Page 9 of 12 FirstFirst ... 56789101112 LastLast
Results 161 to 180 of 225
    #161
    ^ change oil,air filter,fuel filter...baka sobrang baba ng rpm mo 750rpm idle without aircon aroung 800-850 with aircon...
    kung ok naman lahat try the 2t oil theory...read kalang ng other thread (diesel owners that add 2t)
    #162
    Quote Originally Posted by sprite View Post
    sir kmzta po..ask ko lng po kc yung fuego na 2004 model ko..ngoverheat sya kapg ntrafic at nkapark..ngbabago din yung menor ng engine at nawawala lamig ng aricon..pingawa ko na radiator,injection pump,pti chnage oil tuneup na ko ganun pa din?salamat
    sir yung thermostat mo ok pa ba? remove or replace the thermostat...nung ginawa ba radiator ay lininis ang mga cooling fins using sosa and power spray? it will help IMO...
    by the way tignan mo rin ang radiator kung hindi bumubulwak ang tubig pag naka idle ka if bumubulwak its a worn out head gasket or worst cylinder head...
    Oct 2014
    #163
    4JA1 - very reliable, easy to maintain, matibay, and fuel frugal diesel engine. Had one with my 92 Isuzu LS Pick-up with 281,000+ kilometers in it. Tamang maintenance lang talaga ang sikreto. Common lang talaga dito yung medyo mausok. Sa akin ganon din compared sa iba naming sasakyan (Intercooler Turbo 4D56, TDCi, and Hyundai CRDi) pero hindi naman mausok na akala mo nagpapaapoy ka ng mga dahon at sobrang itim. Normal na usok lang from exhaust and the smell is like normal although yes compare sa ibang engine namin medyo (iba ang amoy, but still amoy diesel pa din). Almost 70% of the parts in my pick-up are still the original parts when it was bought brand new way back in the 90s. Only problem experiencing right now is this:
    1. It is somewhat shakey (maalog) especially pag naka-ON ang A/C. Sa lower idle speed nya the car starts to vibrate abot sa cabin and yes noon malakas. At first I thought engine supports, but then we had it fixed with the help of our mechanic na may ganon din na sasakyan, nilinis lang pala yung Air Filter kasi madumi na even konting lumot meron na plus nilinis din also yung Fuel Pump because may tubig na daw i don't know gaano kadami. It went back to normal again, hindi na maalog sa kahit anong idle speed range and we were able to bring down the idle speed to normal which is 850 rpm. The only thing is it's starting to rattle now again pero very very minimal lang and very very weak na rattle lang pero syempre lahat naman tayo metikuloso sa sasakyan natin diba? i'll have it checked nalang again (the fuel pump) and I will try to clean the air filter again this time and maybe change it next week. We'll see the difference kung andoon talaga. But then if hindi pa din mawala ang rattle/vibration sa paglilinis ng air filter and fuel pump, maybe I really have to check the engine supports.
    Over-all this 4JA1 engine is a very reliable diesel engine. Kahit yung maikarga mo dito na fuel (by accident) ay madumi or may water or whatsoever (hindi naman maiwasan ito sa ibang gasoline stations esp sa far-flung areas), never mo ma-eexperience na masisiraan ka ng engine. Base on my experience, pupugak lang ng konti but when nasunog na yung fuel, okay na sya. Unlike some of my friend's CRDi engines, nadumihan yung fuel. Boom! Sira na injectors
    #164
    tibay ng makina na yan problema lang talaga makupad tinatakbuhan nga ng mga 800CC na sasakyan
    Dec 2013
    #165
    Yung amin hilander xtrm yr 2000 non-turbo 4ja1. Hirap mag-100kph pedal to the metal na unless medyo downhill kahit hindi loaded. Madalang itakbo ng highway to halos purely city driving. Normal ba to?
    Jan 2011
    #166
    Quote Originally Posted by n_spinner06 View Post
    check mo fuel filter at sedimentor, baka barado na po sir. palit air filter din po sir. if ganun pa rin, pa check mo ang injection pump sir. o baka ang preno mo sir, nakakapit palagi. many possibilities but start at the basic.
    Aug 2014
    #167
    ano naman kaya problema kung paakyat, parang hirap, yung stop ka then paakyat na, so start ka sa first gear, tapos nahihirapan... ano kaya pasibleng problema... new fuel filter, new air filter, just cleaned water separator. Napansin ko lang, almost half yung temperature ng engine sa gauge... sentomas ba to nang isang engine problem?
