Page 381 of 384 FirstFirst ... 281331371377378379380381382383384 LastLast
Results 7,601 to 7,620 of 7661
    Feb 2007
    #7601
    Quote Originally Posted by Furry View Post
    Thanks all. Now proud to be an owner of a GL despite the minimum to none bells and whistles [emoji848] Any recommendation on the following:
    - car alarm / keyless entry
    - rear sensor / camera
    - dashcam (thinking of a Yi Dashcam or those long mirrors that combos as a front/rear)
    - is automatic foldable mirrors possible when start/stop engine?
    Most importantly, will doing these outside of casa void my warranty???
    Thanks! Really happy i chose this over the HRV! The power and smoothness of the ride is well worth it!
    Hello Good evening,
    napalagyan nyo na po ba ng Keyless entry ang tucson nyo? Saan po kayo nagpalagay at magkano inabot
    Thanks
    Nov 2017
    #7602
    Parang naka display ung latest 2019 Tucson sa Hyundai Pasig
    Quote Originally Posted by garyq View Post
    ilan km/liter ninyo on the average? thanks!
    Waterfall grill na?🤢🤢🤢🤢
    Nov 2017
    #7604
    Confirmed, naka display na nga sa dealerships ung 2019 models
    Aug 2018
    #7605
    Hello, guys. We recently had chance to test drive
    2019 Hyundai Tucson. Thank you
    2019 Hyundai Tucson 1.6 Diesel Test Drive | In-depth Review (Let's drive Hyundai's new SUV, Tucson) - YouTube
    Oct 2018
    #7606
    Hello po. San pwede makabili ng tonneau cover?
    #7607
    Quote Originally Posted by Mdcrc View Post
    Autogears PH sa facebook.
    Oct 2018
    #7608
    Thank you!
    Sep 2014
    #7609
    ang ayaw ko dyan sa Tucson yan plastic na nasa wheel arc, that can easily turn whiteish sa tinde ng acid rain natin dito.
    that's why I prefer cars without plastic trims talaga. like the MUX, Everest, Terra, Montero. hirap maitain black plastic trims, pampapanget sa itsura in the long run
    Feb 2018
    #7610
    Hi Sirs!
    I’m planning to buy a 2010 Tucson AT as a 2nd vehicle. Test drived it last and napansin ko lang 2 things. Mabigat ang steering compared to my car Vios 2016 AT. Is it normal ba sa Tucson? 2nd is when breaking may tunog sya. Any inputs would be appreciated. By the way mileage nung Tucson is 54k lang.
    Aug 2004
    #7611
    Guys sa mga naka Gen3. Got tons of available upgrade options. Just go thru my FB page "https://www.facebook.com/TunerAutoImportsPhil/".
    Sent from my vivo 1804 using Tapatalk
    #7612
    Quote Originally Posted by bynnos View Post
    Hi Guys,
    Has anyone here experienced a stalled engine while driving at high speed?
    While driving at Skyway 2 weeks ago, my engine stalled, dashboard lights went on and I lost steering and brakes. I managed to slowly control the vehicle to a stop on the shoulder. Upon restarting, the engine was ok again.
    It happened again twice last week while driving at EDSA. Same situation. Engine was ok after restarting.
    I have been driving the car for over a week now and thankfully, the problem has not recurred. However, I am not sure what is causing it.
    The car is at Hyundai Shaw today. They're saying they've not had such a complaint before and they are not sure they can correct it unless they actually experience it.
    Anyone had the same experience? What was the cause and how was it corrected?
    Thanks...
    Hi Sir! Long time!
    Vin had the same problem before e. Parehas kayo naka Theta. Parang nasa fuel pump ata ang issue niyan. Pero dapat hindi na mag start ulit. Try ko itanong kay Vin kung paano naayos yung sa kanya.
    Yun sa akin kasi na-dalawahan na ako hehehe nasisira yung socket ng fuel pump tapos ititirik ka talaga.
    Aug 2012
    #7613
    Hi guys, need to replace my 2013 tucson 4x2 brake pads... Whats the best option na di maingay? Thanks!!!
    Sent from my VTR-L29 using Tapatalk
    #7614
    Questions on tucson crdi 2010-2014:
    1. Are any of these eps already?
    2. How is the 4x4? For light offroad conditions only, loose gravel and 3-4 inches of sticky mud?
    3. What is the fuel consumption in city driving?
    4. Any notable problems - suspension, engine, body?
    I still have not decided on which coding car to buy kasi. I was choosing before between vitara 4x4 2009-2016 (non available in the market) and forester 2.0. 2009-2012.
    I'm presently eyeing a 2014 crdi model with 38k on the odo.
    Thanks.
    May 2019
    #7615
    I also bought a 2.0 CVVT Tucson https://www.xeoto.com.vn/hyundai/tucson and I'm quite satisfied with its performance. I also like its sound system as it already has an aux input that allows me to put in my IPOD.
    #7616
    Thanks.
    1. I have the 2015 crdi and its eps.
    2. I got stuck once in sticky mud, the type of mud you will find in fishponds, tucson is light so its easy to push. The low ground clearance and the HT tires are also not helpful in sticky mud.
    3 8 km/l in metro tmanila traffic.
    4. Kalampag sa rear, I omce loaded 4 sacks of rice at the back, I replaced all the rear bushings, the noise is still there.
    4a. Turbo hose, if not properly set after PMS , part of the hose will touch the header and slowly burn a hole in the hose.
    4b. The front under cover is made of plastic, its easily damage if you hit an object on the road. Cost 3.5k to replace, but the part is hard to find.
    Its a good cuv, drove it twice to sagada and banawe with no issues. I also drove it to cebu and back via bicol.
    May 2019
    #7617
    Hi Guys,
    I'm planning to buy a 2nd hand "2012 Hyundai Tucson CRDI" Sa mga nakikita ko dito sa forums parang ang daming nagkakaron ng issue? Sulit parin ba sya bilihin or would you recommend something else?
    Some reasons kaya gusto ko ung Tucson sana is because of the Looks, Ground Clearance, Diesel
    Meron din ako nabasa na nagkaron ng Mass Recall for 2011 to 2014 Tucson. Are those for Gas versions or kasama mga Diesel?
    Jan 2009
    #7618
    Quote Originally Posted by boogie18 View Post
    kuha ka ng bendix bro. don't buy the hyundai brake pads.
    Sent from my HUAWEI M2-801L using Tapatalk
    Aug 2012
    #7619
    Quote Originally Posted by red.speedy View Post
    Thanks sir, where can i get it from?
    Jan 2009
    #7620
    Bought Bendix GCT front break pads from Lazada before.
Hyundai Tucson
