Results 181 to 190 of 224
May 1st, 2015 02:10 AM #181
mga sir meron n po ba nkasubok sa inyo ng oil catch can ? effective po ba or just a display lng
- Aug 2014
- 391
May 1st, 2015 11:33 AM #183for 4jai, none turbo, yung oil catch can is for crank case breather. For mine, since its so old, a lot of blowby exist, so with out oil catch can, if you check the intake of the engine, you will find a lot of oil that enters from the crankcase breather. If you put a catch can between the crankcase and intake, you will minimize or prevent oil contamination of the intake, which will make the engine burn the air from air intake and the fuel only, with out catch can, the engine may also burn the oil that contaminate the intake, which is supposed to be not ideal. Engine oil is supposed to be not included as fuel. Yung sa akin, diy lang.. so not that good looking.. I'll put a picture in a while.
Hopefully, i am not doing it wrong, so posting the image here so to get feedback if i might be wrong on this.
The reason why i by pass the pipe near the intake is that, I observed that there is a little pressure that might go from here to the crankcase breather pipe, and since I admit that this rig has more blowby, bypassing per my observation, will reduce the pressure during the engine is running.
- May 2015
- 5
May 31st, 2015 11:44 PM #184Ah ganun pala tnx for posting sir talagang ginastusan mo ah. Ako binubuksan ko ung intake manifold cover hinuhugasan ko ng joy tapos ung intake manifold mismo pinupunasan ko lang kse bawal malagyan tubig as per advice ng isuzu mechanic friend. Need talagang linisin para lessen ang usok ng tambutso. In my opinion lalakas fuel consumption mo pag na condemn mo na yang breather hose papuntang intake manifold.
- Aug 2014
- 391
June 2nd, 2015 09:13 PM #185hinde naman ginastusan yan, kasi mga pvc pipe lang yan na sobra, tapos joints na tig 15 petot, then used baunan nang tubig na di na ginamit. Di ko lang maintindihan kung bakit lalakas fc if condemn ang breather?
- Jul 2015
- 8
July 23rd, 2015 09:30 PM #186Gud pm po, may isuzu fuego po ako, ask ko lng po, saan po yun tamang pag pakabit ng crankcase oilseal. Help nman po, naka dalawa trial na yun petron pero may leak pa din lalo pa lumakas....
- Jul 2015
- 8
July 23rd, 2015 09:36 PM #187Sir need ko po Help, saan po yun magaling na magkabit ng Crankcase Oilseal. 4ja1 isuzu fuego 2001 nakadawa na kasi ako palit pero nagleak pa din, Mahal pa nman nun oilseal 900each original po
- Jun 2010
- 87
July 28th, 2015 06:30 PM #188
- Apr 2015
- 9
August 2nd, 2015 10:29 PM #189kakabenta ko lang ng 1999 fuego ko, then pinalitan ko parin ng fuego 2002 pero nka turbo na sya with 4ja1. bulletproof itong engine na to.
- Aug 2014
- 391
August 6th, 2015 09:44 AM #190Hi,
I have a mechanic replaced the oil seal of the rear of transmission, the part that connected to propeller. But after a few days, I noticed that there is still a little drop of oil. Can anyone suggest what could be the other problem? is the seal not fitted properly (note: its an OEM Isuzu with correct part number). Hope someone can advise.
Thanks
Hi,
Thanks
It should be repairable. The labels on the tire sealant all say that its a temporary fix and you...
Liquid tire sealant
