Page 373 of 384 FirstFirst ... 273323363369370371372373374375376377383 ... LastLast
Results 7,441 to 7,460 of 7661
    #7441
    Yes, the second generation is "gettin-jiggy-wit-it"
    I have a 2014 crdi as well, learned to live with (and love) its ride characteristics.
    thank you... it seems i need to live with it, feeling ko tuloy nasayang yung pag palit ko ng shocks sa likod and the ride is the same... im a tucson lover here kasi
    Jun 2010
    #7442
    Quote Originally Posted by emdee_27 View Post
    ano tire pressure mo sir? baka bawasan mo mga 1psi or more depending sa ride feel na gusto mo. might help libre lang naman.
    #7443
    Quote Originally Posted by mda_ View Post
    with the stock mags na 17, i maintain it at 33psi... i tried it reducing it to 30psi pero ganun padin at naramdaman ko medyo bumigat steering, i tried it for several days naman na 35psi, ganun din pero ok steering gumaan, pero nag worry naman ako baka sobra over inflated kaya binalik ko sa 33psi.
    me naka pagsabi sakin na lagyan ko daw ng strut/sway bar sa harap... pero iniisip ko yung strut bar e para sa more responsive steering when cornering naman kaya hinde ko nilagyan, baka kasi masayang lang pero ko.
    Jun 2008
    #7444
    Quote Originally Posted by JJB View Post
    actuator rin daw problem sa unit ko and casa is selling it at 3.8k with free labor. I can't open the trunk anymore since lock doesnt disengage i guess.
    Update on my unit. With regards to the power steering problem, y unit's crank shaft pulley needed to be replaced. wear and tear daw so not covered with warranty. First time ko masiraan ng crank shaft pulley within 5 years among all my cars I've owned.
    Mostly yang rubber damper ang nasisira dyan. Meron yata solid pulley from old starex na pwede sa tucson.
    Sent from my Lenovo A7000-a using Tsikot Forums mobile app
    Apr 2012
    #7445
    What's the minimum fuel requirement for Tucson GL? Thanks
    Sent from my LG-H818 using Tapatalk
    #7446
    Quote Originally Posted by darylmonte View Post
    Good Evening mga sir.
    2010 2.0 GLS AT po gamit ko.
    May naka-experience na po ba sa inyo ayaw pumunta from Drive to Reverse yung gear shift? Hanggang neutral lang inaabot. Intermittent po problem. First time nangyari December last year pero recently mas nagiging madalas.
    Ang ginagawa ko para umayos ulit eh release yung break tapos tapak ulit hanggang sa pwede na ulit mai-move yung gear shift.
    May nakapagsabi na "Shifter cable po ang problem for replacement napo or try to adjust..", tama po ba?
    Salamat mga sir.
    sir brake light switch ang problema niyan, that was my problem 3 years ago. hyundai shaw replaced it 3 times. each time had to wait almost half a day sa pila tho under warranty. i discovered from google madali lang pala, bought the part sa seiring araneta parang 350pesos lang, replaced it myself wala pang 10minutes. and never na nasira ulit. look under the steering wheel and trace the brake pedal pataas makikita mo na ang switch. google the image and instructions. hope this helps
    Sep 2016
    #7447
    Hello guys,
    Need your help/expertise please. I'm considering getting a tucson 2011/2012 as a daily, all-around errand car for my employees back there in Pinas but I'm a bit concerned about the parts availability if something breaks. The comments I've read re parts availability are not very encouraging, is it true that local parts sellers don't stock up on hyundai parts and it can take weeks or event months to get them? I would buy the x-trail or escape buy my employees prefer tucson and I'd like to keep them happy, but this serviceability/parts availability worries me.
    Would greatly appreciate your inputs.
    Regards,
    Bill
    Sep 2014
    #7448
    Parts are abundant sa Banawe. Kaya lang may bago style mga tindero, pino-profile ka, pag si ka mukhang mekaniko, kunwari sasabihin nila dapat may sample kahit nasa dala-dala mo car . Eh di symepre papatanggal mo para makita, kita yun mekaniko nila
    Iba na ang mga tao sa Banawe lalo na yan Fronte, one of the reasons not to get a Hyundai Anymore, I guess,
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    Oct 2016
    #7449
    Hi po!
    Ano po kaya size ng headlight bulb ng tucson 2016 gas? Low and high beam mo.