    Dec 2013
    #168
    Quote Originally Posted by shelu View Post
    thanks for the reply sir shelu...crossing my fingers na hindi injection pump. ok naman takbo normal traffic, bagal lang naman. yun nga lang 80kph lang tapos gapang na acceleration or minsan hanggang dun na lang talaga. 1500km pa bago yung next na servicing, baka hintayin ko na lang para papalitan fuel filter at check yung brakes...yung sedimentor di ako familiar. pinapalitan ba yun sir o nililinis lang?
    Aug 2013
    #169
    Got 2001 Isuzu Fuego LS Pick Up truck with 4JA1 2.5TDi engine, one click start kahit hindi na use heater, nasubukan ko na sa Baguio City last January, hindi na need talaga heater. Hindi masyado mausok, madalas ko masubukan sa SCTEx at NLEx, unlike sa nakikita ko other Fuego pick up, maintenance talaga nagkakatalo. I also add 5ml - Shell 2T oil, Jaso FB for every liter of diesel fill, be it Petron Diesel Maxx, Shell Fuelsave, Caltex or small player diesel fuel, naging smooth ang andar lalo na sa high rpm run, parang CRDi ang andar. Very patient ang engine na ito, sa long drive, hindi siya overheat kahit traffic, medyo makupad lang talaga, umaangil na siya sa 120 kph, hanggang doon ko pa lang na-try, saglit lang yun, pero kung fitted with high speed differential, baka tumulin pa with such a small engine. Workhorse kasi intended use kaya ganoon lang speed.
    #170
    Solid engine basta properly maintained... pag napabayaan pwede pa rin.. ganun yan ka tibay
    May 2009
    #171
    Quote Originally Posted by aioshin View Post
    from my experience and some research on the net, may dalawang transmission models fitted sa mga 4JA1. eto ay yung MUA & MSG. the MUA trans have higher gear ratios so much better ito on uphill climbs, load carrying, etc. yung company service ko non e MSG. hirap na hirap umakyat pero nakaka 140 kmh sa hiway. MUA trans oil capacity is about 3 liters while yung MSG e approx 2 liters naman. nalaman ko ito nung drinive ko yung isuzu pickup ng kaibigan ko. ramdam na ramdam ko yung difference sa uphill climb and load carrying sa 1st gear pa lamang. mas relax ang makina sa MUA trans.
    from my observation, may selected models ng LS (pre fuego models) at siguro may konting fuego models na naka-MUA transmission. at lahat ng IPV e naka-MUA trans din. ang quick way para malaman is the length of the shift lever at yung location nya on the transmission tunnel sa body. mas malapit sa engine yung shift lever ng MUA kesa sa MSG trans.
    i'm planning na rin na iswap ang aking lumang mitsu pickup sa isuzu pickup e. nakakasawa na rin isipin parati yung kondisyon ng timing belt ko.
    Aug 2014
    #172
    Seems there was a little air inside the water separator, just bleed it and its ok after that, I remember i cleaned and replaced fuel filter, maybe i was not able to do proper bleeding that time.
    Apr 2014
    #173
    Guys my ride is a xwind 2004 model tinanggal ng radiator specialist ang thermostat kasi no need na daw dito sa pilipinas kasi hot climate tayo. Anyone done this also and any inputs sa performance and FC. Thanks sa mga makapag reply..
    Apr 2013
    #174
    Quote Originally Posted by maverick74 View Post
    Marami na gumagawa niyan pero nagsisi sa bandang huli. Bakit naman tatanggalin yan eh important component ng engine cooling system yan. Kapag walang thermostat, mas matagal ang cold start mo. Malakas sa gas. Hindi din ma aachieve ng engine ang optimum temperature niya sa highway driving. Magiging sluggish ang engine. Kung no need na dito sa atin sa Pinas yan, dapat sa factory pa lang tinanggal na yan. Nakatipid pa sana lahat ng auto manufacturer. Nilagay yan kasi may purpose yan. Siguro ang mas maganda tanggalin mo, yung mekaniko mo. Hehe. Ipabalik mo na lang ulit yan thermostat.
    Posted via Tsikot Mobile App
    Apr 2014
    #175
    Quote Originally Posted by saksidriver View Post
    Thank u bai.. bukas na bukas pa reinstall ko thermostat ko after 3 years na walang thermostat. heheheh.. tingnan ko ulit kong may difference ba.
