe
    pero kung wala akong mahanap na 4JG2T baka mag SR20DET na lang ako
    since timing chain din siya
    #35
    Quote Originally Posted by jctapit13 View Post
    ayaw talag ni sir ng timing belt ha. hehe. To each his own nga naman.
    Feb 2011
    #36
    hehe sabi kasi ng mechanic mahirap daw ma distinguishe kung sira na ang
    timing belt eh
    btw yung SR20DET daw 80k daw pero hanap muna ako ng non turbo
    para tipid rin sa gas hahaha
    #37
    timing belt eh
    Madali lang naman kung gusto mo maging safe, 80,000km change ka na and use only OEM belts.
    Feb 2011
    #38
    ayaw rin ng tatay ko eh kung sakin lang yun 4AGE HH na lang papalit ko haha pero yung 12t namin na toyota 381T KM na wala pang palit palit ng timing chain kaya ok rin sakin maghanap ng timing chain or gear type na engine kasi 381T KM nayun wala pang ingay yung chain
    Jun 2004
    #39
    thanks for the info. all the while i thought all of the 4j series were direct injected.
    #40
    how much for this brandnew 4JB1T?
4JB1T Engine