    Feb 2011
    #7450
    Hello has anyone experienced this:
    ABS, Hill-Descent Control (HDC), Traction Control light is on while driving, cant turn them off. Any fixes to this?
    '12 Tucson GLS Premium DSL 4x4
    Jul 2016
    #7451
    Quote Originally Posted by rrdanas View Post
    There is something wrong with the ABS system, could be sensor, wiring or the module itself. I assume since 2012 model, under warranty pa? Bring it to casa na lang para ma diagnose using there computer scanner.
    Jul 2016
    #7452
    Quote Originally Posted by Janemar View Post
    Based on experience, #1 cause nito is a break in signal of one or more abs wheel speed sensor. Either may pinaservice ka under chassis at natamaan ng mechanic sensor or nasira nya wire. Pwede kinain ng daga wiring...
    Dec 2013
    #7453
    Good day po mga sir, Newbie po dito, Tanong kolang po kung anong input or masasabi nyo sa 2016 tucson? balak ko po kasi kumuha this year, base sa mga nababasa ko diesel ang maganda, totoo po ba yun? malakas din po sya syang humatak and fun to drive? At sa mga parts po mukhang madali naman na at madami ng mapagkukunan ngayon. Ano rin po gagawin ko pag nagbreak in? salamat po sa mga magrereply.
    Jul 2006
    #7454
    Walang nag reply ... ako nalang.
    I have a 2014 Tucson diesel 4x4 automatic. Now on 21K++ mileage. It should have the same engine as the current one.
    1. Engine has adequate power for its equivalent displacement. On long highway stretches, hindi ka maiiwan (actually mauunahan mo pa) ..
    2. Parts availability should be good. No major repairs (thankfully) in our Tucson, except for the usual service parts.
    3. Break-in? Personally, I did nothing. Went to Baguio on the first weekend after we took delivery of it, then drove it like I stole it. But, in your case the proverbial 80 kph speed limit before the 1000 km mark is okay, should you choose to follow it.
    4. On 4x4 (lock) mode, it will happily traipse in the most sandy of beaches.
    5. Fuel economy is around 12 to 15 km per litre on strictly Unioil Euro 4 diesel.
    6. My wife drives it, because its small.
    Good luck on your purchase.
    Dec 2013
    #7455
    Thank you po sa info sir, Bale po ngayon decided nako kumuha talaga ng tucson ang pinagpipilian ko nalang is kung diesel or gas, medyo mahal ng 200k ang diesel baka di ko kayanin, Explain ko lang po ang sitwasyon ko baka may advice po kayo sakin, Seaman po ako at umuuwi po ako ng pinas every 6 months and 2 months vacation po, sa 2 months na yun dun ko lang po magagamit yung sasakyan then for 6 months nakatenga lang sya at walang gagamit, advisable po ba ang pagbili ko ng brand new tucson?
    Mar 2015
    #7456
    Quote Originally Posted by rontrip25 View Post
    kung totally walang gagamit ng ganun katagal, wag ka na bumili. mag rent ka na lang.
    yun kaibigan ko seaman din, bumili ng city. 10months to 1 year naman nya hindi nagagamit. nakakapang hinayang lang.
    Dec 2013
    #7457
    [QUOTE=ads13;2803519]kung totally walang gagamit ng ganun katagal, wag ka na bumili. mag rent ka na lang.
    Sent from my SM-N910C using Tapatalk[/QUOTE
    Nakakapanghinayang nga po, naiisip ko iparent a car nalang kaso ang swerte naman ng gagamit naka tucson pa at baka malaspag lang at mas mahal bayaran ko sa maintenance...hehehe,
    Jun 2012
    #7458
    [QUOTE=rontrip25;2803522]
    Quote Originally Posted by ads13 View Post
    Tama. Ikaw na lang ang ang mag rent
    Sent from my SM-A9000 using Tapatalk
    Jul 2006
    #7459
    Seaman po ako ...
    Still, its your choice on whether or not to buy a vehicle or not. At the end of the day, ikaw pa rin masusunod di ba?
    Or you can scan the classifieds for pre-owned units.
    Diesel for me, hands down, no regrets. Even if it costs more. The go factor is more than worth it.
    Dec 2013
    #7460
    Oo nga po medyo may kamahalan ung diesel pero in the long run makakatipid naman sa fuel, I decided na kumuha napo ng diesel, Iniintay ko nalang maayos ang issue sa lto, may bagong memo po kasi sa mga brand new. Anyway, Thank you po sa advice nyo.
Hyundai Tucson