    Oct 2014
    #176
    Quote Originally Posted by miked View Post
    Pwede po ba yun malaman depending on the manufacturing year ng sasakyan? Mine is a 1992 Isuzu LS Model 4x2. Thanks sir!
    Oct 2014
    #177
    Same with mine sir. Year 1992 pa pero same engine lang non-turbo 4JA1 and yes hirap na ako umangat pa above 100kph sir be it a straight highway without kasalubong or kasunuran. Done that with the 5th gear at kahit anong sagad ko sa accelerator pedal halos hirap ng humugot pa ng speed yung makina, kita ko naman sa speedometer at RPM gauge hindi na halos tumataas. Staying between let's say 1800-2000 rpm. Di talaga siya ganon kabilis because I've driven the same road (same condition) using our non-CRDi TDi 4D56 strada at kayang kaya ko pang umabot ng around 140-150 kph eh.
    Oct 2014
    #178
    Quote Originally Posted by IOwnIsuzu View Post
    sir, pwede po ba magtanong? ano na po ba ang options na pwedeng gawin kapag sobrang nginig na nung engine ng crosswind? 2004 xuvi tsaka white na po yung usok niya. help po pls.
    Sir, hindi ko lang 100% sure kung totoo ito ah pero palaging sinasabi sa akin ng father ko na mas mabuti na daw kung medyo mausok yung sasakyan mo basta kulay itim yung usok na lumalabas kaysa kulay puti. Try mo ask sa iba sir. Mine is medyo mausok din pero itim at may nginig din minsan (although this could be broken engine support lang or maduming fuel pump e.g. may tubig sa loob or maduming air filter; my car used to be shakey din noon but then nung pina-service ng father ko paguwi niya wala nang alog, sabi niya nilinis ng mechanic yung air filter kasi madumi na halos may lumot na and yung fuel pump because madumi na! sometimes ngayon medyo umaalog siya and maybe baka kelangan ko ng palitan fuel pump and air filter but it's just that na inayos sa akin wala na alog)...
    Oct 2014
    #179
    Quote Originally Posted by cokezero View Post
    i have a isuzu ls 1994 model.. normal lang ba na kada startup (morning) ng pickup ko lalabas yung oil & batter indicator tapos kelangan ko pa mag antay until mawala yun (siguro 15-20min) bago magamit yung pickup.. *btw nawawala agad pareho pag ni-revolution ko agad
    Base on my experience~
    a. Battery Indicator - Yung sinasabi na I.C. sa alternator. I think it's the most sensitive part of the alternator eh and I don't know sa ibang place ha but dito sa amin yung mga nagbebenta ng ganyang parts ay may "No Return Policy". It's either you get a good I.C. or a defective one. I don't know bakit ganon. I had mine changed few months ago, mabuti it was a good buy pero same lang tayo every startup ko especially sa umaga (first start-up) always nag-aappear yung battery indicator pero nawawala when I rev up the engine. But be reminded na if hindi pa din nawala kahit anong rev up mo, alternator na may problema, hindi na siya nagchacharge. Or baka grounded connection ng indicator pwede rin so it keeps on showing up.
    b. Oil Indicator - base on my experience, nag-aappear yung ganon sa akin na matagal and kelangan pa i-rev up (just like that battery indicator problem) nung time na hindi ko namalayan yung engine oil ko konting konti na lang pala (those times na may leak sa oil seal ng engine ko and transmission so unti-unting nauubos yung engine oil). I also took notice during those times na konting konti nalang engine oil ko, pag mabilis takbo ko and then magmemenor ako to turn to a road in my side (whether left or right) nag-aappear for a split second yung oil indicator but then kahit na konti nalang engine oil ko nung time na yun, hindi man lang nag-overheat yung engine or uminit na katumbas ng init ng ibang engine during normal usage good condition. Iba talaga 4JA1, di ko alam bakit hindi masyadong umiinit :/
    Aug 2014
    #180
    Oil indicator, I remember, yung oil indicator signal ay galing dun sa oil sender sensor, baka naman loosen na yung nakakabit na wire kaya pag inalog, nag loloose contact kaya nag sesend ng signal. Patingin na din baka meron ng leak dun sa portion na yun.
4JA1 Engine, Are there any problems?
